Channel master model 9510A need wiring help
The control has 3 posts marked 1 2 3 I have red black and white wires but no idea where each goes I guess I can try the various combinations but would like to get it right the first time anyone know how it should hook up?
3 Suggested Answers
SOURCE: Wire hook up for Channel Master 9510A
wireing for channel master 9510
Posted on Mar 23, 2009
SOURCE: We need to reattach the wires to the Channel
Can't wait around for your response, so I kept looking on the web until I found a users manual that showed how to connect the wirew.
Thanks anyway.
mt
Posted on Sep 13, 2009
Replacing Pool pump motor
Which control panel?
White can be Com, and Black Lo, and Red/Blue Hi
But this is guessing without knowing control panel wiring.
For example T106 timer. Wires can be any color.
http://waterheatertimer.org/images/T-106-control-208-277V-4-40.jpg
High connects to terminal 4
Low connects to terminal 1
Com connects to terminal A
Apr 16, 2013 | Pool & Spa
How do I change the electric wire in a franklin ground water pump from 230v to 115v? I purchased a Red Lion 3/4 hp convertible ground water pump but must change the power and wiring from the pumps...
You have 4 wires coming out of the fuse box , one white , one bare, one black, one red, right? The fuse is a double pole, 220 volt, ?30?amp, guessing, and you are now wiring up to a 110 volt, motor which needs 20 amps, so, remove one wire from the breaker, red or black, shut it off first, pull the wire off, tape it and mark it what it was. leave the red wire on there, or the black, it doesn't matter, Now you have one hot, one ground, one neutral, hook them up to the pump, the box on the pump has screws, one silver, one brass, the brass is always hot, the colored wires are always hot, The silver screw is neutral, the white is neutral, always, and the ground wire goes to the ground screw, maybe outside of the box. You should be all set, tape off the old colored wire you didn't use and mark it . You might need it someday. Hope this helps.
May 31, 2010 | Plumbing
I screwed up and did not label the wires when I took off the alternator on mt 1973 Mustang Mach 1 351C. I know where the orange wire goes, but the others(s) I'm clueless. Thanks
Red goes to the threade post,main output marked"batt".Orange and blue go to the post marked "feild",closest to the rear bearing.The white and black go to the post marked"sta" or stator.If there is a ground or all black wire it goes to one of the posts on the back of the alt that has no plastic insulater.Let me know if you need more help.
Nov 13, 2009 | Ford Mustang Cars & Trucks
We need to reattach the wires to the Channel Master 9510A unit but are unsure which color goes to which post. We have a red, white and black on the tip wires. Can you help?
Thanks anyway.
mt
Sep 12, 2009 | Channel Master Televison & Video
Sensors
I think someone has used wiring that didn't come with the opener. One the rear of the motor unit are wiring terminals. The sensors connect to terminals 2 and 3. Whichever color wire is connected to terminal 2 goes to the screw marked white and the wire on terminal 3 goes to the screw marked black. This information is if you have a Craftsman or Chamberlain opener.
Sep 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
On outside compressor for whole house AC: Critters ate wires. Have Blk & Red power in from breaker. 24vac switched from thermostat. 1 contactor with 24vac coil(original). 1 Capacitor w/ 3 terms...
There should be a wiring diagram on the back of the access panel. If you can't read it, check online for model wiring diagram. Don't guess, you may cause more expensive damage.
Jun 25, 2009 | Heating & Cooling
I NED TO CONECT 3-1 RELAY OVERLOAD CAPACITOR IN MI FRIDGE
first take all the relays and capacitor off of compressor , then attach black wire with terminal on "C" terminal post usually top terminal, white wire with terminal goes on "S" terminal post on compressor, red wire with terminal goes on "R" terminal post on compressor. then take the two black wires one connects to white neutral wire and the other connects to the black power wire if tis fridge has a condensor fan then you will also need to connect it two the two black wires also thanks hope this helps
Jan 23, 2009 | Kenmore 50522 / 50524 Side by Side...
Jan 17, 2009 | Televison & Video
Basic wiring for craftman garage door opener
from left to right..
1. red. to wall button
2. white . common to wall button and white wires of sensor.
3. black. white with black strip of sensors
Jul 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
Televison & Video Logo
773 people viewed this question
Top Televison & Video Experts
Electro Med Services...
