Question about Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder
Trying to find ac adaptor for Medel top box
Trying to find ac adaptor for Medel digital top box
  • 86 Answers
If you cannot get the replacement, try one with same voltage & ampere. Replace the DC plug if necessary
Posted on Jul 23, 2009
I have a Sansui beat box with usb & sd card facilities.May I playback flashdrive or sd card using ac power or must playback only use dc power???
You could plug it to ac and try to play your usb or sd card mp3format. There are some rechargeable equipment that does not work while plug into ac, because the use of the ac adaptor is primarily for charging the battery. Yet like laptop, or portable dvd you can use it while it charges the battery.
Mar 08, 2013 | Cameras
My Kodak m1033 will not stay on. Once I press the power, the screen is blurry and then it shuts off.
If your using the battery which is included on the box the KLIC-7004 try to clean the 3 metal contacts of your battery using a clean dry cloth. hen charged the battery using AC adaptor or USB cable., Now if this not work, Try to turn On the camera using the AC adaptor if you experienced same problem it means the your camera is defective, But if you can turn On the camera using AC adaptor It means the battery is the cause of the problem
You may call tech support toll free 1 800 235 6325 ext 12
Nov 13, 2009 | Kodak EasyShare M1033 Digital Camera ...
My kodak camera m853 won't turn on at all. it was working when i charged it with my psp charger. i lost my computer charger. is there any way it can turn on?
Try to clean first the 3 metal contacts of your battery I Believed you are usign the recommended battery that came from the box (KLIC-7001). Now you may try to charged your battery Using 5V AC adaptor and also you can Turn it on using the Adaptor
Nov 08, 2009 | Kodak EasyShare M853 Digital Camera
I need to know where I could find an AC adapter for a memorex iMove boombox...
It depends on what kind of power jack the device uses. If it is standard, then any department store or "box" stores sell universal ac adaptors with multiple size power jacks. Just make sure that the adaptor power is enough to drive your boombox.
Dec 11, 2008 | Audio Players & Recorders
Laptop does not work with AC adaptor, does not charge. Mother board issue
You may be able to get a battery charger but its rare.
If you do wish to use the AC adapter, take care with positive and negative. Also the voltage of the battery is actually lower than the AC adapter in order to get charged. I don't know what is going to happen if you do choose to use AC adapter as battery. 75% chance that it will work.
Oct 08, 2008 | Dell Inspiron E1705 Notebook
Battery on lap top is not charging
switch off - disconnect ac adaptor - wait 3 seconds - connect ac adaptor - repeat about 20 times.
Is charge light blinking when you connect ac adaptor?
Try reseating battery.
If battery is old (over 2 years) or heavily used then it may need replacing. They only last for 250-500 complete discharges.
Aug 08, 2008 | Evesham Computers & Internet
Lightning strike ac adaptor is fried
Your phone did expirence a surge that probably blew the ac adaptor which happens most of the time, u can buy one of those universal adaptors and look on the back of the old adaptor for the output voltage it will usually read between 3 and 8 volts DC.Set the universal adAptor voltage to the setting right below the voltage output on the back of the ac adaptor.
Aug 04, 2008 | Uniden Cordless phone EXS9950
Lap top problem
Hi
If the AC power light is blinking, try the following steps:
1 Cut off power to the computer by disconnecting the AC adaptor and removing the battery. The error condition will be interrupted, and the AC power light will stop flashing.
2 Put the battery back into the computer. Do not connect the AC adaptor. Try turning the computer on again. If the computer starts normally, the AC adaptor may be
defective and will need to be replaced. If the AC power light starts flashing, remove the battery, and continue with the steps below.
3 Connect the AC adaptor to the computer. Leave the battery out of the computer. Try turning the computer on again. If the computer starts normally, the battery may need charging, may be depleted, or may be defective. Turn the computer on, insert the battery, and then leave the computer running for several hours, which will deliver a slow, steady “trickle-charge” to the battery. Once the battery has been trickle-charged, it may begin working correctly again. If the trickle-charging does not prove effective, consider replacing the battery with a new one.
4 Connect the AC adaptor to a different power outlet, preferably in a different room. If the computer starts normally, there may be a problem with the AC outlet itself, or the voltage level available from it.
5 Verify that the AC adaptor is the correct unit for your computer model. The computer may not be able to start from an AC adaptor that is rated for less current (amperage) than the computer requires, even if the rated voltage is correct, and the plug fits correctly in the DC-IN socket. The labels on the bottom of the computer and the AC adaptor show the specifications for voltage ("V") and current ("A") for each device. The voltage level must match exactly. The amperage rating of the AC adaptor must be equal to or greater than that required by the computer
Regards
Mike
Mar 21, 2008 | Toshiba Satellite 1805-S204 Notebook
Won't work
oh no maybe you used different adaptor some adaptor have reverse polarity. check the adaptor before plugging it..if you using variable voltage set to 3v then adjust also the polarity. the polarity should match the polarity of your camera.
Feb 05, 2008 | Kodak EasyShare C875 Digital Camera
Sagem PVR 6280 Freeview DTV Receiver / 40-Hours Video Recorder Logo
128 people viewed this question
Top Sagem Televison & Video Experts
electracon
ka4iup
ka4iup
 Mikey
Mikey
Are you a Sagem Televison and Video Expert? Answer questions, earn points and help others
