Question about Uniden TRU9380-2 Twin Phone
Phones won't pick up calls...say connecting
Calls are coming in just fine the base unit and people can leave messages. However, we are unable to receive or make calls using either of the handsets. They will either flash "Connecting" and then "Unavailable." The batteries have about 3/4 charge and up untilyesterday were working just fine. THen, late yesterday, they would say Connecting and then, eventually, a dial tone would come up.
When a call comes in nothing happens when you either pick up the handset form the base or push the green button to answer if off the base.
Re: phones won't pick up calls...say connecting
HOLD THE HANG UP BUTTON AND THE POUND BUTTON DOWN FOR 5 secons. select base unavailable....yes. then hang it up on the base and it will register to the base. if that doesn't work then unplug the base then plug it back in then put the reciever on the base.
Posted on Sep 18, 2010
0 characters
3 Points
My panasonic KX-TG5000 phone headsets cannot make or recieve outgoing calls and the intercom function is gargly.
You need to reset the menu once again as it is possible that the phone had hung up as there was LINE PROBLEMS . Once this was reset the CLIP facility came back. So if you can once again remove power battery and keep aside to reset , then start all over to set up the base and slave units to MESH , the intercom and line facility must work.
You can remove the battery from the slave remote units to reset.
Oct 20, 2011 | Panasonic KX-TG4500 Phone
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Phone doesn't ring on incoming calls
i cannot fix the number of times for the ringer on my vetch phoneset
Oct 19, 2008 | Vtech Cordless 6041 Phone
RCA ViSYS 25450 cordless handset
Quickly, return this Phone is you still have a chance, my small business used this phone for EXACLY 2 years, and now all lines are DEAD, NOT A SINGLE ONE WORKING. LINE ONE AND THREE HAVE NO DIAL TONE EXCEPT EXTREMELY LOUD STATICS. AND LINE 2 AND 4 ARE TOTALLY MUTED.
A lot of my customers are complaining about not being able to reach me in my office.
Apr 10, 2008 | RCA 25450 4-Line Extended Range Multi...
No Link To Base Unit
I am having the same problem!
Mar 10, 2008 | Panasonic KX TC1743B Cordless Phone
Siemens Gigaset 2420 corded unit resets when calls received
OK, here's what happened. I had the same issue of the phone resetting when a call came in, I thought it was a power issue and through some testing it was not. Here's the fix...Menu \ system settings \ enter pin (if you haven't changed it it is 0000) scroll to factory default and reset. This fixed the problem somehow for me, make sure to write down any impotant messages because it will erase everyting (silly me). I hope this helps.
Nov 14, 2007 | Siemens Gigaset 2420 Phone
Uniden TRU9380-2 Twin Phone Logo
342 people viewed this question
Top Uniden Phones Experts
Dave Ellis
Are you an Uniden Phone Expert? Answer questions, earn points and help others
