Question about Garmin nuvi 255W GPS Receiver
Garmin 255W turns on and shuts off
I turn it on, GARMIN comes on the screen, then followed by
nüvi 255W
Copyright 2009
Garmin Ltd. or ts subsidaries
and then you hear some beeps and it shuts off.
If I put the adapter in, it keeps on doing this by itself (turning on and shutting off)
  • Anonymous Mar 13, 2014
    garmin oregon 450t I turn the power on and the Garmin logo shows on the screen At the bottom of the screen the copyright information shows up and it then switches to loading photos... then it turns off. This is the first time this has happened? What is wrong?
  • Anonymous Mar 24, 2014
    turns off as soon as the garmen 2012 copyright logo appears
  • 35 Answers
Have you tried resetting the unit.Press and hold the RESET button on the bottom of the nuvi for several seconds,DONT use a ball point pen to do this,use something that wont damage the unit,if this doesnt work,do a hard Reset.Or try rebooting by holding the Power switch on for 15 seconds.Good luck.
Posted on Jul 23, 2009
I struggled with this for a week. Could not find any reset button or hard reset. Turning the switch off for 15 seconds by holding my thump on the lower right corner of the screen and then turning it on. It asked with a message 'Do you want to erase user setup?' I pressed No and then it started working...
What is this placing finger on the right bottom corner does, no idea. but it works!
Posted on Apr 27, 2010
My garmin nuvi 215 will not power on - every so often the garmin logo is displayed but it wont go any further - any idea how I can fix it?
Try performing a soft reset on the unit.
Resetting Your nüvi
If your unit stops responding, turn off the unit, and then turn it back on. If this does not help, perform a reset using the reset button on the bottom of the unit.
Caution: Do not reset your nüvi with a ballpoint pen or other sharp object, which can damage your unit.
1. Disconnect the nüvi from external power.
2. Press the Reset button on the bottom of the nüvi.
3. Connect the nüvi to a power source.
A hard reset can also be done but will erase all the user data.
This is done by with the unit off and pressing and holding the bottom right hand corner of the screen while turning the unit on.
You could also try running the Garmin WebUpdater.
Download and Install WebUpdater.
Sep 21, 2011 | Garmin nuvi 215 GPS Receiver
My garmin 200 gps is not coming on?
Resetting Your nüvi
Sep 15, 2011 | Garmin nuvi 200W GPS Receiver
Screen does nothing just says garmin
Resetting Your nüvi
Aug 24, 2011 | Garmin nuvi 205W GPS Receiver
Garmin turns off when Garmin screen comes on
Resetting Your nüvi
Aug 22, 2011 | Garmin nuvi 205W GPS Receiver
How to calibrae my gps nuvi garmin 255????????????????
For the Garmin 2x5 series GPS
Calibrating the Screen:
1. Turn off the nüvi.
2. Hold the upper-left comer of the screen white turning on the nüvi
3. Release the power key when the Garmin screen appears.
4. Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
Here are links to the manual for both the 255 and the 255W (wide).
I hope helped & good luck! Please rate my reply. Thank you.
Jun 30, 2011 | Garmin nuvi 255W GPS Receiver
I need to calibrate my Garmin Nuvi 1260T. It's been alittle off ever since I got it. I tried holding the power button for 30 seconds and waiting until the calibration screen pops up but nothing pops up. ...
In order to calibrate the screen on the Nuvi 1260T, you need to follow these few simple steps.
- Turn off the device
- Hold the upper-left corner of the screen while turning on the device
- Release the power button when the Garmin screen appears
- Continue to hold the upper-left corner of the touch screen for 30 seconds until a white screen with "Press dot" appears.
This should allow you to calibrate the screen. I hope this helps!
Mar 01, 2011 | Garmin nvi 1260T 35 in Car GPS Receiver
Garman 225w won't start, stops after "loading
The micro usb port is at the back. Connect Vehicle Power Cable to the nüvi and connect the other end to your computer, your nüvi does not operate as a GPS unit - it goes into some sort of charging mode. However, if you FIRST turn on the nüvi in the battery mode then go into the test mode (press the battery icon for about 8-9 seconds) from the main screen, THEN PLUG in the USB cable, and finally exit the test screen, your nüvi will restart (reboot) and it will operate just like it was plugged into the cradle connection in your vehicle.
This mode will charge the battery
AND operate as a GPS.
It works with my computer USB cable, my cell phone charger and my car charger for my cell phone.
Don't forget to turn off the nüvi before unplugging.
Jan 08, 2011 | Garmin nuvi 255W GPS Receiver
Nuvi 225W shuts off as soon as it comes on
Well, I had a similar experience with a nuvi 1300, and perhaps my solution will work for your unit.
I tried holding my power button for 10-15 seconds, which forces it to start, but mine (like yours), would begin starting, get stuck on "Loading Maps." and then shut itself off.
I had to plug it into a USB port of a PC, and it started up for the purposes of data transfer, (not the normal startup). I then unplugged it from the PC and it restarted properly.
Give that a shot and see if it works.
Apr 12, 2010 | Garmin nuvi 255W GPS Receiver
I don't know the pin for my Garmin Nuvi 255W. Help! I have used it a few times in the past. My granddaughter set up but she does not recall the pin either. Any way to bypass this or is there a way to...
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Apr 18, 2009 | Garmin nuvi 255W GPS Receiver
Dear Mr Deacon. To enable your traffic subscription follow the steps below: Apply external power to the nüvi. Connect your FM Traffic Receiver to your nüvi using the USB cable. From...
Those were pretty good instructions that Garmin gave you.
If you have your owner's manual, refer to how to get into your settings. If you don't have the owner's manual, you will have to google it. Unfortunately, you did not provide the model number, otherwise, I would have provided the link to it.
Mar 17, 2017 | Garmin GPS
Garmin nuvi 255W GPS Receiver Logo
2,891 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
