Question about Electrolux Washing Machines
I have an electrolux 22S750, I have just replaced the upper and lower bearings and the tub seal, the action was ok with just water in the machine, with the first load the adgitator hardly moves,what have I done wrong.
jsrock516
  • 5911 Answers
SOURCE: kenmore elite HE4T front load washing machine standing water
This problem can be caused by either a leaking water inlet valve, or a condition known as "siphoning". Since you just recently moved, I would make sure you don't have a siphoning problem, first. The following link explains how:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although siphoning normally refers to a constant drain problem where a washer has problems maintaining the proper water level, it can also lead to problems where the drain line will back up into the washer.
Now, if you follow the advice in the link and determine this is NOT caused by siphoning, I would suspect that you have a water inlet valve that is leaking. A tell-tale sign will be water trickling down the fill tube in the rubber door bellow. The water inlet valves have a diaphragm that is controlled by an electric solenoid. Sometimes the valve becomes clogged with sediment or deposits, causing the diaphragm not to close properly. If you live in an area that has hard water, or use well water, you may have hard water deposits or rust build up in the valve. You may be able to correct the problem by removing the valve and cleaning it with some distilled vinegar. You can remove the valve by following these steps:
1. Unplug the washer and turn off water supply at the taps.
2. Disconnect the water inlet hoses.
3. Remove washer top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel slides back, then off.
4. The inlet valve (this is what your water inlet hoses connect to) will be located in the left rear of the washer (facing from the front). Remove the dispenser hose(s) from the valve and the electric connections. Remember how the electrical connections are removed. They should be color coded. One is for HOT, one is for COLD.
5. Remove the mounting screws that hold the assembly in place.
Once you have the inlet valve removed, you can place it in some distilled vinegar and let it soak. Just don't submerge the electrical connections. If this does not correct your problem, replace the valve. Searspartsdirect.com and repairclinic.com are two notable web sites that I have frequently used. Just type in your complete model number to begin the parts search.
I hope you find this information helpful. Let me know if you require additional assistance.
Posted on Sep 02, 2008
  • 1462 Answers
SOURCE: How do I remove the
whine could also be from motor bearings and also from motor brushes. leak is not necessarily due to bearings. to help localise leak, put a sheet of newspaper under machine when in cycle and this will give you a good idea where leak is.
Posted on Sep 29, 2008
SOURCE: Outer tub bearings are gone
My bearings went out too and I found this site http://www.neptunebearing.com/ Ordered the bearings and the Tony Tool. My son and I replaced the bearings in about 2 hours!
Posted on Apr 03, 2009
  • 8 Answers
SOURCE: VERY LOUD GRINDING NOISE LG WM-2277HW Front Load Washer
Get a new washer. Perhaps another brand.
The fix for me was to get a new washer. Had same issue with loud spin cycle. Tried researching while wife was continuing use of washer. Then the LE message appeared.
Took back apart and found that water had leaked and caused a boat load of damage. Bearings shot, seal leaks, drum leaks, Stator damaged. Same issue as 'jammy64' stated.
Cost to repair wasn't worth it. Going to get an
Electrolux model.
Posted on Sep 29, 2009
  • 4 Answers
SOURCE: I think my Maytag MAV6200AWW washer has a bad tub seal & bearing
if you have had this unit for over 5 years Then it is TOTALLY NOT worth the repair - if it is only a year or 2 old then call MAYTAG and they may offer a parts/labor concession. average life is 5-10 years now as sucky as that is!!
Posted on Nov 02, 2009
Why does the lower tub bearing leak?
the rubber hoses from the tub to the pump, the pump itself are cause for leaks
the rubber hose is normally an accordion style that perishes in the ridges and the pump seal is a simple seal that will leak over time
it may be the tub shaft seal as that would account for leaking more when full as the water will be bypassing the seal into the gear box and out the bleed hole
Jun 23, 2015 | Maytag Washing Machines
Amana dlw330ra, loud and leaking
HI,
Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only If the washer leaks only during the fill cycle, check these:
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Aug 11, 2008 | Amana DLW330RA Top Load Washer
Leak in front
see this steps and fix it. God bless you
Drain Pump
If the washer is leaking water the drain pump might have a hole or crack. Or, the bearings might be worn out. Replace the drain pump if it is leaking water, they're not repairable.
Enter your model number to see parts for your washing machine.
Help me find my model number
Tub Seal and Bearing Kit
If the washer is leaking water the tub seal and bearing might have a tear or rip and is letting water leak past. The tub seal and bearing can be replaced. This is common and relatively easy to replace.
Tub Seal Kit
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. The tub bearing often gets damaged when the seal leaks. consider replacing the tub bearing along with the tub seal.
Tub Spin Seal
If the washer is leaking water the tub spin seal might have a tear or rip and is letting water leak past. The tub spin seal can be replaced. This is common and relatively easy to replace.
Tub Seal
If the washer is leaking water the tub seal might have a tear or rip and is letting water leak past. The tub seal can be replaced. When the tub seal fails water gets into the tub bearings and usually causes the bearings to go bad also. It is a good idea to replace the tub bearings with the new tub seal.
Door Boot Seal
If the washer is leaking water the front door boot seal might have a tear or rip and is letting water leak past. The boot seal can be replaced. This part can tear when the washer is overloaded. This is common repair.
Tub to Pump Hose
If the washer is leaking water the hose from the tub to the pump might be split or torn. Don't try to cut off the bad piece of hose and stretch it to fit the pump, this will put strain on the remainder of the hose and may cause a sudden and complete failure of the hose which will dump potentially hundreds or thousands of gallons of water onto the floor because the next time the washer tries to fill all of the water will end up on the floor and so the washer will never shut off the valve. Any time there is a damaged hose, replace it completely with the OEM part.
Washing Machine Fill Hose
If the washer is leaking water, check the fill hoses on the back of the washer, this is the most common place for water to leak. If the washer still has the original black rubber fill hoses replace them with stainless steel or some other, more durable hose.
Drain Hose
If the washer is leaking water check the drain hose. The most common places for the hose to spring a leak is from the connection to the pump out to the back of the washer. Another common occurrence is when the washer gets pushed too far back against the wall.
Jul 09, 2013 | Bosch Nexxt Platinum WFMC640SUC
How to change the bottom spin bearing?
Two bearings in that model One in tub will be leaking water if bad. One on the lower end of transmission.which is part of the transmission. Whole tub basket unit must be removed from the case to replace either the tub bearing and seal or the transmission.
Nov 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
I have a load squeaky sound on my FAV6800AWW washer. THe machine spin but when is starts agitating, the sqeaky sound can be heard.
This could be the start of Outer Tub Bearing issue.
Raise the lid of your washer and rotate the wash basket CCW as fast as you can. Does is spin down slowly to a gentle stop after several revolutions with no bearing noise?
The Service Manual for reference. Sears Parts Direct for reference.
I would by removing the Clutch Pulley and check for One-Way Roller clutches bearing wash water contamination. That will give you a feel for the integrity of the Tub Seal. See my Clutch Fix post for support.
If this is Outer Tub Bearing noise you will have to replace them along with the Tub Seal and Tranny O-ring. The Series 16 machine (I have that one also doesn’t use the upper Clutch bearing ring. That upper One-Way Roller clutches bearing is integrated into one of the Outer Tub bearings.
See this post. This guy bothered me for his statement that I left him hanging. I’m a DIY’er not a appliance tech and most AT’s won’t touch this with a 10 foot poll due to lack of knowledge. I did replace the Outer Tub bearings on a ebay win Series 10 machine. See this post for the details of that.
Don’t get too excited by any of this. 1st determine if the squeaky noise is Outer Tub bearing noise I haven’t had them fail yet but I would suspect you will hear metal against metal grinding of the ball bearings in the bearing race. There will be down time for the tear down and work. You need to determine if this is worth it for your situation. No more than a $85 to replace Outer Tub bearings tub seal tranny o-ring and buy Maytag Spinner Nut removal tool for reassembly and you extend the service life of your $1K machine.
If you want to DIY further let me know……Rich
Jun 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I've recently done the roller bearing fix on my FAV6800AWW, now..
cysloane
You have a Tub Seal leak for sure. Did your Clutch Pulley use the upper bearing ring? If you don’t have any Outer Tub bearing noise you may get around replacing the Outer Tub Bearings.
Take a look at these links and see if they will help. Getting the Spinner Assembly removed without breaking one off requires care. Soak in Liquid Wrench or PB Blaster. Even after doing that I broke one off. I had the bolt hole drilled out and Stainless Steel Helicoil inserted in.
Here is the process for a Series 10 machine I did a tub seal replacement on. If you follow my post I’m a DIY’er with basic mech. skill sets. I’m a Electronic Technician by training and and learned craft skills. I feel you can do this if you felt OK with my Clutch Maintenance/Replacement post.
I would replace both the Tub seal and the Tranny O ring seal.
I used an air impact tool to remove the Spinner Bolts and the 1.75” Spinner Nut. You might be able to get away from using the Spinner Nut removal tool if you lock the Spinner Assembly as shown on page 47 in the SM.
See this post for links on Tub Seal and Outer Tub bearing replacement.
Good luck and I feel you can do this. I’m no expert but will try to help you……..Rich
May 20, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Water keeps getting into my bearing.
I feel you have a Tub Seal leak.
Did you replace the Clutch Pulley or a repair service?
You are talking about the Clutch Pulley One-Way Roller Clutch bearing in the white bearring plate correct? The First two digits of your serial number are 12 thru 17. What are the first two digits of your serial number?
To replace the Tub Seal you need to remove the spinner assembly. That means you have to remove the outer tub. A bigger job but several on this forum have completed it including myself two weeks ago on a Series 10 FAV6800A.
I will point you to a link most recently where a form member replaced Outer tub bearings on his Series 15. If your wash basket spins up to 850 rpm with no Outer Tub bearing noise I would just do a tub seal replacement this round.
You would need the Tub seal see Sears Parts Direct. I would also pick up the Tranny O-ring seal (series 10) .
Some links on Outer Tub Bearing replacement.
http://www.fixya.com/support/t3973659-fav6800aw_sn_15_top_loader_r_nunit
http://www.fixya.com/support/t4028403-just_replaced_new_clutch_fav9800aww
If you replace the tub seal make sure you remove this sleeve that will more than likely stay on the Spinner Support when you remove. See Page 49 of the Service Manual. Here is a real world pic of the sleeve on the Spinner Assembly.
I did break off a Spinner Bolt even after heavy soaking in Liquid Wrench be careful;
There should be six there oops!
Good luck and post back if I can help.....Rich
Apr 16, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Amana lw8203w leaking
Your LW8203W is at least 12 years old. It is leaking from the tub seal, Your machine needs to be rebuilt or replaced.
If you have it rebuilt I would also put in a new belt, pump, brake pads, upper tub bearing and the tub seal it needs.
Call and authorized Speed Queen or Amana dealership and ask for a price quote over the phone. Then price out a new machine.
Your choice.
Jul 05, 2008 | Washing Machines
Electrolux model.
May 19, 2008 | LG WM-2277HW Front Load Washer
Leaking water from underneath.
sounds like several problems. sounds like your boot stem/ seal is leaking and possibly the tub bearing is rusted. I generally replace both at the same time as long as the machine is apart anyway. As for the squealing and tub slamming to a stop, that is your brake package and bearing have dried and/or rusted and need to be replaced
Dec 25, 2007 | Maytag Ensignia 3.3 cu. ft. Top Load...
Washing Machines Logo
70 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
