Question about HP OfficeJet 6210 All-In-One InkJet Printer
Printer not print on color
I have an hp officejet 6210 all in one printer, but just print on black ink, and not color at all.
  • 153 Answers
Change the ink and settings .
Posted on Jul 23, 2009
Prints blue instead of black
Blocked or out of ink, it needs more than one color to print black, good look
Apr 11, 2012 | HP OfficeJet 6210 All-In-One InkJet...
The printer won't print. It says replace the color ink cartridge. All I want to do is print black and white.
You can only use the black ink cartridge without the color ink. But no need to replace them in your printer.
When you print just choose black and white for the printed text must be black not colored. But if you still received such notification...just try to replace the color ink cartridge to continue printing
Note: As per my experience. printer with exclusive black ink alone will damage the printer easily due to unbalance printing of ink
Sep 20, 2011 | HP OfficeJet 6210 All-In-One InkJet...
My HP all-in-one 6210 doesn't print in color anymore. What can I do? Thanks!! :)
Your ink cartridge ran out of color ink. That kind of brand usually has a BLACK ink and a TRI COLOR ink cartridge. You can find them at most stores , WalMart , Target , Best Buy. Make sure you know the brand name and model when shopping for them.
Nov 07, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Can the ink cartridge HP 98 work on a 6210 HP Office jet?
No, it can't
The HP OfficeJet 6210 works with the following print cartridges:
Black: 94
Color: 95, 97
Photo: 99
Source: http://www.shopping.hp.com/supmodel/product/Q5801A
TechSaver!
Feb 01, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Use of 852 and 855 cartridge in hp 6210 officejet printer
This quite often happens with CLONE cartridges and happens very infrequent with original cartridges.
The cause is the ink level chip used in clones is quite often a very cheap chinese copy and very prone to failure or misalignment
Either way take them back and get them changed is my advice
Aug 17, 2009 | HP Office Equipment & Supplies
HP Officejet 6210 All-in-One: Black Ink Copy Problem
i've fixed a simular issue recently, it could be your print head has developed a issue\blockage for the nossles for the black ink tank, it could be mixing colours from word but a black white copy will just use the black ink, try removing the head and using isopropol on a qtip to clean the head for the black only.......
Aug 13, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Trying to put back in the color ink cartridge for 6210
The printers are bad about damaging the ribbon cable inside the print cartridge when you replace the ink cartridge. There is a small wire spring that gets pushed through the cable rendering the printer useless. Poor design by HP. How do I know? I did it to mine. It's cheaper to buy a new one then to have it repaired.
Jul 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
How to check ink level on hp officejet 6210 all-in-one printer
  • Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • Mar 22, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    Printer cartridges
    Dispose of the leaky cartridge. Clean the contacts in the machine with a little rubing alcohol and a q tip (don't soak it-just moistened it a bit) Make sure the Printer is turned off while you are doing this. While you are doing this I will look up your cartridges and what they are for. I suspect that you have a color cartridge/a regular black cartridge/ and a black printing only cartride but I will check. Don't ever use a leaking cartridge they can damage your printer.
    Aug 15, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    HP officejet 6210.
    Put the printer in the mode for changing the carts. Take out the Black ink car and clean off the heads on it. Looks like brown in color it's on the cart at the bottom To clean use paper towel with cold water never use warm or hot. Clean the area where the in rest in the printer also if you can reach it. The noise you hear is that the cart didn't go back in the right position. You have to be cart not to force these carts out as everything in this printer is made of plastic.
    Jul 23, 2008 | HP OfficeJet 6210 All-In-One InkJet...
    HP OfficeJet 6210 All-In-One InkJet Printer Logo
    164 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
