Question about Garden
HAVE A DEWALT PRESSURE WASHER WITH 6.5 HONDA ENGINE THAT WAS STORED FOR A COUPLE OF YEARS. IT WILL START BUT ONLY RUN FOR3-4 SECONDS WITH CHOKE ON THEN KILLS. WAIT A MINUTE OR SO, PULL ROPE AND WILL RUN FOR ANOTHER 3-4 SECONDS. WON'T RUN CONTINUOUSLY. PUT FRESH GAS AND CLEANED BOWL UNDER CARB. ANY OTHER TIPS? THANKS, FOREST
    Brigadier General:
  • 4,088 Answers
Look for plugged filter anywhere in fuel line.
Posted on Jul 23, 2009
Dewalt DPD3800 pressure washer starts and runs fine. After 5-10 minutes of washing the engine quits. It will not start until it cools. The engine will start after a 10 minute cool down. It will run and...
I have the exact same pressure washer and have had the same issues with it. The cure for me was to simply run the washer with the gas cap loose. For some reason the fuel gets vacuume locked and stops flowing into the carb. The fuller the tank is it seems the shorter the time is between the time it starts and the time it shuts off. Or you might find a way to vent the cap. Hope this helps.
Jun 06, 2011 | Dewalt 3800 PSI Pressure Washer
My pressure washer is 3 years old, never had a problem with it until now. It runs for 2 seconds only on choke. It will not start or turnover at all with out the choke on. Please help, I miss my...
It sounds like could be one of the problems listed below or a combination of those things.
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. High-speed exhaust air must pass freely. We finally broke the exhaust screen out with a screwdriver to get our machine going one day.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas ... and then put in fresh gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Buy some gum out, and then don't store power washer with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle, and then start it each time using WD-40 as described below.
5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way onto the spark plug?
Now the nitty gritty of starting that bad boy and making you happy again!!!!
7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week. Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed.
Once it starts, keep spraying WD-40 directly into carburetor to keep engine going.
If engine will not fire and keep going on WD-40, then your spark is suspect.
If your engine fires and runs on WD-40 but dies without it, then your gas supply or carburetor are suspect
8) Carburetor problem >>> try Gum out >>> and then take machine to small engine repair shop
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal. If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
Let us know how it comes out!!
Oct 15, 2010 | Honda Black Max 2600 PSI Pressure Washer
I lost my manual ,how to start the pressure washer
Check gas and oil. With water OFF, pull out choke on washer. Pull the start cord until it starts. Let run for about 20 seconds. Push in choke. Turn on water. Bleed wand line. Insert desired tip. You should be good to go now.
Oct 08, 2010 | Honda Pressure Washer PSI 3000
190 honda engine only runs on choke?
pour a large amount of carburator cleaner into the gas tank
run the engine for five minutes then shut it off and let it sit for a couple of days.
then start it and see if it runs any better
the longer you let it sit with the carb cleaner in it, the better it should run
Aug 08, 2010 | Honda 50 W Ar Pump 2500 Psi 25 Gpm...
Honda GX390 engine on Citation pressure washer: less than 50 hrs on pressure washer worked fine last year and was winterized all start settings correct; had to use starter fluid to start this year and...
Did winterising the engine include pouring lots of oil into the intake of the running engine until it choked and died? That is the classic method of winterising...
Heavy blue smoke is burning oil.
I expect the spark plug fouled in those few seconds. After winterising the spark plug usually needs cleaning several times before there is a reliable start and continued running.
Sep 28, 2017 | Motorcycles
I have an Excell model XR2600 pressure washer that will not start. I have had it stored for 3 years. I drained the gas tank and carb and put in fresh gas. Is there a fuel shutoff on this model ? It has a...
If it's been sitting for 3 years most likely the carb is gummed up. If it's getting spark, you could try a small shot of starting fluid into the carb. If it runs on this you know it's a fuel problem. Best bet would get all the MOTOR data, and buy a carb kit from you local lawn and garden equipment parts supplier. . Remove carburator and clean and install kit. Use sta-bil when you put it away next time, but even that only works about a year or so.
Jul 05, 2010 | Karcher 2500 PSI Pressure Washer
New Karcher pressure washer won't start
replace the fuel carburetor filter and, or, your fuel tank filter
Aug 31, 2009 | Karcher 2500 PSI Pressure Washer
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
228 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
