Hi i have a xs 650 special. ijust had the carbs cleaned and now it backfires if i drive it without having the chocke in. it runs well with the choke. i
Sounds like a float level may have been altered redicing the amount of fuel flowing into the carbs, this may not have been intentonaly addusted, undo the drain screw at the bottom of each carb with the fuel tap turned off and catch the fuel from each bowl as you drain them, this will give you an idea which carb if any is at fault, it may be the float needle sticking, blocked pilot, or main jet, if you think of it like the choke is a separate jet, when you turn of the choke the fuel is restricted, the only other likely fault could be a blocked jet , or as i have described above, also check the throttle slides are opening as you run the bike with the air box rubbers removed you may have a split diapram,
Needle Is Stuck. Clean The Carb.
