SOURCE: I think the brushes are
Key in your model to epares.co.uk they will show a picture of the carbon brushes and you will see on utbe a video of HOW TO ...I find it easy to leave the motor on the machine and work from under it although I have done this over 25 years so its easy for me .....I wish you well .Cost of parts around £15 depending on model....
SOURCE: HOW DO I REPLACE THE TOOTHED BRUSH ROLLER BELT ON MY PRO 8910
Here is the Instruction or User Manual for the 7910 and the 8910 series machines
and this link is video how to change both belts,,,,,,,,,,enjoy.........
http://cache.vendaria.com/vpop/VpopV6.html?ct=13&ctname=CT630X556D630X390&fw=630&fh=556&logo=49&fv=10&ap=vnd_bissell_change_belt_proheat_2x&purl=MAIN_bissell_change_belt_proheat_2x&iid=sbpgzLIuvIlJlJquLvumgwqKqvIqvv&bg=ffffff&nm=BZOpener&curl=&err=0&title=Bissell&tp=
SOURCE: my sonicare tooth brush wont stop beeping
This happened to me as well. One long, two short beeps. Incessantly. Only happens when brush is on the charger.
Try this simple fix first. Hold down the SILVER button for 5 seconds while the toothbrush is on the charging base. If the fix works, it will fix the problem immediately like magic.
If that doesn't work, try this:
1) remove brushhead.
2) use screwdriver in the base and turn 1/4 turn
3) push out assembly from the top
4) dry the inside of of the base handle. allow to air dry
5) allow the switch to air dry
6) reassemble
