Question about Curtis CM19033S 19" TV
TV Reset Problem
My question is "Does the TV set have a RESET button?" If so, "How do I RESET it?"
I have a Curtis Mathes Tronic Color TV, Model CM19001, and Date October 1999. I purchased it new from K-Mart, and used it a few months, so it setting unplugged for years. About 6 months ago, I began using it again. It has a perfect picture. I cannot locate the TV Manual.
I must have accidentally press the wrong button when I (thought that I) turned it off this afternoon. When I got back home, the screen says plug in the AV Jack. I only have Cable TV plugged into the set, nothing else.
I tried to use the remote control, but the TV will not respond. I have tried fixing the problem manually from the TV set. It responds from the TV set, but I cannot get to the Setting menu.
Alternatively, do you have any other suggestions for correcting the situation?
Thank you for any help you can provide in this, and I look forward to hearing from you.
Re: TV Reset Problem
Trying setting it on fire, let it burn for about a half hour then come back to it. should work like a champ then
Posted on Dec 19, 2009
  • 39 Answers
Posted on Nov 21, 2007
0 characters
3 Points
I am trying to adjust the brightness on this circa 1980 floor model solid state tv
The contrast setting controls the relation between the light and black areas of the screen. If the light areas are too bright and are losing details, press the CVOL button; if the picture is gray and lacks contrast, press the VOLB button
The brightness setting controls the overall amount of light in the picture. If the picture is too bright, press the CVOL button; if the picture is too dark, press the VOL B button
The color setting controls the intensity of color.
Curtis Mathes CM19102 Owner Manual Returning To The Factory Settings...
Apr 09, 2016 | Curtis-Mathis Standard (CRT) Televisions
How do I change a Curtis Mathes Analogue to Digital
You can't. The only way to change it would be to go and buy a new TV. Unless you're asking about hook a game console to it, that's a different procedure. The analog refers to the internal workings of the TV its self.
Nov 07, 2014 | Standard (CRT) Televisions
Screeen color is green
This fault is called one color predominant screen. The cause might be to its video output card itself. There will be some loose solder terminals around the Green video output transistor. Check this card for any loose solder terminals. Just re-solder all the suspected solder terminals by applying a little more solder, without making any solder bridge short in between adjacent solder terminals. This card can be located at the neck of the picture tube [a rectangular board], will be directly plugged on to the back of the picture tube.
Dec 27, 2012 | Curtis-Mathis CM27101S TV
Can I reset the parental control on a curtis mathes model number cmc19101
Download the user manual to your TV from net. It will have all details. To download it, click here.
Actually Daewoo and Curtis Mathes TVs have same motherboards inside.
May 26, 2012 | Standard (CRT) Televisions
While moving my parent's Curtis Mathes Cm19001 TV produced in 1999, I touched the channel button which took the TV off of channel 3. We've tried to use the channel buttons to return to channel 3,...
I have one of this tv model too.Just used a RCA component cables like Y,R,W hook one side to the tv Video IN INPUT holes and the VCR the other end of the cable to VCR Video OUT INPUT holes.Now just pushes a channel manual button up or down a couples for the tv go into VIDEO Mode.Play the dvd player it will work.Or try to buy a tv original remote.Return the universal remote.
Jun 18, 2011 | Curtis-Mathis CM19011 TV
How do you reset your Curtis Mathes Tv after the
May 14, 2010 | Standard (CRT) Televisions
My Curtis Mathes television will not turn on. Stand by button is on but television remains unresponsive.
Curtis Mathes not Sony,same porb.Ur high voltage it dead,the FBT,the flyback transformer it dead,the big block of plastic with a cap hook to a CRT(tv tube).
Sep 28, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Need code to program Zenith remote control
Try these codes for your remote and TV. The are the Zenith codes for a Curtis Mathes TV.
CURTIS MATHES.....002 103
............................. 112 502 506
..................... 512 601 701 704
These should work.
May 09, 2009 | Curtis-Mathis CM25011 25" TV
Curtis Mathes TV Remote Control Codes for Programming the remote to the TV
I own a One-for-All universal remote, and my booklet says the setup code for a Curtis Mathes TV (without a built-in DVD or VCR) is one of the following numbers: 0030, 0047, 0054, 0060, 0093, 0145, 0154, 0166, 0451, 0702. I can not guarantee these numbers will work with your remote, but it is worth a try.
Jul 03, 2008 | Curtis-Mathis CM32010 TV
Curtis CM19033S 19" TV Logo
962 people viewed this question
Top Curtis Standard (CRT) Televisions Experts
Martin Murray
Jaime Hernandez
Are you a Curtis Standard (CRT) Television Expert? Answer questions, earn points and help others
