Question about Ricoh Office Equipment & Supplies
Need to change the Waste Toner Bottle on Ricoh FW870
The Operating Instruction manual does not include how to change the waste toner bottle. The manual says to call the service rep, and we do not have a contract. Could someone help me with this issue??
  • ashleykate7 Jul 23, 2009
    This is a large plat printer. There are only doors on the front of the machine that open down. There are no access doors that open on the right. You may be reffering to another model. Thank you for your assistance.
  • Ricoh Expert
  • 393 Answers
Depends on the model, if you open the right door as to remove a jam does it have a brown 4 or so inch belt on the door you opened? If it does the lite grey lever on the front side lift up to tpo and lift out assy. Take off the 2 springs and release the tab so as to lift the brown belt portion off dump the toner out of assy and reassemble. -Carl
Posted on Jul 23, 2009
Message the toner bottle is full please call the server machine printing rico 4500
The bottle full message indicates that the waste toner collection bottle is full. The full bottle needs to be removed and the toner disposed of properly. Then a replacement collection bottle needs to be installed and the waste toner counter reset. This site has the toner bottle: http://www.precisionroller.com/waste-toner-containers-for-ricoh-aficio-mp-c4500/details_47769.html . It is possible to reuse the bottles but most people will spill the toner when they try to empty a collection bottle. You do not want loose toner in your environment.
Turn off the printer (at the power switch) and wait for the lights to stop blinking before attempting the replacement. See page 62 of the network guide for the replacement procedure. See https://www.ricoh-usa.com/downloads/downloads.aspx to search for your printer and get the manuals.
I hope this helps
Jul 06, 2015 | Office Equipment & Supplies
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
WASTE TONER IS FULL ERROR
You have to empty out the waste toner bottle... The bottle is a milky white plastic and I believe it is right under the fuser unit. It should slid out toward you. Carefully dump the toner out of the bottle into a plastic garbage bag and re install the bottle and you are done....
Dec 07, 2012 | Ricoh 4506 Copier
I have a ricoh aficio MPC2050 copier V2295900860 and it is saying that the waste toner bottle is full and needs to changed how do i do this and where is the waste toner bottle located.
Hello!
Your machine have 2 waste bottles.
The bottle 1 is placed in the front door. (See the picture). You can empty it or replace it.
(is less expencive to empty it)
The secund waste bottle is in the left. See this picture
Now, you just need to make sure what waste bottle is mentioned in the display.
Hope this helps
Sep 12, 2011 | Ricoh Aficio 450 Copier
We have a Ricoh Aficio CL3500N and are getting an error stating: "Used toner is almost full." No manual to refer to. Thank you!!
Hi there, You can just empty the waste toner bottle. here is what you need to do. Here is also a manual for your machine http://support.ricoh.com/bb_v1oi/html/oi/re/model/cl3500/cl3500en.htm Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Regards,
Jul 27, 2011 | Ricoh Aficio CL3500N Laser Printer
I'VE BEEN STRUGGLING FOR MONTHS NOW I CANNOT FIND THE WASTE TONER BOTTLE FOR NASHUA RICOH SPC232 SF
Please have a look at the attached image to see where to look inside the Ricoh printer for the waste toner bottle.
You have to remove the transfer unit before you take out the waste toner bottle, as per image.
Dec 06, 2010 | Ricoh Aficio SPC232SF All-In-One Laser...
How do I replace the waste toner?
The waste toner bottle is just a bottle that the old unused toner falls into. It is located on the right side of your printer. Open the right side door, and the waste toner bottle (which is wide and flat) is in plain view taking up the bottom half of view. It has a sliding lock on top. Slide the lock to 'unlock' and remove it. Replacing it is easy - just reverse and make sure to lock.
Jul 30, 2009 | Ricoh Aficio CL2000N Laser Printer
I need to empty or repalce the used toner bottle
Hello sir; You may open side door, you will find out a retangle plastic box that is the waste toner bottle, on the top of waste toner bottle have a green knob, just slide it to right, you can remved it and dump it out.
May 18, 2009 | Ricoh Aficio CL3500N Laser Printer
How do I change the waste toner bottle for a ricoh sp c410?
Drill a 3/4" hole in lower left side of waste toner bottle. Waste toner is very fine and will get all over the place – you also may want a breathing mask. Take outside and dump waste in large ziplock bag and dispose properly. Put a large piece of shipping tape and cover hole. Put back into ricoh c410. This wi;; save you about $50 and less plastic in our landfills. SG
Jan 13, 2009 | Ricoh Aficio SP C410DN Laser Printer
223 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
