Question about Cobra Radio Communications
Constant RX mode on cobra microtalk PR3850WX
I have a cobra microtalk PR3850WX that is always on RX mode and it is showing contantly the symbol RX on screen.
The walkie talkie is only transmiting but is not receiving. It happens in all channels.
Any suggestion to solve it?
    Problem Solver:
  • 14 Answers
Sounds like the radio was subjected to electrostatic discharge. If you have your manual, and it describes a way to do a "master reset" on the radio, follow the instructions. This usually involves pushing down on one key while turning the radio on. Otherwise you have to find a licensed dealer for factory service, as there is no way to repair the radio yourself. The use of surface mount technology still confuses many Techs unless they have been to a company's two or three week seminars.
Posted on Jul 24, 2009
Because of the low battery, the radio is programed only to recieved but not to transmit due of the luck of energy. Once the battery is fully charged you can easy change the RX mode by pressing on the "light/max range" button.
Hope this helps!
Best from Bulgaria!
Posted on Oct 07, 2013
HOW TO TURN ON COBRA MICROTALK PR 260 WALKIE TALKIES
you have to press & hold the "mode" button for a few seconds, same to shut them off
May 11, 2014 | Cobra Microtalk Pr260 2 Way Radios Walkie...
One of my Cobra Microtalk radios is stuck on RX. Everything else seems to work. What could be the problem?
Hi!
Almost always, the problem here is that the micro switch for the Push-to-Talk (PTT) button has failed. Your radio should have a warranty, but even if the warranty has run out, it isn't horribly spendy to fix. I'd get in touch with Cobra Electronics, I have heard they're extremely helpful. Try this link and good luck!
https://www.cobra.com/help/
Jul 05, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
What does the "RX" mean on the display? How do
RX means that the radio is receiving a signal, this will put most of the cobra 2-ways into a locked state. many of the cobra models have an issue were after a bit of use, they will seem to receive a "mystery signal" sometimes, carefully taking the radio apart and cleaning out the inside with canned air will help, you may also check the terminals that the batteries connect too, otherwise the SoC (system on a chip microcontroller) likely has an issue.
Jul 02, 2011 | Cobra Electronics microTALK® PR 3850 WX ...
I lost my manual. Can I download a basic guide for free? Cathie
Yes, Cobra has the user manual for the PR3850WX available for download HERE
Oct 13, 2010 | Cobra Electronics microTALK® PR 3850 WX ...
Everthing on the radios work but there is no sound from the speaker.The RX shows on the display and the the vibrate work when called. Whats up?
#1 bad speaker, #2 external speaker jack bad/shorted, #3 volume control bad/open, #4 squelch control bad, & #5 is it both radios no audio?
May 13, 2010 | Cobra microTALK LI 7200-2 WX VP Two Way...
One of my walkie talkie has an RX on the display and you can send but you cannot hear the other person. How can I remove the RX as that seems to be the only difference in them. Thank you
depending on what radio you have, they are programmed in different ways, rx means recieve signal
and tx means transmit signal, if you have a mode button, you will have to scroll through it until you
get to the menu that allows you to change the radio transmission. it looks like that radio is only
programmed to receive signals and not transmit. good luck!
Nov 11, 2009 | Cobra Microtalk 100 FRS Walkie Talkie...
Constant RX mode on Cobra Microtalk Walke Talke
I have the same walkie talkies and on mine I can hold down the mode/lock button and it will come off of the Rx mode. Also, you should be able to press the talk button and it will come off of the Rx mode.
Jul 06, 2008 | Cobra PR4100-2WXVP 2-Way Radio
Cobra PR3850WX will not recharge batteries
There is a contact in the upper left hand corner of the batt compartment.This has to touch the metal of the last batt.If your batts have paper around them scrape it off where it contacts that contact point.
Nov 10, 2007 | Radio Communications
Radio Communications Logo
1,911 people viewed this question
Top Cobra Radio Communications Experts
AnyMHz.com
AnyMHz.com
Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
