I have a maytag side by side refrigerator which seems to have the common problem of a warm fridge area while the freezer stays cold (but not cold enough for ice cream). It has been unplugged for several months now. I see that several people with the same problem solved it by purchasing an adaptive defrost control board. If I buy this, could I still probably run into problems since it has set idle for so long? One repairman told me that this would be the case. Thank you, P. B. Shelbourne
Hi, when you plug this refridgerator back in leave it for a few days and if you have the same problem it's going to be the defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpgheatershttp://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck! P.s Please don't forget to rate my solution Thanks! Mike
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Maytag MSD2756GES Side by Side
The ice maker cycles before the cubes are frozen, which leaves the fingers coated in slush, which...
(More)
The ice maker cycles before the cubes are frozen, which leaves the fingers coated in slush, which then freezes and jams the cycle. It also dumps the water from the partially frozen cubes into the container, causing the bottom cubes to freeze together. I have set the freezer control on "colder" to correct this, but it makes no difference.
my evaporaror will freeze up in about a month and half of running. i take a hair blower and defrost...
(More)
my evaporaror will freeze up in about a month and half of running. i take a hair blower and defrost it. IT WILL RUN ANOTHER MONTH AND A HALFTHEN I DO IT AGAIN
We are new to the fridge & were finally able to replace the filer. Now the ice maker isn't...
(More)
We are new to the fridge & were finally able to replace the filer. Now the ice maker isn't working...please help!
