Question about Nintendo DS Lite Console
Nintendo Ds Lite Top Screen Problem(pls help:( )
The top screen of the ds does not work(Goes blank)until you lower the top part a bit but if you bend it in the position it should be it stops to work,the lower screen works fine.
    Problem Solver:
  • 5 Answers
It is probably the connectors connecting the screen to the bottom part where the CPU is. My portable Wii screen does the same thing. If you can live with it, your OK, but you might need a new DS. I recommend a DSi!
Posted on Jul 23, 2009
My ds lite power gooes off as soon as you turn it on
The bottom screen flashes an then the green light goes off new top screen is needed very common on ds lite i repair them for a living an can sort yours for about 18 quid
Simon
Dsdoc
Nov 26, 2011 | Nintendo DS Lite Console
My Nintendo ds lites screen is not working i dont know why? the coulour is white on the top screen and it has white lines all over it but the bottom screen is fine. Please i need help may you please give...
Hello.
There is a problem with the connection of your top screen. Try bending it A BIT backward or forward until you get a display. BUT that is just a "temporary solution". You will eventually need to bring it to a service center and if it is badly damaged, they will replace the top screen.
Please rate my answer.
Aug 13, 2011 | Nintendo DS Lite Console
The Top and the bottom of the DS are disconnected. But it still works, and the top screen has gone blank.
Uh, oh. You gonna have to buy a new casing for your DS and possibly a new top screen LCD. It is not that expensive compared to the lower screen, but it is very complicated to assemble it yourself so it is very advisable to bring it to a pro.
Aug 10, 2011 | Nintendo DS Lite Console
My DS Lite's top screen is blank white. Help.
a white screen can be due to two reasons 1. the screen is ruined which will cost you mush and 2. the display IC might have ruined which will not cost you mush .
Jul 07, 2010 | Nintendo DS Lite
Wet DS lite. Top Screen now blank in one corner
you need a new top srceen, you can get these screens on ebay for about 20.00
Let me know if this helps!!
Jan 28, 2009 | Nintendo DS Lite Console
Turns on and lights up but no images on top screen
The DS top screen has two components, which are the LCD display, and the backlight. If the LCD display has gone bad but the backlight still works and the connecter is seated properly, the DS will still power on and the lower screen will be normal, and the top screen will light, but it won’t display anything.
You didn’t mention if your DS is the original DS or the DS Lite. Replacement top screens for the DS Lite are cheap on eBay, but installing the screen is a bit complex. The screen for the original DS is a different part and they are more expensive and hard to find.
I’ve never worked on an original DS, so I can only tell you about installing the top screen on a DS Lite.
First, the DS Lite has to be just about completely disassembled. You have to completely remove the top and bottom cases, pull out the microphone and wi-fi cables, and release the connecter for the top screen, which is located on the main board in the lower case. You’ll need the tri-wing screwdriver. You can leave the bottom screen/touch screen assembly attached to the main board, but be careful not to pull or tear the flex cables. Check YouTube for videos on disassembling the DS Lite.
Here’s the deal breaker for most people: The speakers are soldered to the flex cable of the top screen. I’ve never seen a replacement sold with speakers. You’ll have to unsolder your speaker wires from the old screen cable and reconnect them to the new one. If you can’t solder, you could take the screens to a local tv/electronics repair shop and pay to have it done. I got this information for you from http://wiinewz.com/forums/nds-general-discussion/72805-ds-top-screen-white-blank.html this appears to be a common problem I hope this helps
Dec 01, 2008 | Nintendo DS Lite Console
Nintendo DS Lite top screen is shivering
I think you have a defective screen or the adjustment 'screw' for the topscreen on the mainboard is defective.
My opinion is to send it for repair to Nintendo or a DS Lite repair service.
Nov 25, 2008 | Nintendo DS Lite Console
My nintendo ds lite top screen isn't working properly
Top LCD's flex cable that passes through right-hand hinge into bottom part of case will be damaged or not properly seated in its connector socket.
Nov 17, 2007 | Nintendo DS Lite Console
Non-working top screen
If you see lines on either screen of your Nintendo DS Lite during game play, then it is likely one or more of the components that create the image on the screen are damaged. This can occur if there has been an impact -- such as being dropped or hit -- to the Nintendo DS Lite's screens. Phone 1-800-255-3700 to discuss available repair options and they will be grateful to assist you at any time of need.Important Note: If you are seeing lines on the screen that slowly fade away after turning off the system, this is normal.
Oct 28, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
218 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
