Those fault codes require the proper toyota spec air bag diagnostic reader to clear any air bag fault codes
maybe some other sensor is throwing a new code
air bag code readers can say what else is throwing a code
how to solve the warning Lights on the dashboard?
1 Handbrake
2 ABS
3 Airbag
4 VSC/Trac
5 P/S
i have gone for a reader tool and only the airbags are off the others still on
my part of the world i call that a toyota camry
the lights on the dash only indicate the fault is still there within all of those component systems
what ever was replaced so far want causing the dash light alert
some parts may not have needed replacing at all
good the air bag alert is sorted
there are some youtube vidies fixing some of these issues
P/S warning on a toyota dash is the only one i dont recognise
more work to be done tracking down the causes
my thoughts
the abs module faulty leaking valves not working or something in the brake sensors at the road wheels ?
handbrake on off switch faulty or maladjusted
VSC/trac is a sensor .calibrate steering angle sensor
ABS LIGHT AND MODULE TROUBLESHOOTING:
Anti
lock brake system light comes up when there is issue with car brake systems. It
can be low brake fluid or faulty ABS fuse or its issue with brake system or assembly.
Your vehicles brake system needs inspection.
To
troubleshoot these issues, I suggest you to refer the help links provided below.
There are direct links with accurate solution, for these specific issues.
Click
the link below and follow the procedure: ------
http://howtobyme.blogspot.com/2011/11/abs-and-service-light-comes-on.html
http://howtobyme.blogspot.com/2011/11/abs-light-stays-on-but-brakes-work-fine.html
http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
http://howtobyme.blogspot.com/2011/11/abs-brake-lights-warning-indicator.html
http://whoisbyme.blogspot.in/2012/07/battery-light-and-abs-light-on-dash.html
http://technoanswers.blogspot.com/2011/11/how-anti-lock-brakes-work.html
http://technoanswers.blogspot.com/2011/11/brake-system-troubleshooting.html
http://technoanswers.blogspot.com/2012/01/anti-lock-brake-light-stays-on-all-time.html
ABS
light comes on and Car makes Grinding noise?
http://repairhelpcenter.blogspot.com/2012/01/abs-light-comes-on-and-car-makes.html
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
http://technoanswers.blogspot.in/2012/05/2008-toyota-highlander-abs-warning.html
http://technoanswers.blogspot.in/2012/04/2003-lexus-es-vsc-trac-off-abs-lights.html
http://technoanswers.blogspot.in/2012/04/2008-toyota-highlander-hybrid-warning.html
http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
http://schematicsdiagram.blogspot.in/2012/02/can-i-drive-car-without-abs-fuse.html
http://schematicsdiagram.blogspot.com/2011/12/where-is-abstcs-module-located-on-2005.html
http://schematicsdiagram.blogspot.com/2012/01/abs-motor-keeps-running.html
http://howtobyme.blogspot.com/2011/12/when-car-stopsabs-pump-turns-on.html
http://technoanswers.blogspot.in/2012/02/replacing-abs-unit-on-buick-century.html
http://technoanswers.blogspot.in/2012/04/toyota-camry-premature-abs-actuation.html
How to replace ABS Modulator Control
Unit on Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-modulator-control.html
How to replace ABS Pump Assembly on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-abs-pump-assembly-on.html
How to remove ABS Accumulator on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-accumulator-on-acura.html
How to remove ABS Control Unit on
Acura Integra?
http://repairhelpcenter.blogspot.in/2011/11/how-to-remove-abs-control-unit-on-acura.html
These details will help.
Thanks.
