Problem with Panasonic 47'' HD Projection TV MN: PT47WX53G
Ok. Here is my delima. I have a Panasonic 47'' Wide Screen HD projection TV, Model # PT47WX53G. I am getting the convergence problem with the red and know how to fix that now and found the parts for that. I did however, like a ********, started to take apart the Red Projector. In doing so I proceeded to take it apart too far. Doing so allowed an oily liguid come out of the projector lens (pretty sure it is silicon oil). Now what to do. Can I hopefully replace that liquid or do I need to buy an entire red projection unit including the lens?
  • 8,617 Answers
You can get a bottle of replacement CRT coolant at the following link. But the spilled coolant will need to be thoroughly cleaned use denatured alcohol and let dry thoroughly as the coolant is corrosive and will destroy the solder, Components and traces of all items affected if not thoroughly cleaned.Heres where to get the coolant for the CRTs.
http://servicemanuals.vstore.ca/index.php/cName/prjection-tube-coolant/osCsid/a71095f09804ab9fe52939c4fa517cfa
Posted on Jul 24, 2009
My Panasonic hdtv PT47WX53G is having convergence issues
The repair kit called PT53WX53 convergence repair kit from www.tvrepairworld.com is the correct kit for your model and symptom. The kit contains the ICs, Resistors and the CD with instructions.
Aug 20, 2010 | Panasonic PT-47WX53 47" Rear Projection...
What are the error codes for a Panasonic PT-47WX 42 TV
3 times LED blinks in Panasonic PT-47WX42 shows problem with convergence out chips failure as this tv has two big black ICs STK392-110 as convergence output, replace them to fix tv problem.
Click Part Store to see an image of required chip and price info.
Local tv tech is recommended if you have no experience of working in tv circuit boards.
Thanks.
Apr 18, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Need to find a convergence kit for a pt47wx53g projection tv
Mats Electronics has the STK ICs you need .
1-800-628-1118
STKs will have part number on them ,example STK392-110 go by number printed on them if they are 110s upgrade to 180s Better ICs.Let me know if their is anything else that you may need help with.
Mar 25, 2010 | Panasonic PT-47WX53 47" Rear Projection...
TV IS OFF BUT HAS A GLOW ON THE SCREEN
replace capacitor ceramic 473j 250V beside plug yoke.
Apr 15, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Convergence problem
If you cross reference this term, I think you'll find alot of helpful info on your problem:
Convergence amp ICs
These (there are probably two of them) are probably burned out, at least one of them. From what I see online in blogs and such, this repair can run several hundred dollars to have done professionally, but if you are qualified (or at least careful enough to learn how to do it SAFELY and CORRECTLY) you can do it youself for around $12 - $50, depending on what model part your set uses.
Hope this helps. I am about to embark on this same repair myself on my Panasonic PT47WX53G, so my best to you.
Dec 30, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Power issues-pt47wx53g
convergence ic's failed. probably took out some resistors and the pico fuse from what i am hearing from t.v techs. its like 50$ in parts if u can solder / desolder.
Oct 17, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Hewhen lp
The convergence ICs need to be replaced. # blinks is the error code for the convergence. You will need two STK392-110 Convergence ICs you can get replacement ICs at the following link with free shipping and free instalation instructions with pictures.
Jul 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Color Fading
check your menu settings if not there then you may require board level service.or eprom sub menu adjustment.
Dec 02, 2006 | Panasonic PT-47WX42 47" Rear Projection...
Televison & Video Logo
207 people viewed this question
Top Televison & Video Experts
Electro Med Services...
