Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Sound went out, tv turned off, red light flashing...
I have a Sony Wega and when I try to turn the TV on, it goes to green, the fan starts, then it clicks again (within a few seconds) and the red light (power/standby) starts flashing. I replaced the bulb around 8 mos. ago and haven't done anything since that would cause the lamp door to open, but I will check that first. Any other ideas?
  • 668 Answers
The Lamp being bad as well as one of the three fans in the unit not turning could also cause the problem.
Hope this helps,
Skyassoc
Posted on Jul 25, 2009
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
Sony 42in- No picture or sound
You need to replace the bulb...very easy. You can do it yourself.
Dec 23, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony FD Trinitron WEGA Standby Light Blinks, TV Does Not Turn On
Sony FD Trinition Wega KV-32HS510 Try to turn tv on -it starts then shuts off -stand by lights keeps flashing. Memory stick light flashes then goes off.
Nov 29, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
60 inch sony wega tv
Green flashing is normal. Red flashes are error codes. Count the error flashes.
3x - Lamp cover position or cover detect switch bad.
4x - One or more fans failed RPM test
5x - Lamp power supply/ballast failure
6x - Thermal fuse failed (usually)
Oct 16, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Jan 05, 2008 | Sony Grand WEGA KF-50WE620 Television
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
311 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
