Question about Sharp AL-1540CS All-In-One Laser Printer
Scanner won't work. I have a Sharp AL1540cs
Can't find installation CDs. Have used device only as a copier for years. Now I want to use the scanner.
Ron
    President:
  • 744 Answers
Hello you can get a copy of the software you require at the following website: http://www.sharpusa.com/products/TypeSoftware/0,1086,20,00.html Hope this helps :)
Posted on Jul 23, 2009
Tip
Sharp AL Series Copier L1 L-1 Error Code Cause and Solution
L1 or L1-00 indicates Scanner movement failure. The scanner is the part under the glass that lights up and moves back and forth. So if you lift up the feeder so you can see the glass, turn the machine off for a few seconds then back on. Watch the movement of the scanner. It should move right and inch or two then back to the left. If all goes well the copier should come to ready. Lay a piece of paper on the glass and press the print button to watch the scanner movement. If it binds up or does not scan correctly there are 2 possibilities.
1) your scanner lock is engaged and is preventing the scanner from moving. Check the clear plastic dial located under the far left upper side of the copier, near where the paper exits the machine. Make sure it is in the unlocked position.
2) Your scanner rail is dirty and dry. This rail can be seen under the glass towards the back of the copier. The scanner rides on this rail. It is very common for these to get dirty and for the grease to dry up causing the scanner to freeze up on the rail. The glass must be removed and the rail cleaned and lubricated.
Just power off then on the copier to reset.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Mar 20, 2010 | Office Equipment & Supplies
Tip
Sharp AL Series Copier L3 L 3 code meaning and solution
Good Luck and thank you for using Fixya
on Mar 16, 2010 | Office Equipment & Supplies
Hello am using sharp ar165 m copier machine .and am installing my pc also but scaner is not working please help me.
How are you doing? In order for scanner to work in all multi-functional printers, you must install all functions. While installing printer Sharp Ar165m, it will ask you if you need to install scanner and you must select that box otherwise it will install printer alone. Also there is an option where you are to configure the button keys on scanner function, please configure the buttons while installing. This will allow you to press scanner key on the copier to start scanning without necessarily selecting from the computer otherwise --- will appear and nothing happens. So insert the software CD and remember to select scanning option.
Dec 15, 2010 | Sharp Office Equipment & Supplies
Sharp AL-1217 Driver for Windows Vista
try the driver for AR123E at
http://www.sumthai.com/s0104/index.php?tpid=0086&pageno=1
it covers
Supported Models AR-123E, AL1045, AL1216, AL1225, AL1255, AL1530CS, AL1540CS, AL1456
Aug 21, 2009 | Sharp AL-1217 Copier
What is error code E-7 for Sharp copier AL1540CS
Hi Dave,
E7 means that the lamp under the glass is not working.The most common cause is a blown fuse that sits right beind the lamp.If you can test the fuse and take it from there.
Jun 18, 2009 | Sharp AL-1540CS All-In-One Laser Printer
Halkawt_07@yahoo.com
 have a Sharp AL1540CS MFM. It has been displaying the H4 code for a while. Clearing it would work for a time. Removed the fuser assy., and cleaned the temp sensor. It had a wad of toner stuck to it. Cleared the code again, so far so good.
May 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
CAN'T INSTALL PRINTER TO MY COMPUTER -SHARP AL1540CS MODEL
if the people who did your computer didnt do a complete wipe and re-install then the printer driver is still there. try to hook up the printer and PC should pick up new hardware and reinstall the driver.
Mar 26, 2009 | Office Equipment & Supplies
Shapr AR-M205 and Sharp AR-123E Scanner cannot be installed in XP
I'm using XP Professional on my computers. I don't know what happened but what i can remember is that i kept uninstalling and installing the sharp AR-123E and yesterday, it was finally installed.
i only have one problem now, the AR-M205. I've been doing same procedure as above for almost 3 weeks now but no luck.
Nov 22, 2008 | Sharp AR-M205 Copier
Al1540cs problem
check the toner and cartiga
Sep 05, 2008 | Sharp Office Equipment & Supplies
Sharp AL-1540CS All-In-One Laser Printer Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
