Question about Electrical Supplies
I have a eu3000 overload safety shuts it down at about 1100 watts
I have a eu3000 it has an overload safety shut down on it, and is shutting down at about 1100 watts or 9 amps. It will start and run the a/c, on start up the a/c pulls about 3300 watts and 28 amps then runs at about 1100 watts and 9 amps, and runs for about 10 minutes and shuts down. Any ideas?
  • rockyharrima Jul 23, 2009
    The volts are right at about 119-121v
    with an inductive amp clamp and ammeter
    President:
  • 1,723 Answers
Can you verify the amp draw on the output? This gen should handle 25 amps continuous. I wonder if you actually have a bit more that 9 amps? It would be nice to check the frequency and volts too...A Fluke multi-meter can read these values.
Posted on Jul 23, 2009
  • Craig Butler
    Craig Butler Jul 23, 2009
    How were you able to obtain the 9 amp value that you mentioned?
  • Craig Butler
    Great! That's valid. Your overload is an invalid shut down. At least it's not a 'current overload is what I mean. In order to diagnose it further, we will need to know from Honda, (or the manual), what does a 'safety overload' consist of. I do not have that information right now. You can call :1-770-497-6400
Dometic AC B59516.711 15,000 BTU, while on generator power the AC works during day while it hot but once the sunsets and it cools down, compressor kicks on it drags the gen down and shuts it off.
something else besides the ac is stopping ( overloading) the genset
if it works well during the day, the compressor has to be working so the ac is not the problem
a 4000 watt gen set has a duty cycle load of around 3000 watts full time so any additional power requirement besides the ac will overload it
electric stoves , microwave ovens , hot water elements , anything that consumes power after dark will when combined with the ac will overload and shut down the gen-set
Jun 26, 2017 | Electrical Supplies
My GE stainless steel 1100 watt microwave starts beeping out of the blue and the display panel shuts off and when I open the door it resets itself and then starts to beep when I close the door again.
Try removing the power cord for about a minute, push all the touch pad 'buttons' and then plug it back in. If this doesn't work it sounds like you may have a bad door interlock switch or a bad PCM .. Good luck !
Feb 11, 2015 | GE XL1800 1100 Watts Microwave Oven
My microwave came on by itself and will not shut off
Be sure to unplug it ASAP to shut it down. These things are expensive to fix, I'd buy a new one.
Aug 21, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
My Pc just shut down while i was playing a game. i unplugged my geforce 9600 gt's power and my pc worked again, but without graphics. what is wrong with my graphics card???
The problem that caused the PC to shut off is the GForce graphics card is drawing too much power and the switch mode power supply was overloaded and shut down.
Check the switch mode power supply's wattage, if it is around 300 to 400 watts, it maybe be too low. You most likely need to get a higher wattage switch mode power supply, especially if you added more RAM, disk drives, DVD drives etc. to your PC after the initial purchase of the PC.
Feb 12, 2010 | BFG Technologies NVIDIA GeForce 9600 GT OC...
Maytag electric dryer keeps shutting off.Dryer gets hot. Repairman replaced the motor but still having the same problem.Could it be a sensor?
Generally if the motor shuts off it is because of the overprotector on the motor opening up to save the motor.When the motor cools down the overload will close and the motor will work again.
If the unit is getting so warm the motor is shutting off check to make sure the rollers are working properly and moving freely.
Sep 15, 2009 | Dryers
6500 watt diesil generator /as soon as i put any
if by fliping the breaker it shuts off..that means there is a short circuiting in the breaker..try connecting your house,shop..etc..directly ...
that is if the shut off reason is overloading...if not please explaing with details
Aug 23, 2009 | Electrical Supplies
Microwave shuts down when hot
Most microwaves have a temp sensor or moisture sensor. Maybe your one has gone faulty or the magnetron itself is causing it to shutdown. Get it checked up.
May 12, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Malibu transformer shuts down early
Well, you're overloading the transformer by 30 watts. It's doing what it's supposed to do when overloaded...shut down. It's the _other_ (works fine) transformer that you should worry about possibly starting a fire, since it's not shutting down when overloaded.
Mar 09, 2009 | Intermatic Malibu 121W Power Pack...
Turns off when i turn it up
Does it power back up after it shuts down, if it does power back up it is unlikely it is an internal fuse, you would need to replace the fuse if that was the issue, could be an amplifier overload, check the demand your speakers require in watts, and be sure the right ohm speakers are being used, many receiver will display "overload protection"and shut down, and some just un-power to prevent a electical short from occuring.
Feb 02, 2009 | KLH R3100 Receiver
Electrical Supplies Logo
222 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
