I have just instal my new pixma ip1300 printer but when i try to print it does,nt print and service error 5100 shows on my screen .
    President:
  • 2,306 Answers
5100 says the carriage with the inks can't move right to left properly. Possibly grease that needs to be wiped from the encoder strip, behind the carriage, and one customer left the white plastic tray over the hole and stopped the carriage. Look for anything inside that would stop the carriage from moving freely. Also under warranty..so free service
Posted on Jul 23, 2009
4 Suggested Answers
SOURCE: service error 5100
may be the driver are not installed correctly ... just try reinstalling the drivers ... and make a check that you have inserted the ink cartilage or not ...
if not insert it and then give try ... it may work ..
if problem persists then call the service rep ...
Posted on Feb 07, 2008
SOURCE: canon pixma ip1300 initialisation problem
I have a canon ip 1300 produces an error(both LED's are alternately blinking one blink for the green led and 5 blink from the orange led) then it will produce an error 5600.
Posted on Feb 24, 2009
  • 412 Answers
SOURCE: PIXMA iP1300 printer is showing an error 5100
nope try this --
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Posted on Mar 09, 2009
SERVICE ERROR 5100
for error 5100 usually i turn off my printer, then disconnect the usb cable then connect again to computer
then i turn on my printer again
try it
i hope this helpful
thank you for using fixya
Feb 19, 2011 | Canon PIXMA iP1300 Printer
It shows service error 5100 & doesn;t print
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Nov 20, 2009 | Canon PIXMA iP1300 Printer
CANON IP 1300 SERVICE ERROR 5100
ERROR 5100 means that there is some foreign object blocking your ink cartridge carriage that disables it from moving. It may be a piece of paper or a scotch tape or a staple wire. You may try cleaning also the encoder strip with a moist tissue paper. Furthermore, you may also try cleaning CAREFULLY the contact points of the cartridge holder and the cartridge itself (those shiny bronze pins) with a moist lint-free cloth.
Jul 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
nope try this --
Dec 28, 2008 | Canon PIXMA iP1300 Printer
Canon pixma ip1300 initialisation problem
Dec 03, 2008 | Office Equipment & Supplies
Service error 5100 canon pixma ip1300
see this --As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
Nov 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Service error 5100
Feb 07, 2008 | Office Equipment & Supplies
Canon ip2000 service error 5100
I have been facing same error and this was the solution.
Canon Error 5100
Sep 08, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
100 people viewed this question
k24674
jasbo
jasbo
