Question about Vivitar DVR-550 DV Camcorder
No action on DVR550
Nothing happens when I open or try to turn on my DVR550.
  • 1 more comment
  • hd_thompson Jul 24, 2009
    I have had the DVR plugged into my computer all day and there is still no power. Is there any visual indication when you need to replace the battery? Will I need to go to a specialty store to purchase a battery?
    Also, how do do plug this DVR into a wall socket?
  • hd_thompson Jul 28, 2009
    I'll let you know if this fixed the problem once I get the battery/charger I just ordered!
Can you confirm that the unit is fully charged and that the battery is properly inserted? If so, can you have the unit plugged into the power cable with the power turned on at the wall socket, and see if it will turn on with the power cable instered?
Posted on Jul 23, 2009
  • Anonymous Jul 24, 2009
    Thank you for your reply.
    Sorry, I would have thought the camera came with a standard wall charger. It seems like the battery in the unit is not getting charged when plugged into the computer. You may need to purchase a charging kit such as this one.
    If that does not help, this problem does appear very common with this camera with lots of complaints from customers regarding the same power and charging issues. You could try a local camera repair center and see if they bring back the same verdict. It could simply be a faulty camera unfortunately.
    Best regards
Hobart am 15 dishwasher display freezes when turn on and no further action
Long shot, but have you checked to hood reed switch. Nothing will happen if it thinks the hood is open?
Dec 23, 2017 | Hobart Dishwashers
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
''water intake'' button flashes but no action
I would check the water supply lines that run into the washer they may be restricted.Or the solenoid valve is shorted and is not opening the valve to let fresh water in to start the cycle.
Apr 23, 2010 | Dishwashers
Lincoln 3200hd. welder,when power switch turns on, the fan comes on, but when i pull the trigger on gun to start to weld nothing happens the wire does not feed. i am not sure what is happening
open the area were the role of wire is and check when trigger pulled if any action to feed motor. [wire might be stuck at end, or there usually is a small fuse in that area for feed motor]
Dec 04, 2009 | Lincoln Electric K1170 AC-225 Stick Welder
Code manager connection
CD is in drive: Plug in the DS and turn it on (going to the update screen on the DS), this -might- prompt you about a new software that has been plugged in and ask you to install the drivers for the "NDSLink" With the CD in the drive, it will find the drivers for the NDSLink
Wire Wiped Clean: It isn't the wire that needs cleaning but it's the pins, if the Pins need cleaning use an alcohol solution (Damp, not soaking). Otherwise pinch the wire and run your fingers across it to straighten the wires within the cord without pulling (pull too hard and you'll rip the wires) Though do note that exposed wires are not a good thing. If you received your cord with exposed wires, return the Action Replay and its accessories promptly and get a new one.
DS is Open: Again, your DS needs to be on in order for the computer to recognize that it's plugged in. It's the Action Replay that the Code Manager on the computer talks to, not the DS. The Action Replay needs an electrical current going through it to tell the computer that it's turned on. DS on = Action Replay on.
Other possibilities that are not explained: Did you happen to drop the Action Replay? Damage from falls is completely possible and ruins the state of the Action Replay, causing it to come lose easily or not work properly. I have needed to replace my Action Replay due to these accidents before.
Where was this Action Replay bought? If you bought it from a exchange store, you might have gotten a DS that was damaged before you got it (It happens), so if it is not too late, return it, and get a new one (Depending on the price difference between new and used in your area, for me it was a $5 difference)
Nov 12, 2008 | Panasonic DMR-E85H DVD Recorder
Sony nwz-S515
Try adjust the USB cable and/or switch which USB port it's connected to on your computer. Also just patiently let the player sit and try not to perform any other actions on the computer. When mine did this, I opened Media Player, wiggled the USB cable and waited. Eventually it connected and worked correctly.
Sep 28, 2008 | Sony NWZ-S615F Walkman Video MP3 Player
AR won't work, screen is white, nothing happens
this is an action replay problem, try to use a damp cotton swab and rub it on the bottom where it reads. If this dosent work please consult.
Jun 15, 2008 | Nintendo DS Lite Console
Panasonic vcr
what is the model of the vcr ?
Mar 23, 2008 | Panasonic PV-4601 VHS VCR
Copy and paste issue
Why not export the image as a jpeg or tiff and the open it in photoshop, that's what I do, It works fine.
Feb 05, 2008 | Adobe Photoshop 7.0 for PC
Vivitar DVR-550 DV Camcorder Logo
94 people viewed this question
Top Vivitar Video Cameras Experts
Joseph Wright
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Vivitar Video Camera Expert? Answer questions, earn points and help others
