Question about Brother LS-1217 Mechanical Sewing Machine
I have the machine apart and am looking at the inside. all belts intact, press on pedal and belt whir, no motion on needle end. help?
  • 46 Answers
The belts need to be reasonably tight but not like piano strings. Also if there is oil or similar on the belts this will stop the machine from turning over me friend.
Also, if the machine turns over by hand without any tight spots and will sew then your belts are either the wrong ones or need to be adjusted.
I hope this helps you,
Cookey.
Posted on Jul 25, 2009
Needle no longer moves up and down but the engine whirs
sounds like the needle is bent replace the needle
Dec 25, 2013 | Sewing Machines
I was using my sewing machine when there was a loud cracking noise-the needle had broken and I replaced it but now the machine won't work. When I press the pedal I can hear the motor whirring but the...
Have you pulled apart the bobbin race area and checked for any bits of broken needle?
Is the clutch disengaged on the flywheel?
Otherwise, was the loud cracking noice coming from inside the machine case in which case it could be a gear internally that went and the needle breaking was just the result of this, in which case, time for a road trip to the service tech.
Mar 03, 2011 | Brother XL-3500
My sewing machine makes whirring noises but will not sew anything (the needle will not move)
Not sure about this model but most have a belt inside the machine to connect the motor to the rest of the machine. Some have an access plate you can remove. New belts are available many places and are usually easily replaced. Good luck
Jan 03, 2011 | Brother LS-2125 Mechanical Sewing Machine
Belts intact, press on pedal, motion in belts, but not on needle end
does the needle go up and down when you turn the handwheel by hand? if so, one of the belts may be slipping - tighten it enough to make it grab.
if the handwheel does not make the needle go up and down, is the handwheel lock for bobbin winding un-locked? if so tighten the handwheel lock inside the handwheel. if the handwheel lock is tightened and the handwheel spins when motor runs the handwheel lock is asembled incorrectly. if this is the case, undo screw in handwhhel lock nut and spin lock nut off machine, then remove pronged washer and turn 1/3 turn and re-install.
scott
Jul 23, 2009 | Brother LS-1217 Mechanical Sewing Machine
Kenmore 10 stitch needle won't move
hi there,
push or pull hand wheel clutch to engage
motion of needle and shutter.
if not check belt on downside of hand
wheel open cover motor,loosen bolt cover
see belt check if engage on pulley by
holding hand wheel move belt if
hand wheel move,if not tighten screw on
pulley from hand wheel and moter.
have a nice day and thanks
Apr 03, 2009 | Sewing Machines
Push on pedal, hear the motor, no motion, arggg
it sounds like the belt might have come off the handwheel
Feb 02, 2009 | Brother XL-5130 Mechanical Sewing Machine
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
Foot pedal is not working!
sorry no nothing about sewing manchines ,althought this could be a wire loose in the pedal to sewmanchine .
ah you can get a manual from here http://welcome.solutions.brother.com/bsc/public/eu/eu_ot/en/doc/manual_index.html?reg=eu&type2=-1&prod=hf_xl2600i2610euk&c=eu_ot&lang=en&flang=all
if this helps
regrads
riz.
Nov 20, 2007 | Brother XL-2600
Brother LS-1217 Mechanical Sewing Machine Logo
85 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
