Question about Audiovox D2010 Portable DVD Player with Screen
Horizontal lines on screen.
Have an Audiovox portable DVD player, who plays fine. Problem is that, from the moment you turn it on, the screen has small horizontal lines moving across. It makes no difference if it is playing a DVD or not. You can still see the movie, but the lines are distracting. HELP?
    Novelist:
  • 133 Answers
Your unit may have a loose connection from motherboard to the display (video cable inside the unit), another distinct possibility is that the video processor chip is damaged or there is a power supply problem for the video chip (a bad electrolytic cap or similar somewhere around the video IC).
You can check the connection, but you'll need to take the unit apart, also check other connectors, but if it's an IC problem, this could get difficult or/and costly.
Please note that these are only suggestions and that the problem may as well be something else.
regards
3rq8 (Triarcuate)
Posted on Jul 24, 2009
I have great sound on my Audiovox portable dvd player but no picture. Can you help?
  • Check that the A/V IN/OUT Switch on the side of the player is set to the OUT position.
  • Check the small switch near the hinge at the back of the unit, if one is installed there. It turns off the LCD screen when the panel is closed. This switch sometimes sticks in the down position and the screen remains off. When the screen is opened, the switch is supposed to pop up. If it is still in the down position, try to free it with the ends of a toothpick or paper clip.
  • If both switches are correctly set and the screen remains blank, the unit should be sent to Audiovox for service.
May 16, 2011 | Audiovox D1708 Portable DVD Player
Nothing is showing up on the screen. When you
Due to the fact that when you move it it changes the problem it sounds very much like an intermittent soldered connection internally. That would require a shop repair.
Mar 30, 2010 | Audiovox D1888PK Portable DVD Player
Dvd won't play
lens could be the last option to check, most common problem with portables is, the drive motor, try to change it then play it, still problem continues, then change the lens, it should solve your problem
Oct 25, 2009 | Audiovox ADV12 Portable DVD Player
Audiovox portable dvd PVS6360 unlock codes
Audiovox code hack for DVD players
1. Turn the DVD player on
2. Go to the main setup page
3. In the main set up page press the numbers 9653
4. In the new menu go to region press enter
5. In region use the up and down arrow to select the region
6. Turn the DVD player off and turn it on
7. You now should have changed to the region of choice.
This hack was found on the internet. I hope this information helps you with your problem.
Dec 13, 2008 | Audiovox D1210 Portable DVD Player with...
Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
Nov 16, 2008 | Audiovox D1020 Portable DVD Player
Dvd -no picture
Sometimes the displays can't be sent to another tv or monitor. Make sure that isn't turned on. Sometimes there can be a short in the wiring if your unit folds up to play like a notebook computer. You can try moving the screen back and forth and see if the picture changes. If neither of these solutions work, contact audiovox and see if it is cover under warranty.
Here is the website:
http://www.audiovox.com/webapp/wcs/stores/servlet/contact_us.jsp?type=nprev&catalogId=10001&storeId=10001&categoryId=874323&langId=-1&page=&urlString=&productId=&brand=
Jun 30, 2008 | Initial IDM-1731 Portable DVD Player with...
Cannot read disc
prob. the laser i have an accurian(radio shack) portable dvd with the same issue. spin motor fires fine but says no disk. just because the laser "lights up" dosent necessarily mean the read section works also. if anyone has a solution to locate a suitable laser please post here as i have a ton of lasers from various drives etc.
Apr 18, 2008 | Audiovox D1708 Portable DVD Player
No power
Apparently Audiovox does not support the pvs33116 dvd player. Nor does the manufacturer Alco. Support and accessories can be found at http://www.1800customersupport.com/products.aspx?type=pad&view=1385&p=75&sc=5
Thus one can purchase a $15.00 ac adapter, $20.00 battery, or a $10 dc adapter for a dvd player that's worth about 10 cents.
Nov 21, 2007 | Audiovox D1708 Portable DVD Player
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Audiovox D2010 Portable DVD Player with Screen Logo
257 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
