Question about LG Microwave Ovens
I have inherited my aunts LG microwave MC800AW, mine was ruined by a power-cut, unfortunately there is no handbook. Please help!!!
LG microwave not working fuse is ok
The cable is ok? is the cable plugged in in a socket, with live power? check with a little lamp.
No wire lose in the plug that goes into the mains?
Jan 23, 2015 | LG Microwave Ovens
LG door panel separating
DO NOT use this microwave in the current condition it is in- please! Although microwaves do not emit ionizing radiation, it does emit non-ionizing radiation and electromagnetic fields- and there is a lot of research studies being done possibly linking microwave exposure to cancer.
If your microwave is in that bad a shape, bring it to an authorized microwave repair shop or junk it and buy a new one.
For replacement parts, repair videos, and manuals: http://www.lg.com/us/support/parts-accessories
Jan 03, 2014 | LG Microwave Ovens
The microwave oven has completely gone dead Sharp r-1501c. Yesterday the light was on. I went to turn the light off and to put something in the microwave and it lost all power. I've checked the outlet...
It may be the control panel. What ever you do, don't send the control panel to William Miller. He ripped me off, and I have to dispose of my microwave because he never returned my control panel.
If yours has gone dead completely, it's more cost effective just to replace it. I bought an LG to replace mine.
Mar 08, 2011 | Sharp R-1501 Microwave Oven
STS17 microwave user manual
look on the internet for "who makes this model" you maybe able to down load it
Oct 21, 2009 | Belling Microwave Ovens
It is running, but doesn't heat the food.
I had the same thing happen to my microwave and the Magnatron was the bad part. There are some things that you can check and I would be glad to help. I bought the parts for around $70.00, but mine was a built in unit.
Let me know, I will help.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I have helped you, please help me, and rate this suggestion a the highest FixYa rating (Give it Two thumbs up). If not then please comment to this post and I will try to help you further.
Thank you for your support.
May 21, 2009 | Goldstar Microwave Ovens
Need help with my Gold Star microwave.
i just took out my fuse on the same model. you have to pull down the microwave and take cover off. there should be like 6 screws on backside and cover will slide back and off. then you will see a fuse cover with a small cylinder fuse in a plastic cover. pull it out and check continuity with volt meter. mine unfortunately came up good still, so i dont know what kinda problem mine is having. had a short in light and it popped and power was gone. good luck!!
Mar 08, 2009 | Goldstar MV-1526 Microwave Oven
How do I set the power to 50%?
If you have "Power" botton on m/w
1. set time for time cook
2. press power botton
3.set 50 and hit start
Nov 30, 2008 | Microwave Ovens
Instruction manual for LG microwave convection oven
You can download Samsung over the range microwave installation instructions here. If that's no good, try here.
Otherwise, visit this page, click on click on the left-side arrow "Busque por Codigo del Modelo" in the big purple rectangle, enter your model number in the box, then click "Buscar". They may list an English version manual available for download.
Good luck.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 15, 2008 | LG LMVM1935 Convection/Microwave Oven
MS-3444DPS LG Microwave
You can see and hear a YouTube video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven. You may have to cut the cover off with snips, then use a screw when reassembling it.
For Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 26, 2008 | LG LRM1250 Microwave Oven
Touch-pads unresponsive
Some newer models have a child lock feature which can be accessed via a HELP or CUSTOM HELP pad. On recent LG models, try pressing the "0" key for 5 seconds. You may also have a bad keypad, which in many cases can be replaced. A bad keypad may be worn out due to age, damaged, or it may have gotten wet or otherwise contaminated. Has anyone ever sprayed cleaner directly on the keypad? Has anyone ever boiled on the stovetop without running the hood vent fan? Is the hood vent clogged? Any of these can cause moisture buildup on the control circuit board or in the keypad, which can cause odd problems like this. I warn my customers to never spray cleaner directly onto the microwave keypad, since the liquid can get inside and "lock up" or even ruin the keypad or controller. Apply an alcohol-based cleaner (such as the purple kind) to a cloth (since paper towels can scratch) and gently wipe it off. I suggest to my customers that they NEVER use any ammonia-based cleaner (like the blue stuff) on a microwave, since the ammonia will crack and distort polycarbonate plastics. Please let me know if I can help further: http://tinyurl.com/yzjozk
Sep 22, 2007 | LG LMVM1945 Microwave Oven
Microwave Ovens Logo
67 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
