Question about Dell Latitude D600 Notebook
I have no picture or image in mine laptop
Mine laptop; a  dell latitude D 531 work well but the LCD display is completely black as I turned it on; I need to use another l monitor to see the display of the computer, I made  hadware test(F12), and I found an error code 0413 LCD cable not found ;  I want to go further with mine hardware test but I don't want to risk damaging the laptop more; so I stop the test when I saw the error; can  anyone help me to solve my problem?
  • tresa boven Jul 26, 2009
    HELLO Jardunk, thanks for your response; I really need help; I have done what you said; I have partially removed the keyboard and I am looking under it and I can not understand what you said"the port underneath..."can you please tell me further where can I find it?; mine LCD display was already loose from the motherbord; I think the cables are goed; normally when I opened the laptop I am seeing 3green lamps appeared; I also made a test with the LCD display and I heard (3-3-4 beep code) Iam not sure if the LCD display is damaged ;I can't see any damage in the LCD screen; can you help me further? thanks Trvboven
  • Rik Evans May 11, 2010
    First thing is to check that the monitor cable has not come loose from the adapter port on the motherboard. To do this you will need to remove the keyboard and then you should be able to see the port underneath - it may be partially or completely unseated - if this is the case simply reseat. If not it is likely that the cable or screen itself is damaged and needs replacing.
    Sergeant:
  • 338 Answers
Hello there,
maybe inside the laptop a cable got loose.
you may want to take the laptop to a technician to repair it - else you can dissassemble the laptop yourself,and check if everything is connected. google for model and instructons how to repair it or come back on me if you're willing to do it yourself
Posted on Jul 23, 2009
Testimonial: "I followed the advice of Rocketman;now mine laptop is okey; Rocketman; thank you very much> trvboven "
  • 57 Answers
Could be the back light bulb is bad. Boot it up and using a flashlight pointed at an angle at the screen, see if you can faintly make out any images or text. if yes than its inverter or bulb time.
Posted on Jul 30, 2009
  • 4 Answers
Before taking the laptop to a repairman, try the function (Fn) key and F6 (display assignment rotation) key combination. Press and hold the Fn key and then press the F6 (CRT/LCD) key several times slowly to rotate the screen selection through its settings (LCD only, LCD/CRT both, and CRT only) just to make sure. MTG
Posted on Jul 28, 2009
Latitude B130 screen works great then cuts out to complete black, works with external monitor
Are you sure that the display is not set for external monitor only? Also take bright flashlight and shine on the display. If you can see the images then the problem is with the back light and usually caused by a bad inverter. Some times you can get the back light or inverter bu most times it is easier and cheaper to replace the entire display.
Aug 20, 2012 | Dell LATITUDE Computers & Internet
My Dell Latitude D820 has many problems.... The biggest one is that I came home from work to turn it on, and the screen is black... When it turns on, it is completely white. I am so upset! I just got this...
Screen issue:
It sounds like either the lcd screen or video card inside the computer is bad. To isolate the problem try connecting an external monitor to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the external monitor displays ok that proves your video card is ok and your lcd screen is the problem. If the external monitor displays the black or white screen like your lcd screen then your video card inside the computer is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Laptop hot:
Some laptops and the ac adapter get very hot. If the laptop is not shutting down, then it is not overheating, so don't worry about it. You can buy a laptop cooling pad that has fans on it and it plugs into one of the usb ports on the laptop. The laptop sits on it to keep cooler.
Your battery is probably dead so that is why you can only power it up using the ac adapter power cord. Once the power cord is removed, the laptop will turn off. Batteries only have a useful life, and after that, they have to be replaced.
May 21, 2012 | Dell Computers & Internet
I have a DELL LATITUDE D610 note book i need a
LCD screens are available on the Internet - here are some WEB sites that sell LCD screens :-
www.lcdparts.net
http://www.yallstore.com
http://www.shope2.com/
Dec 20, 2009 | Dell Latitude D600 Notebook
My monitor on my Dell laptop went completely black while I was on it. I have tried turning it off and back on, and the monitor is not working at all
You may have a defective CCFL backlight, it may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Nov 26, 2009 | Dell Computers & Internet
Dell latitude d820 xp: Mouse inputs are moving
Mine did that too, its normal, the actions undearneath maybe stuck just a little and thinks it is required to move when not
Jul 15, 2009 | Dell Latitude D820 Notebook
I dropped my laptop, white pixels turn pink
The CCFL lamp has been partially damaged and could fail completely any time. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
var selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1 = null,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2 = null,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3 = null; function checkReviewsMarked() { if (selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3 !== null) { $('btnctl00_SideColumn_ctrl_rater').disabled = ''; $('btnctl00_SideColumn_ctrl_rater').className = 'c_sub_small sub_enabled'; } } function checkAndSend(obj) { if (selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3 !== null) { setRate(selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3, function() { window.location.href = window.location.href; }); } }
Jul 09, 2009 | Dell Latitude D600 Notebook
Display Problems
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jul 02, 2009 | Dell Latitude 100L Notebook
Dell Latitude d620 display problem
Sounds like your computer has just bit the dust, do your self a favor and purchase a new one. This time buy an XP, it might be a little bit more, but you get what you pay for.
  `Nbryson
May 30, 2009 | Dell Latitude D620 Notebook
Dell latitude D600 display blacks out, showing just a ghost image
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is the backlight.
If you see a very dim image or flicking image on the LCD screen it means you have a backlight problem.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 21, 2009 | Dell Latitude D600 Notebook
Dell Latitude C810 LCD screen doesn't work
buy an inverter off ebay. they are cheap and good. 10 dollars
Jan 07, 2009 | Dell Latitude C810 Notebook
Dell Latitude D600 Notebook Logo
233 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
