Question about Kenmore 53602 / 53604 / 53609 Side by Side Refrigerator
Lightbulb burned hole in top of Kenmore Refrigerator Md#53602l
The light bulb went out on my Kenmore Model# 253.65953602, and when I removed it I noticed it had burned a whole in the top of my refrigerator. The bulb was very hard to remove and it looked like it was touching the top of refrigerator. I tried to turn the bulb holder to see if I could position it pointed down but it does not move. I do have a 3 year extended warranty and the repair man is to come out next week, I was wondering if this has happened to any one else that has purchased this model? It could be a real fire hazzard. I have not found a recall on this model. How would a problem like this be repaired? Thanks for any information
  • 150 Answers
SOURCE: Refrigerator Water Leak from opening under Freezer
easy fix my man. couple of possibilities: 1) the fresh food gets cold air from the freezer via the vents where the water has been coming out. the water has frozen up in the vents and is blocking the airflow. the reason the water was coming out in the first place is a slow drain. open up the evaporator cover inside the freezer. get all the ice out of there and clear the drain. a little bleach will kill the gunk that made the drain flow slowly.
2) you have a defrost issue and the coil is loaded up with frost causing no airflow to the fresh food section. check the defrost heater limit and timer. none of these repairs should be over 150. but thats in lawton ok. if you live in L.A. or NYC get the wty.
Posted on May 07, 2008
SOURCE: Kenmore Refrigerator Model #596.76522500
Where is the motor,Evaporator fan locate at?
Thanks,
Ko Ko
Posted on Jun 16, 2008
  • 63 Answers
SOURCE: is there a kenmore refrigerator recall?
The 800 number is available at:
www.techimo.com/forum/imo-community/145834-lg-electronics-sears-roebuck-recall-refrigerators.html
Posted on May 30, 2009
woodchuck789
  • 4070 Answers
SOURCE: Freezer too cold--refrigerator too warm
If the cold control is not adjusting the temp when you move it, that can be part of the problem.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Jan 26, 2010
SOURCE: Kenmore Trio lights staying on melting the bulb housing
The service guy just left after fixing our unit. I found this thread, called in the complaint this morning that our housing was melting (and the food on the top shelf was HOT...had to toss out some melon), and mentioned SF46-515. To my surprise they sent out a repairman this afternoon, he replaced the bulb assembly, replaced the controller board, and ordered a new bulb cover (he didn't have one). Total cost to me: $0.
The new bulb assembly includes a thermostat...if it gets hot due to the bulbs being on too long the thermostat shuts them off. The first person who answered the phone seemed to be in an overseas call center (just a guess), and when I mentioned the SF number he put me through to an American person (based on the accent) who set up the service call. No muss, no fuss.
Anyone having this problem, call the service number on your manual and mention the SF46-515. LG apparently has agreed to fix this problem whenever it occurs. No time limit, per the service guy. I am satisfied with the service I received today.
Posted on Sep 10, 2010
Where is lightbulb in freezer whirlpool model ed5kvexvboo
The model number is probably ed5kvexvb00. The parts diagrams, http://www.searspartsdirect.com/model-number/ed5kvexvb00/1198/0165000.html , show four places with light bulbs. There is one light under the Refrigerator ice dispenser. (It's mounted on the Refrigerator Dispenser Motor Mount. The motor power a shaft through the ice bucket so that might block your view of the light cover.) There is a small 7 W light behind the dispenser control bracket. There is a single light near the top right of the freezer above an air duct clip. Finally there are two bulbs in the refrigerator above the air duct louver in the lower portion of the refrigerator. Use the Refrigerator Liner, Freezer Liner, Motor & Ice Container Parts and the Dispenser Front Parts diagrams above for pictures of the covers for several of the bulbs.
I hope this helps.
May 29, 2017 | Whirlpool Refrigerators
My light just burnt iut onmy kenmore sewing machine and now it wont work
You need to replace the lightbulb. You may need to remove the cover over the lightbulb off in order to remove the bulb. Take the bulb to the local sewing machine repair shop or order a replacement online.
FWIW, you may want to consider an LED bulb. They are much brighter and do not get hot like the standard bulbs.
Mar 15, 2017 | Kenmore Sewing Machines
How to replace lightbulb
Is this a countertop microwave or an over-the-rang (OTR) microwave? If it's a countertop model, you need to completely remove the outer case to get to the lightbulb. If it's and OTR microwave, there usually is an access cover located behind the grill vent. You can remove that grille vent by removing the 2 to 4 screws above the grill vent. Then either slide the grill vent 1/4" to the left to remove it, or else (depending on the model), just pull out the top of the grill vent, followed by the bottom. Then you should be able to see the lightbulb access cover. Usually there is 1 screw that you have to remove. But unplug the microwave before you to any further! Now remove the screw, lift up and remove the cover, and you should be able to get to the light bulb.
Aug 10, 2014 | Kenmore Microwave Ovens
Freezer broken lightbulb
you can usually take a potato and screw the broken bulb out and find a new one home depot lowes or walmart
Apr 24, 2009 | Magic Chef CTB1521 Top Freezer...
Light went out on the interior of microwave
The first step is to unplug the oven before changing bulbs!
I have a diagram at my site which helps you find & replace many cooktop and cavity light bulbs. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Aug 27, 2008 | Kenmore 63763 Microwave Oven
Light bulb
Sounds like you got a defective bulb. Make sure it is for 120 volts or thereabouts....not 6 or 12.
Jun 19, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore 53602 / 53604 / 53609 Side by Side Refrigerator Logo
305 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
