Using Corel Draw 12 for the publishing software. Have a high end quality four colour print job for offset sheet feed printing. File size is not an issue but best quality is to reproduce the photography. When I produce the PDF in Corel Draw 12: GENERAL 1. Compatibility: Acrobat 4, 5, 6, PDF/X-1a, PDF/X3? 2. PDF Style OBJECTS 1. Compression Type: NONE 2. Bitmap Downsampling tick these OFF or should I give them values for best results. 3. Export as Curves 4. Encode: ASCII DOCUMENTS 1. Page Only 2. Encoding: Binary or ASCII PREPRESS Understand that tab SECURITY Not relevant ADVANCED Should I tick: 1. Preserve document overprint 2. Preserve halftone screen information 3. Convert spot colors to process 4. Apply ICC profiles - Composite printer profile or separations printer profile Any other tips for settings to get best quality out put.
  • 1 more comment
  • wayne428 Jul 23, 2009
    Thanks for the reply.
    Couples of points:
    1. I do have text copy with the images. It is a corporate brochure 48 pages.
    2. I usually save text as curves for saftey.
    3. Compatibility setting: Acrobat 4, 5, 6, PDF/X-1a, PDF/X3?
    4. Doesn't Bitmap sampling being switched off give you the highest quailty. As Bitmap samples down.
    5. Using high end 7 colour commercial offset printer
    Cheers,
    Wayne
    With question 3. Which one of these compatibility settings should I use. Acrobat 4 or Acrobot 5 or Acrobot 6 or PDF/X-1a or PDF/X3.
    Understand about the quality issue with Bitmap Downsampling and the higher numbers. Should these be unticked so the Bitmap Downsampling is not done for best quality.
    Cheers,
    Wayne
  • wayne428 Jul 27, 2009
    Partly
  • 3,037 Answers
Compression Type will reduce the file size, so JPEG is the best to choose as it will keep the largest file size and thus the greatest quality or image.
Bitmap Downsampling should be left as the following which may be the default (This is 300 for Color, 300 for Grayscale, and 1200 for Monochrome). These are all in the eye of the beholder, so this is something that if you feel you like it more one way or another, then you can test different settings but generally the above are the best for high quality photos.
Anything under Texts and Fonts is not relevant to your needs as you are only concerned with images
compress text and line art doesn't matter and Binary or ASCII doesn't matter since again this applies to text only
Preserve document overprints is used to override manual color trapping such as outlines and fills. This can be useful if another application is not being used for trapping the objects. So have this checked.
Preserve halftone screen information maintains line frequency and angle information for postscript devices and Preserve Spot colors determines whether spot color(s) should be converted to CMYK or maintained. This maintains color consistency. So have both of these checked.
Maintain OPI links maintains any Open Prepress Interface comments for linked images. You don't need this, uncheck.
Apply ICC profile can be enabled if using printer (composite or separations) color profiles. Use the Separation printer profile if printing to an imagesetter or use the Composite printer profile if printing to a full color desktop printer so this depends on what you are doing and any other settings for better quality would from now on come from your printer settings specifically. I hope this helps. Let me know how it turns out.
Benjamin
Posted on Jul 23, 2009
  • Benjamin Patri
    Benjamin Patri Jul 23, 2009
    1. Thanks, good to know it is a brochure
    2. That's fine then
    3. Yes, keep the compatibility setting on
    4. no, higher number equals greater quality until your printer can't do any better, a high number also increases file size
    5. Sounds good, let me know how this goes.
  • Benjamin Patri
    Use PDF/X3 for the compatibility setting
    The downsampling numbers means the number of dots per inch or dpi and 300 is basically a max that printers can handle, so a higher number is a better quality than a lower number
I'm using half of A4 size paper and when I print my file on it, it takes 20 seconds after feeding the paper. Is there anything I can do to make it faster?
I fixed your capitalisation, punctuation and grammar. Half of an A4 sheet is an A5 sheet and should take half as long to print an A4 sheet. Print speed is dependent on a number of variables;
Density of colour, the more colour or more blocks of black take longer. Yours is monochrome and these are the specs. You should get 12 pages per minute. It may be that your computer is slow and also is low on available RAM memory. This is an old printer and you may think about upgrading. I had one of these 10 years ago.
Benefits
  • 12 ppm mono printing
  • Zero warm-up time from sleep mode
  • First Print Out Time in only 9.3 seconds
  • Up to 2400 x 600dpi print resolution
  • Energy efficient and quiet operation
  • Easy to use All-in-One cartridge
You should get 12 pages per minutes
Sep 16, 2015 | Canon LASER SHOT LBP-2900 Printer
When starting Corel draw 12 I recieving mesage; Valid workspace file not found at the path specified.End tag was not expected at this location Please help me
You can try resetting the workspace this way:
- Press F8 and hold while CorelDraw is launching
- accept the default workspace when prompted.
I hope this solves your problem
bye
Mar 21, 2011 | Corel DRAW Graphics Suite 12
C6180 will not print labels as set out in the avery template. will bunch up as they go down sheet
Step 1 : Change the print settings
The print settings of the HP All-in-One can be customized to handle nearly any print task.
Before changing the print settings, decide whether to change the settings for the current print job only, or to make the settings the default for all future print jobs. How print settings are displayed depends on whether to apply the change to all future print jobs or just to the current print job
Change the print settings for all future jobs:
In the HP Solution Center, click Settings , point to Print Settings , and then click Printer Settings .
Make changes to the print settings and click OK . Change the print settings for the current job:
On the File menu in the software program, click Print . Make sure that the HP All-in-One is the selected printer.
Click the button that opens the Properties dialog box. Depending on the software program, this button might be called Properties , Options , PrinterSetup , or Printer .
Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Step 2 : Print with 210 x 297 mm (8.5 x 11 inch) labels
The HP All-in-One can be used with any software program designed for printing.
This document contains basic information about using the HP All-in-One to print on labels using a software program. For additional information, such as printing a poster, printing multiple pages on a single sheet, and more, see the onscreen Help that came with the HP software.
Follow these steps to print on labels:
· Make sure to load labels in the input tray. Always use letter or A4 label sheets designed for use with HP inkjet devices (such as HP inkjet labels).
· Make sure the labels are no more than two years old. Labels on older sheets might peel off when the paper is pulled through the HP All-in-One, causing paper jams.
  • Fan the stack of labels to make sure no pages are sticking together. Place a stack of label sheets on top of full-size sheet of plain paper in the paper tray, label side down. Do not insert labels one sheet at a time.
    1. On the File menu in the software program, click Print . Select the HP All-in-One as the printer. To change settings, click the button that opens the Properties dialog box.
    2. Select the appropriate options for the print job by using the features available on the Paper/Quality , Finishing , Effects , Basics , and Color tabs.
    3. Click OK to close the Properties dialog box. Click Print or OK to begin printing.
Aug 09, 2009 | HP Photosmart C6180 All-In-One InkJet...
Corel draw is not open plz help me
coreldraw x5 (Portable Vertion) not opend.
Error :
The application was unable to load a required component :
CrlUtl.dll. Please contact the publisher of this application for more information.
Jun 13, 2009 | Corel AE CorelDRAW Graphics Suite 12 for...
Corel draw files do not open
Try launching CorelDraw FIRST then open the file from the CTRL+O command in Corel. Let me know if this works!!!
Mar 18, 2009 | Corel AE CorelDRAW Graphics Suite 12 for...
Corel-DRAW 12 UNABLE TO EMBED (COLOR) JPG ONTO COLOR BACKGROUND
Right click the graphic and choose the image tools and you wil find an option for color and one for B&W. Play with those to find the problem. That should solve it
Michael
Feb 26, 2009 | Corel WordPerfect Office 12 Standard...
I'm using MS Publisher 2007 and pdf creation problem
  1. On the File menu, click Publish as PDF or XPS.
  2. In the File name list, type or select a name for the publication.
  3. In the Save as type list, click PDF.
  4. Next to Optimize for, click Change.
  5. In the Publish Options dialog box, click the optimization in the Specify how this publication will be printed or distributed list that matches the needs of the publication. For example, if the publication will be distributed online and print quality is less important than a small file size, click Minimum size. If the quality of the printing is more important than file size, click High quality printing.
  6. Click Advanced to display the entire dialog box, and select the settings that you need. (Find links to more information on these options in the See Also section.)
  7. Click OK.
  8. In the Save As dialog box, if you want to open the file immediately after saving it, select the Open file after publishing check box. This check box is available only if you have a PDF reader installed on your computer, and if the Commercial Press option is not selected in the Publish Options dialog box.
  9. Click Save.
Feb 10, 2009 | Microsoft Office Publisher 2007 for PC
HP PRINTER
function addess protection fault errors when I try to print file and go through older version of Corel Draw Print setup menu. error says "Application Properties sheet pages may not work properly". Upon execution of print file, CP1518 prints a couple lines of gibirish on top of multiple pages. I have to cancel print job manually and CP1518 needs to be "cancel print job" several times before the printing of gibirish stops. I can print just fine from Adobe Illustrator, so I am thinking that is something within Corel Draw, perhaps I need a new driver so that it works with the CP1518.
Any suggestions appreciated. Thanks.
Sep 12, 2008 | Office Equipment & Supplies
Problem Printing accurately colors from Corle Draw to Bizhub C252
The reddish greys are something a Fiery will correct, that is part of it's function. (GCR).
I would try turining colour management off, or rasterizing the file in Corel. I believe there is an option in the print window.
Have you tried making a PDF of the file and printing that?
Using the ICC profile could be a solution, but the Fiery is what is needed.
Jan 10, 2008 | Konica Minolta bizhub C250 All-In-One...
Printing accurate colors from Corel draw to the Minolta Bizhub C252
HI there i have the same printer and for accurate color i follow this steps:
1 - First publicate you work in a pdf file whit high quality
2 - Go into adobe Acrobat (profesional not reader only) and pres print
3 - Then you have to select in advanced settings and select icc profile "sRGB ..."
4 - You´ll notice that the colors are very real. No oversaturated and the real deal are the fonts that prints correctly in border even if they are very small (- 6 pt.).
5 - RECOMENDATION: For intense black use a compost one 100% in every color or select in the color palette the one at the end of the palette
Greetins.
Nolasco from argentina - DPI Grafica
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
