SOURCE: Canon PowerShot SD630 LENS WONT CLOSE,LENS ERROR RESTART CAMERA
I have the same problem. How do you restart the camera. I have pulled the battery and SD card, but can't get to a menu screen to restart to camera.
SOURCE: Powershot A560
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
SOURCE: camera shuts off after E18 error code
You have most likely dropped the camera or banged it against something while the lens was out. This situation causes the brass pinion gear to shear teeth off the plastic ring gear on the Inner Lens Housing. It may also cause the guide pins to jump their track. If this is the case the repair bill usually exceeds the value of the camera and you are probably better off selling it for parts on eBay and getting a new higher resolution camera.
SOURCE: Canon PowerShot SD780 IS camera lens error. :(...
I did the same thing and it works only be restarting it now but it works lol. I threw it agianst my bed . SO BEAT THE **** OUT OF YOUR CAMERA..then restart and it should work..*** made **** what can you say
SOURCE: lens error, restart camera canon powershot
The best thing to do is to first try restarting the camera. Do not push or pull on the lens as this will often cause other issues. Do not blow air in the lens as this generally moves any dirt or dust to the back and it sits on your imaging sensor, you'll end up with poor photos after that. The best thing to do is to have it serviced so it is fixed correctly and working the way it should be. The site that is great for the Powershot Models is: www.CamerasAndParts.com They only specialize in these Powershots and they have your exact lens error problem right on the site. Try them for help. They tend to be the best deal plus they're service is wonderful. You'll pay $89 for the repair, all of the service for that model and the return shipping back to you included with them. They'd be the place for help with this one, best of luck.
