Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
CANNOT REMOVE THE OSD MAIN MENU FROM MONITOR SCREEN
THE OSD MAIN MENU AND SUBMENU IS DISPLAYED ON MY HP PAVILLION F1503 MONITOR FOR WHICH I CANNOT REMOVE. WHEN USING THE MOUSE THE CURSER GOES BEHIND THE OSD MENU NOT ALLOWING ME TO CHOOSE AN OPTION SUCH AS "EXIT" .
IF I SELCET THE AUTO/SELECT BUTTON THE ITEMS IN THE MENU ARE HIGHLIGHTED INDIVIDUALLY IN A FAST MOTION STARTING FROM FROM TOP TO BOTOM.
CAN THIS OSD SCREEN BE HARMFUL TO THE COMPUTER ?
ANY HELP ONE CAN PROVIDE TO REMOVE THE OSD SCREEN WOULD BE GREATLY APPRECIATED.
  • langloislaur Jul 30, 2009
    The solution offered above was very helpful and thank you.
    Now my next question is can you tell me how you go about replacing a faulty switch in the menu button ? Is this something I can do and if so how or does it have to be by a professional ?
  • langloislaur Jul 31, 2009
    Thank you so very much !!
    This experience was very pleasing and helpful.
    Brigadier General:
  • 7,191 Answers
The problem of OSD Menus popping up automatically are usually caused due to a faulty switch in the Menu button which is getting switched on automatically.
This menu will not harm the computer but constant OSD menu will most probably lead to permanent damage to the pixels in the LCD screen plus it is a constant irritation to your eyes which are most precious.
This problem can be rectified by replacing the faulty menu switch. Hope this solves your problem Thanks.
Posted on Jul 23, 2009
  • AliTech110
    AliTech110 Jul 30, 2009
    Thanks for the feedback.
    You should definitely refer the servicing to a qualified repair personnel because there are a lot of delicate and sensitive parts inside your monitor and the problem could become worse or you can cause some other serious damage if it is not handled carefully. Also, it requires great skill and speciallised equipments to open and then successfully re-assemble the monitor.
    To a trained technician, the present problem is a very minor one and should be rectified easily.
    Hope I have helped you. Thanks.
  • AliTech110
    AliTech110 Jul 31, 2009
    Thanks for the feedback and appreciation.
Osd main menu and brightness bpxes stay in center of screen
-the main problem with your monitor is the OSD buttons
-the OSD buttons could be stuck so you can try checking the OSD buttons one by one to check which one is stuck
-try pressing it if it could remove the stuck buttons or you can try using a toothpick to remove the stuck OSD button
Nov 22, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
HP 2009m monitor. OSD lockout keeps appearing on
OSD (On Screen Display) lockout. To resolve the issue you can hold the power button of the monitor until you get another message something similar to "OSD unlocked"
try holding menu button also if it doesnt workout
Nov 30, 2009 | HP 2009M Monitor
The osd main menu has appeared on my hp pavilion f1703 monitor
Control Panel->System->Hardware->Device Manager->Monitor. select and uninstall. Then let Windows detect the monitor and re-install the drivers for your monitor. Do the same for the disply adapter in the Ctrl Panel.
Aug 24, 2009 | HP Pavilion F1503 15" LCD Flat Panel...
My computer screen has a blue box that pops up and say "Controls locked". I am assuming that the buttons on the bottom right hand corner of my moniter is what it is talking about because when I hit the...
This is from the user manual for the monitor. You can download a copy from hp here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=324216&os=228&lang=en&
Click on the "monitor user's guide" link to download.
There are four adjustable options on the OSD settings screen: Lock OSD settings, Timeout, H Position, and V Position.
To change OSD settings:
1 Open the OSD setting screen under the Advanced menu. See
“Using the On Screen Display” on page 25.
2 Press the Browse buttons to select the option you want to adjust.
3 Press the Select button to check the option.
To change OSD lock setting:
1 Press the Browse button to select yes (lock) or no (unlock). The
setting is automatically saved when you change the value.
2 Choose Exit sub-menu and press the Select button to return to
the OSD Main Menu or press the Menu button to exit OSD.
NOTE: Once OSD is locked, all OSD functions including the
shortcut buttons are disabled. If OSD is locked, pressing
any button on the monitor directly opens the Lock OSD
settings window so that you can unlock OSD.
Dec 02, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Whereabouts and meaning of OSD
OSD stands for On Screen Display. You get to it by pressing the Menu button on the front of your monitor.
Here's a link to making adjustments...and unlocking the OSD:
HP f1703
Oct 18, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Hp pavilion f1503 momitor
Hold the MENU button for 10 seconds to lock or unlock the OSD
Aug 05, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
Problem on hp monitor
The problem should be defective keypanel.Try replacing the switches .
It should solve your problem.
Please provide feedback and rate this solution.
Samir.
Apr 08, 2008 | HP Pavilion F1503 15" LCD Flat Panel...
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
1,598 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
