Question about Western Digital MY BOOK HOME 1TB EXT HD-USB2/FW/E-SATA 3.5IN 1YR FireWire 400 Hard Drive
Wd 1tb not recognized in explorer but is noted in device manager
I have the same problem. one day i could see the hard drive in explorer and the next day i couldnt see it. i can see it in device manager and it says that everything is working fine. i have tried on both my lap and desk and still the same result. any information would be apprecriated
  • russell_eckh Jul 26, 2009
    First of all thank you for responding.
    I followed the steps listed above and located the disc.
    In the disc management it says the my WD drive is "unknown" and "not initialised".
    It is allocated disc 1 with the primary and recovery drive being alloocated as disc 0.
    When i attempt to initialise the disc i get a pop up box with "incorrect function".
    Then upon uplugging and resetting the drive and trying to initialise it came up with an error "the disc drive cannot find the sector requested".
    Any help or information would be appreciated.
    Thanks
  • russell_eckh Jul 28, 2009
    Mate thank you so much for your time and effort. Strange, but i think its just a damaged drive. The GetDataBackNTFS couldnt locate the drive either and according to WD the drive should be supplied a serial next to WD in the device listing. So as you said i got a RMA and i am sending it back to WD. Your troubleshooting technique was extremely helpful though and i learned quite a few things. once again, Thank You
    Novelist:
  • 81 Answers
One reason your external drive may not be showing up in explorer could be an issue with assigning the drive letter to the device. This normally happens when the device attempts to assign itself a drive letter that is already taken by another drive or a network mapping. Here is how you can quickly test if this is your issue:
WARNING: Double check the drive you are selecting before changing your drive letter. Accidently changing the drive letter of the wrong drive, such as the one holding you OS can cause your computer to stop booting.
1. With the device connected right click your “My Computer” icon.
2. From the menu select “Manage” which will load the computer management window.
3. Inside the computer management window select “Disk Management” from the left side of the screen under “Storage”.
4. After all your devices are scanned and loaded into the right side of the screen you will see the various drives and partitions connect to your computer.
5. Located the device you are having an issue with in the low section of the right screen panel and check to see if a drive letter is assigned to it. If you are unsure of what it should look like with a drive letter assigned observe your “Disk 0” device which normally is connected to the “C:” Drive letter.
6. Assuming there is no drive letter assigned to your problem drive, or the drive letter is already taken you can simply right click on the partition and select “Change Drive Letter and Paths”. The partition will be the part which lists the file system type and the size.
7. Once in the “Change Drive Letter and Paths” window click the “Add” button and then select a drive letter that is not in use and click “OK”.
8. After you have clicked OK/YES to all the dialog boxes your drive’s partition should now have a drive letter that you can access via explorer.
Posted on Jul 24, 2009
    Novelist:
  • 81 Answers
I am sorry to be the one to tell you this, but based on what you are saying your drive has either been corrupted or has failed. I would first try to recover any data you may have that is worth saving. I recommend GetDataBack which can be found at http://www.runtime.org/data-recovery-software.htm assuming you are working with NTFS GetDataBackNTFS is your best bet. This application will see your device as long as it is shown in device manager then attempt to scan every sector for data. Honestly, recovering data at this point is mostly a luck game. There are companies such as OnTrack that will recover data for you with near 100% success rate for a price.But, if the data is recoverable by software means odds are GetDataBack will save the day.
Ok... Now that you have your data recovered and or have decided it is worth losing you will need to confirm the status of the drive. This is simply done by downloading the drive diagnostic tools from Western Digital's site in the support section. From here you will find out if it is a hardware failure or a data corruption issue. If you run the diagnostics and the drive fails the test you will need to contact WD and attempt to RMA the drive. They are normally very good about this and it is a painless process that will net you a nice new working drive.
If the diagnostics software says your device passes both the short and long tests you have a data corruption. This can be caused by either a drive that will soon fail, a virus or some random fluke event that happened while it is writing data. You could attempt to run the disk check utility in you OS, but it VERY rarely fixes the problem. Instead I would say first go back to the Disk Manager I had you in before and delete all the partitions on your WD 1TB drive.
****WARNING****
Tripple check that you are deleting the correct partition or you WILL lose important data. Also, be sure you have recovered the data or called it a loss at this point. After this step it will be pretty much gone for good.
****WARNING****
Once you have deleted all the partitions you should eject the device and power it down just to be extra safe. Reconnect your device and then in the Disk Manager attempt to create a new partition on the drive and be sure to NOT SELECT QUICK FORMAT. Assuming the drive is not too mangled this should finish and a drive letter will be assigned to your drive. Test your drive and everything should be working fine.
If the Disk Manager gives you errors deleting/creating or formatting the drive then you must perform a low level format. This is a fairly simple process and under the support section of the WD site you will find directions on how to perform one using their utility. A low level format simply writes a 0 to every writable part of a hard drive and is more or less the most powerful reset a user can preform to repair a drive at home with corruption issues. Please note that that a low level format will take multiple hours to finish based on how large the drive is. Also, MAKE SURE YOU SELECT THE CORRECT DRIVE! If you low level format the wrong drive your data will be lost forever.
I hope this solves your problem and feel free to update this post with your status and/or success.
Posted on Jul 26, 2009
My iomega 1 tb hard drive isn't recognized by computer. Blue light turns on but I don't hear anything from the device itself
What's your operating system? If windows: Check in device manager if its recognized as USB device. You can also look in disk managment
Aug 31, 2013 | Iomega 1TB Desktop USB 2.0 Hard Drive
My 1tb elements external drive is not recognised on windows 7
I'm guessing the HDD needs to be reformatted. To reformat... ALERT THIS WILL ERASE EVERYTHING ON YOUR HARD DRIVE. if there is import information that is not backed up, back it up on a computer that recognizes the drive.
Go to control panel in the start menu, then to system and security, then Administrative tools, then computer management, then storage, Disk management,
This will list all storage devices that are connected to the computer. Based on the names you should be able to tell which one is the western digital. Right click, format and follow the formatting wizard. Format the drive as NTFS. Allocate all available space to 1 NTFS partition unless you would like multiple partitions.
Oct 03, 2011 | Western Digital 1TB WD ELEMENTS USB...
I have 1Tb wd My book found tha new hadwear and no sho the drive
look the drive at device manager, at device manager it will show yellow mark,and that device that show yellow mark is the new device
Feb 19, 2011 | Western Digital My Book Essential 1TB...
Computer won't recognize external hard drive anymore
Have you tried changing the USB cable or connecting it to a different USB port on the computer?
Nov 14, 2017 | Western Digital 320GB MyBook External USB...
I have a WD 1tb My Book and it stopped being recognized
1. Go to Start>> Right click My Computer>> Manage>> Device Manager 2. Expand the USB Controller section 3. Right click and Uninstall all of the listed USB devices 4. Reboot the system
Feb 28, 2010 | Western Digital MY BOOK HOME 1TB EXT...
How to format WD Passport 1TB to FAT32 I have used WD external 500GB passport drive with my samsung 1080p9 dvd player successfully WD 1TB passport drive is not recognised by dvd player
Plug the drive into your PC.
Right Click on My Computer (or Computer in Vista/Windows 7) and select Manage.
Click on Disk Management.
Right Click the Volume in question and select Format. Select FAT32 in the options.
Dec 24, 2009 | Western Digital My Book Essential Edition...
My computer fails to identify my WD 1tb external hard drive when I plug it in the USB. It also does not show up on Disk Manager. However, it still lights up and I hear it turning. How can I get the...
I fixed that problem with a WDC My Book Home 1TB in Windows 7:
The drive was recognized in computer management and in device manager but no drive letter was allocated while connected with a e-sata cable.
1.in computer management > storage > disk management
2.rightclick drive 1 or wathever the number of the WDC drive (which should be basic at this time)
3.select 'convert to dynamic disk'
4.drive should get a drive letter
5.format (warning: all data get lost, but you can download original software from wdc.com)
Succes!
Olivier
Oct 31, 2009 | Western Digital MY BOOK HOME 1TB EXT...
Drive Recognized but not visible on my computer
Right-click My Computer, go to Manage, Disk Management under Storage
Find your drive there and assign a drive letter.
The drive may still need to be formatted.
Sep 01, 2009 | Sabrent EC-UEIS7 USB, eSATA Internal Drive...
WD 1TB Hard-drive, worked perfectly now it won't :'(
If you go into Administrative Tools, Computer Management, you will see a tree for disk management. It should be listed there - probably without a drive letter..
You can partition and format there.
To get to administrative tools: Go into your control panel - click on classic view and it is one of the top options.
Jul 12, 2009 | Western Digital Elements powered by WD 320...
Western Digital MY BOOK HOME 1TB EXT HD-USB2/FW/E-SATA 3.5IN 1YR FireWire 400 Hard Drive Logo
690 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
