Question about Nokia Cell Phones
Nokia n95 8gb-memory full error. When an alarm is set, the alarm icon is not seen on the top right corner.
I keep getting "system error"
The system setting have been manipulated either by reducing memory capacity or introducing a program download too huge to appear in the browser provided. A system error could be disables by resetting the browser capasity to full memory capasity. Else, consider restoring the entire device to user defaul settings.
Dec 04, 2010 | Nokia 5230 Cell Phone
I have just brought Nokia 5230 2 days back. I found that on the right hand corner of the handset near the battery a envelope blinking, on clicking which i get a message Sim memory full. I have transferred...
This flashing envelope icon is telling you that your text message storage is full.
1. Go to Messages
2. Select Options
3. Then select SIM messages
4. Select and delete all SIM messages.
This should do it.
All the best!
May 18, 2010 | Nokia 5230 Cell Phone
The new small message icon blinks on the top right corner of my nokia n97 how to remove that?
go to Messaging Then "Options > SIM messages". and you should delete all massages from there.
May 07, 2010 | Nokia N97 Cell Phone
Message box keeps blinking at the top right hand corner what could be the problem
its means that your inbox is full with incoming messages,so delete some messages is the solution its actually means that your default message memory is phone memory to avoid such problem in future, and if your phone support memory card , then go to the message settings change the memory option to memorty card from the phone memory....
Feb 02, 2010 | Nokia 6220 classic Smartphone
I have the nokia 5800 xpressmusic which i have just got. in the top right hand corner there is a envelope flashing, when you click on it its says simcard memory full, i have all ready cleared the numbers...
If you've just put your SIM card in your Nokia 5800, you may have noticed a flashing envelope icon at the top of the screen.
This icon indicates that the SIM card's own text message storage is full. This doesn't actually cause problems on the 5800 because it stores its messages in the phone's own memory, but the envelope can look a bit annoying.
To get rid of the flashing envelope:
1. On the standby screen press the white menu button.
2. Select "Messaging"
3. Select "Options"
4. Select "SIM Messages"
5. Delete some or all of the messages from the SIM messages folder using the Options menu.
This should make the flashing envelope go away. You only have to do this once because when the SIM card is emptied it won't fill any more, as the 5800 does not store messages on SIM cards.
Nov 19, 2009 | Nokia Lands Phones
My Nokia N79 handset is displaying a small blinking ikon of a message on top right corner of the screen as if there are some unread messages in inbox. I emptied inbox, sent and outbox items, still problem...
go to msgs then in options go to sim msgs..when all sims msgs appear then delete them..icon will dissappear.i had the same problem.its due to sim memory fullness
Nov 01, 2009 | Nokia N79 Cellular Phone
It says 'SIM memory full' in top right corner with a little envelope pic next to it and iv tried everything to get rid of it.there is not one thing saved to it that i can find?
SIM memory can only be full of contacts. You cant save anyother thing to the SIM. May be that the SIM memory is bad. You can ask your service provider to change the SIM with the same number.
Jul 31, 2009 | Nokia 5800 XpressMusic Smartphone
Sim memory says it is full when it isn't
go to messaging, click options then go to sim messages,mark all messages then copy to your phone. that's what i did and got rid of the annoying flashing envelope in the top right hand corner of the screen. hope this will work for you.
adrian23
Mar 20, 2009 | Nokia 5800 XpressMusic Smartphone
Memory full error
Format phone by using this tips. -Turn off the cellphone. - Press (long press) at thesame time the switch on, call sign(green color of keypad), *, and the number 3. -don't take off you finger to this keypad until it show on the screen a FORMATTING. Thank you.
Nov 11, 2008 | Nokia 6600
Cell Phones Logo
313 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
