My screen resolution is stock at 640x480 and i cant adjust it.. how will i adjust my resolution to fit my monitor.. and when i open my cam its getting darker and all the pictures even in friendster or other site.. pls help me pls... i need ur help.. what will i do and what will i download...
    President:
  • 987 Answers
you have to install the graphics driver first ..you can find it on motherboard's website ...
thank u ... for using fixya ...
Posted on Jul 23, 2009
    President:
  • 1,383 Answers
Install graphic driver .
If already installed then uninstall old driver then install again.
when you power up the computer pressF8 key then enter in enable vga mode then change screen resolution to 1024*768 then aply and ok
Monitor w2261vt
Make sure that your software, that you view your pictures with, falls into the 'box format' of 640x480, 1024x768, 1280x1024, etc. Background pictures are typically streched to fit the wider screens. You can change that by right clicking on your desktop.. in XP it is the 2nd tab, on the right side, you can choose stretch or ? Some will give you black bars but no skewing. Then you can adjust your monitor's resolution downward to enlarge your pictures, or leave it at a higher resolution if you don't mind the borders. -DellTech1
Oct 31, 2013 | LG Computers & Internet
Screen in two parts, just during boot
Don't worry about it. During boot time, the input to the monitor is set to a different resolution (640X480 for plain text). The monitor remembers settings for different resolution inputs, and the position is wrong but it's not a monitor problem as such. You could adjust the position and the display would be properly centered, but it's not worth the effort. Once the system starts Windows and the resolution switches to your normal settings, the display looks right. Once in Windows, you can't even set the resolution low enough to adjust the monitor; Windows won't go below 800X600 pixels.
Feb 06, 2011 | HP Pavilion F1703 17" LCD Monitor
Pop up of monitor adjust screen
Hi, you probably have to set the correct resolution that fits on your monitor. The correct resolution is: 1920x1200 You can set it by right-clicking on your desktop and choosing "Screen Resolution" in Windows Vista and Windows 7. If you use Windows XP, right-click on your desktop and choose "Properties" Then open the rightmost tab to choose the resolution
Jul 19, 2010 | CTL 261UW 26Inch Wide Screen LCD Monitor...
How to get 1200 X800 resolution
It depends upon the notebook you use if it support the resoulution you want. You can change the resolution by display properties in control panel. Also 1280*800 is used only by widescreen desktop or laptops.
Mar 24, 2010 | Compaq Presario 700 470024-192 Notebook
I cant fit the whole image on the screen. The options to adjust only allow me to adjust the width...it wont let me show both the top of my windows open AND the start button.
Your resolution may be set to high on the computer. Or you have a standard screen resolution set and since the monitor is a wide screen, it is cutting it off.
Try a different resolution 1440x900 is what the va1930wm uses.
If using a laptop with a standard type screen on it, you may have to set the laptop to just light the monitor to allow this setting to take.
Since this monitor is a wide screen, it may have options in the menu to stretch or zoom on an image if the resolution is not set to a wide screen format.
Dec 03, 2009 | ViewSonic VA1930WM LCD Monitor
Images Stretched
go into control panel/display and check your resolution. It sounds like the resolution may need to be changed. You can try 640X480 or 600X800 and see if that makes a difference for you.
Aug 11, 2009 | Acer X191WSD Monitor
Cyberlink youcam
got to your desktop and right click then choose personalize then go down and click display settings then choose the highest resolution
Nov 15, 2008 | Computers & Internet
Monitor color display problem
Go to the control panel. Click on display. The display applet is your next stop. The display applet is your central location for all of your display settings, including resolution, refresh rate, driver info., and color depth. The display applet has 5 tabs: Thmes, Desktop, Screen Saver, Appearance, and Settings. The 5th tab is where you make adjustments that relate directly to your monitor and video card. Look at the Settings tab. At the bottom of the dialog box, you'll see 2 options. Screen Resolution and Color Quality. By moving the Screen Resolution slider, you can change the resolution. The most common resolutions are 640x480, 800x600, 1,024x768, and 1,280x1,024.Your system may have more or fewer resolution options.
The color quality is the number of colors displayed on the screen .You can change the screen resolution with a simple slider and adjust the color depth from 4-bit all the way up to 32-bit color.
Running a 32-bit color gives a nice, realistic tone to images, and many games insist on it.
Clicking the Advance button opens another dialog box with 4 or more tabs.
The monitor tab gives you details about the currently installed monitor and enables you to make changes to the driver and the refresh rate.
After you make your changes to your monitor and it still is not working properly, it must be your video card which is not seated.
In layman term, your video card is not plugged in firmly in the slot!!
Jul 11, 2008 | Acer X193W LCD Monitor
Computers & Internet Logo
165 people viewed this question
David Payne
David Payne
