Question about Datamax I-4308 Thermal Label Printer
Printing from windows
I can't print to a Datamax printer from windows, I have a text file with the DPL for the specific label. And I have a port pointing to the printer's IP address, using a Generic Text Driver, but nothing comes out.
Any help will be appreciate it.
As i understand, DPL will works if you are using a serial comunication. When you say "using Generic Text Driver" i can see you are trying to print snce parallel port, as any other prnter. If that is the case, you can forget the DPL. Install an apropiated DATAMAX printer driver, and print from Wordpad.
Posted on Aug 17, 2008
Dmx-4204 and zpl
You can't, on this obsolete model. zpl is "Zebra Printer Language." This model of Datamax is dpl only ("Datamax Printer Language"). Most current models of Datamax printers are dpl and zpl compatible.
Jul 23, 2013 | Datamax E-CLASS DMX-E-4204 Label Printer
Zpl emulation with datamax i-4208
Able Label Systems Thermal Printers
Feb 01, 2013 | Datamax I-4208 Thermal Label Printer
Can I print labels using DPL to a networked Datamax I-4208 using C#.NET?
greg babcok: You can do printing via tcp/ip packets or using Windows spooler. I have some example in vb.net
Roberto Martinez
padrino99@prodigy.net.mx
Apr 27, 2011 | Datamax I-4208 Thermal Label Printer
Ido not have any problem if I print label using Zebra. I wrote codes on Visual Basic 6 to print label using Datamax printer conneccted parallel port with command L to start. The printer printed the text...
Do you have Zebra emulation firmware installed? If not, your printer will not understand the command language that you are sending to it. Datamax has its own language and you will need a branch in your code to support that if the printer does not work with ZPL.
Jan 14, 2010 | Datamax Prodigy Plus Thermal Printer
Datamax I-4208 not printing allocated amount of labels
Eventually you HAVE to give the printer a break, during inventory times at work, we have to print 50K+ labels, and in order to prevent either serial number skipping or other issues, I print in 250 batches, yes; there is a time gap but it's better than to restart a series of prints because a few numbers were skipped. Try printing 200 and 200 sets to prevent errors or skips.
Jun 03, 2009 | Datamax I-4208 Thermal Label Printer
Vb6 code to print barcode using datamax e4203
Puedes utilizar comandos DPL e instalar una impresora generica, o generar un archivo PDF y utilizar un controlador de windows para DATAMAX. DPL commands you can use and install a generic printer or generate a PDF file and use a Windows driver for Datamax. buscar
Apr 10, 2009 | Epson Printer
HOW TO PRINT LABELS IN DATAMAX PRODIGY PLUS PRINTER USING VB.NET
Tu necesitas utilizar comandos DPL. Pero si vas a utilizar graficos o windows true type fonts, tu necesitas un cartucho de memoria ram o flash. You need to use DPL commands. But if you use graphics or windows true type fonts, you need a RAM or flash cartridge.
Apr 06, 2009 | Datamax Prodigy Plus Thermal Printer
Image files won't print only name no image
I can help you with this. Please let me know what method you are using to send images (software, dmxconfig, dpl..) and also the type of image (bitmap,jpeg, pcx,etc..). With Datamax printers, 4 types of image can be used: bitmap,pcx,img, and 7bit datamax image file. Another thing to know is that the image must be a black & white, monochrome image. You can use a program like microsoft photo editor to make this change. You can use DmxConfig, Utilities.exe, & DPL (datamax programming language) to load image to printer. Let me know the answers to my above questions to proceed with solution.
Dec 16, 2008 | Datamax DMX-I-4212 Label Printer
Problem with printing labels - not aligned, some missing
This is due to print server problem, you should change the options on the driver.
Nov 04, 2008 | Datamax M-Class M-4206 Thermal Label...
Allegro2 Print Too Slow (25 seconds send from Windows XP)
miaharoon: Printing via Windows driver it's too long time because the driver sent a lot data to printer. Also the print speed via serial port it's slow. Inside driver, install Datamax printer fonts and barcode fonts to use it in Windows programs.
Roberto Martinez
Jul 22, 2008 | Datamax Allegro2 Thermal Label Printer
Datamax I-4308 Thermal Label Printer Logo
667 people viewed this question
Top Datamax Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Greg Cann
Greg Cann
Kevin Brown
Level 1 Expert
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
