Question about Whirlpool Refrigerators
Lots of water pooling on top shelf of refrigerator, toward the back. It is not condensation. Water is apparently dripping down the inside back, as I noticed it has pooled under the veggie bins as well. The frig is at least 16 years old
  • chuneym Jul 24, 2009
    Thanks for the tip! My husband took off a plastic piece that hooked up to a hose on the back of the refrig. It was all clogged with gunk, so we cleaned it out and cleaned out the hole leading into the refrig. It was the only thing we could get to on the back of the refrig. I've layed some papertowels on the top shelf and we'll see if that fixes the problem tomorrow am.
    Thanks for such a quick response!!
    President:
  • 744 Answers
Hello, this sounds like you have a blockage in the drain tube, remove panel back of freezer..you may see ice build up...melt ice with hair dryer/heat gun...you will see a pan below evaporator...melt ice in pan...dry water up in pan with paper towel...now you should see a hole in pan that leads to drain tube...pour some hot water in pan..wait a couple minutes..mop up water and repeat this step 2-3 times....once you have done this find some flexible curatain wire or electrical wire..poke down the hole until you see the water drain..now it is clear..put back panel back and you are good to go. The reason you see water in the fridge is because the water has been leaking down the vent instead of the drain hole...If you need any further assistance please feel free to comment again. good luck! P.s Please don't forget to rate my solution thanks! Mike
Posted on Jul 23, 2009
  • Mike Price
    Mike Price Jul 24, 2009
    Hello again, I have a feeling that you cleaned the pipe for the icemaker, did the pipe go to a pan in the bottom or a water valve? in order to get to the evaporator drain you have to remove the panel inside the back of the freezer. Let me know if you still have a problem :)
The top of the inside of my 2002 Whirlpool refrigerator Model ET1FTK (top mount)is frozen and is dripping onto the first shelf.
The cause of that drip is going to be a blocked defrost drain in the freezer and the water from the defrost is pooling up in the freezer then when it can't hold anymore it's dripping through the vent in the ceiling of the refrigerator onto the shelfs. By removing the back wall of the freezer you could find the drain on the bottom of the freezer coil. By GENTLY peircing that frozen drain at a 45 degree angle until a small hole is formed in the built up ice it could be totally flushed using warm water once a small opening is made in the ice in the drain.
GENE
Oct 13, 2011 | Refrigerators
Hotpoint model #ctxy14epjrwh slow water drip from inside of the refrigerator. inside the top of the frig, center, there are several components that appear to come down from the freezer. the lowest one...
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the centeroldtech2332_52.jpg
Aug 24, 2011 | Refrigerators
I have a 7 year old 21 cubic ft., top freezer Frigidaire refrigerator. There is always water dripping down the back of the inside of the fridge, which then pools in the well in the bottom. It seems like...
syringe the tube with clorine bleach.dry out the interior then cover all food to cut down on condensation,although most freezers are "frost free"the fridges ARE NOT.so most of the problems are condensation.....
Sep 02, 2010 | Refrigerators
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water dripping from freezer onto top shelf of fridge with ice buildup back of freezer
the defroster isn't close enough to the drain to be effective. remove the back wall of the inside of the freezer, remove the excess ice. clear out the ice from the drain using hot water and a turkey baster. there is a kit from whirlpool that uses a piece of metal and a screw around the defrost rod, but I found out that a piece of 14 gauge solid core wire with the insulation stripped off works great too. stick the stripped wire into the drain, 2 to 3 inches, and wrap the rest around the defrost rod.
Jun 02, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Ice and water on the bottom shelf
the blower motor of your fridge which is located at the back panel of your fridge is not running
Mar 06, 2009 | Refrigerators
Condensation dripping from top of refrigerator
The problem is the defrost drain trough is plugged with ice. You will have to turn off the refrigerator, remove the freezer back panel and use a baby aspirator to help you apply and remove hot water to melt the ice. Then insert the aspirator in the drain hole to blow out any thing that may have gotten lodged inside. You will hear the water draining now to the pain underneath the refrigerator. Hope that helps you, good luck!!
http://tclaundryrepair.com/
Feb 25, 2009 | Whirlpool Refrigerators
Water drips from evaporator fan channel Frigidaire FRT17G4B
It sounds as if this is a top mounted refrigerator. (freezer on top) If this is the case, check to see if you need to defrost the drain. You could also have a problem with the door seals. Remember the air coming out of the vent is freezer temp minus a few degrees. It could be that the moisture is condensing in that area.
Feb 01, 2009 | Frigidaire FRT17G4B Top Freezer...
Water dripping into refrigerator from freezer
DRAIN TROUGH IS PLUGGED OR FROZEN. EMPTY FREEZER AND REMOVE LOWER TRAY TO SEE A HOLE ALL THE WAY IN THE BACK USUALLY IN THE CENTER. CHECK TO SEE IF WATER CAN DRAIN THROUGH BY POURING A CUP OF IT INTO HOLE. IF IT IS FROZEN POUR HOT WATER UNTIL IT THAWS, IF PLUGGED REMOVE THE OBJECT.
Jan 28, 2009 | Estate TT21AKXKQ / TT21AKXKT Top Freezer...
Refrigerators Logo
131 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
