''Protect'' mode on Denon AVR 800
What to do when this happens?
  • lswittenberg Jul 23, 2009
    Will try and leave a message back with results..
    Tx!
  • 133 Answers
Protect mode appears when there is a problem with the amp it goes into this mode to avoid any further damage to the system. to begin with disconnect all the speakers and see if it continues or else it could be that moisture in the circuits have caused it to go in protect mode or else ther is some shorting in the circuitry. It wud be wise to have it serviced by an authorised personnel
Posted on Jul 23, 2009
2 Suggested Answers
tech48
  • 624 Answers
SOURCE: Receiver goes into protect mode when hitting certain volume level
There is a problem in one of the output channels of the amplifier. That is the only reason it will do this. I work at an authorized Denon service center and have seen this problem several times, but it has never been the same thing that causes it. It has always resulted in extensive troubleshooting to find the problem. One time it was a capacitor in the pre-driver circuit for one of the channels, another time it was a transistor in the same type of circuit. I can not remember all the other causes. But without the proper tools and the knowledge of how to troubleshoot an amplifier circuit you will never figure it out.
Since this is an older model, more than 3 years old, it is no longer under warranty. They get a 2 year warranty from Denon. You can take it to any service center that works on stereo equipment and they should be able to fix it for a reasonable fee. Probable around $125 to $150 depending on their rates. It may seem like a lot, but it is much cheaper than buying a new one.
Since this is really the only option for you, unless you have the tools and knowledge, a FixYa! would be much appreciated and appropriate.
If you would like to troubleshoot it yourself, let me know, I have the service manual in PDF and can email it to you if you like and help you with troubleshooting it. But be aware, it is not an easy job.
Dave
Posted on Nov 10, 2008
Why does my new AVR X1000 keep going in protect mode
It only goes into protect mode usually when there are to manny speakers hooked up more then its can handle
Aug 01, 2014 | Denon AVR-X1000 5.1-Channel Network AV...
AVR X1000 going in protect mode?
If you used it for only 3-4 hours before the problem occurred then you should have a replacement warranty on the product.
I think you have already done the factory reset procedure shown on page 175 of the user manual.
Is it possible to take it to the place you purchased it from. Alternatively check the Denon website and find out who the closest agent is in your locality. Send it back with proof of purchase using a courier service that you can track for receipt. Hope it turns out well.
http://assets.denon.com/DocumentMaster/us/Owners%20Manual%20-%20English_AVR-X1000.pdf
Denon
Denon avr2312ci shuts off and blinks red
Yes that is why. The receiver is protecting itself from an un-stable load impedance which causes current/voltage spikes through the final amplifier components and proportionally through the input where the protection relay is (click),. Do not continue using the amp until you have repaired or replaced the blown speakers. A rule of thumb is to maintain 8 ohms on each speaker wire plugged into the amp. Keep that in mind or eventually you will damage it.
Jan 23, 2014 | Denon AVR-2312CI
I have a Denon AVR 1601 that cut out in the middle of a song. It will now not turn on, it starts and then cuts out
It went into what is called the protection mode,Did you have it cranked up loud when it happened,? Check if any of your speaker wires come off some how end are crossing . Or there could of been a power suge that will also cause it to go into the protect mode, End fried internal parts on it.If it is a internal problem. The repairs will be verry expensive if it can be (Repaired) A lot of times it is cheaper just to go end buy a different one.
Oct 20, 2012 | Denon AVR-1601 Receiver
Denon AVR589 shuts off. I removed all connections and plugged it back into the wall and powered it on. The same thing happened. I think the company told me it was going into protect mode. I have no idea...
One or more channels have a short in the audio output stage causing the protect mode to engage " saving it from further damage " this will require a professional or Denon service. I'am not aware if there are issues with this model.
May 07, 2011 | Denon AVR-3805 Receiver
How do you get a denon avr-2000 out of "protect" mode?
How diid i get a denin avr 2000 out off protect mode?
Sep 12, 2010 | Denon Audio Players & Recorders
I have a denon AVR-2000 that has gone into protect mode how do i get this off?
power output short....or spk or spk wire short check and .need service...
Jan 07, 2010 | Denon AVR-2800 Receiver
Denon AVR-1100 receiver "PROTECT" mode
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
Dec 25, 2008 | Denon AVR-1100 Receiver
Denon 1508
sterio wireing touching each other putting it in protect mode retrace all your wireing and redo this should clear up the protect mode if not return denon as manufacture malfunction to get replacement
May 30, 2008 | Denon AVR-2105 Receiver
Denon AVR -1905 made a loud popping noise, now doesn't stay on
The output section has smoked and requires repair. The unit is not in "protect" mode. This means that the outputs are turned off to prevent additional damage to either the amp or the speakers. Expect a repair to run from $15-$40 in parts plus the local labor rate.
Dan
Mar 26, 2008 | Denon AVR-1905 Receiver
644 people viewed this question
 Grubhead
Grubhead
