Question about Dometic Rooftop RV Air Conditioner
AC Fan not working on Auto
I have to run the fan in manual mode and everything works fine
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 46 Answers
Ac can take up 2 ten minutes to reconize commands be patiant and stop pushing buttons wait desired ten minutes if does not solve problem faulty conrol box and if comfort cortol thermo try reset in owners manual
Posted on Aug 01, 2009
Fan doesn't work in heat mode it works on all other functions. Heat does come out but fan doesn't kick in. Outside unit is operating
AC inside fan doesn't come on AUTO - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 21, 2004 - The inside FAN doesn't run when in AUTO mode. If I leave ... Is the thermostat not working correctly or something in the AC unit causing it to do this? Thanx ... The unit is electric central air-conditioning(heat and cool). It made ... Carrier A/C condenser fan not working
Jul 27, 2012
Heater Fan Doesn't Work on AUTO
Jan 23, 2006
Blower doesn't work in ON position after repair
Mar 25, 2005
Central AC/Heat, Blower Doesn't work on Auto
Nov 30, 2004
More results from www.doityourself.com
Nov 01, 2015 | Heating & Cooling
Why heater fan will not come on?
Wish I knew how old your furnace is. Let me answer your question directly. In the heat mode the fan runs independently from the air conditioning fan relay. Its either brought on by time or temperature. An old furnace will use a fan and limit control that uses a coil to sense the heat exchanger temperature and turn the fan on or off. Newer furnaces use a timer on a circuit board. 20 years or newer Ill bet its a timer board. Follow the blower motor wires back to the component and ill bet that's the culprit. Hope it helps. Good luck.
Oct 12, 2014 | Heating & Cooling
Intertherm Furnace Model #mmhb070abhr06. Burner lights up but shuts down after about 10-30 seconds then recycles over & over again when fan is set to auto (because fan does not cycle on when set to...
Sounds to me like it is going off on a weak high limit switch. With the fan on it will prolong the event but will not stop it. I would check all of the high limit switches. It would most likely be one close to the heat exchanger.
Apr 06, 2014 | Intertherm 56000 Btu Gas Furnace
Ac fan motor won;t run
get a haynes repair manual at auto parts store or on ebay it will tell you everything you need to know to work on your own vehichle
Jan 16, 2013 | 1991 Cadillac DeVille
Fan wont run on auto
Make sure your tstat is programmed for electric, not gas. Or in the settings you want that the TSTAT CONTROLS THE FAN.
May 23, 2017 | Dometic Rooftop RV Air Conditioner
AC was weak so had it recharged. Everything was fine for the rest of the day. Next morning I started the car, turned on the AC, was putting junior into his carseat when the AC quit. I turned it off then...
read the owner manual to see how the auto works. try the defrost mode whcih is a fail safe mode and should always come on unless a major system issue.
Oct 15, 2010 | 1988 Jaguar XJ6
Fan will come on for heat(auto), but not for AC or set to ON
You have a blower relay in the furnace that's probably bad. In the heat mode the blower is on a temperature relay, in cooling mode the blower has to come on immediately so there is another relay for cooling. The green wire on the thermostat feeds that relay, so if you go to the furnace and shut the power off and find the green wire from the thermostat that feeds that relay and replace it, being careful to mark all the wires before removing them, also the relay terminals have numbers for identification.
Apr 07, 2009 | Heating & Cooling
Blower fan will not come on when set on Auto in heat mode.
the fan is controlled by a fan center or a stack switch. as burners light and heat up the spring sensor on the bulkhead above burners heats up and turns and a a point energizes the indoor fan if it gets to hot the burners go out on safty. sounds like a fan control is bad tap on them gently and they sometimes break loose but if not then have a pro replace fan control and test heat exchanger.
Oct 24, 2008 | Ruud UBHC Air Conditioner
44860 thermostat won't activate in heat mode
I had the same set and problem. I had a RC wire which is the power to the AC. But didn't have an RH wire which is the power for the heat. To fix this just use the jumper wire and insert it in with the RC wire and hook it up to the RH. Fixed my problem.
Oct 20, 2008 | Hunter Fan Company 5/1/1 Programmable...
1998 Sonnybrook travel trailer
Did it just start to do this, or has it always been that way? Are you original owner? Did it work fine before? Make, model# of AC unit & thermostat would be of help too.
Aug 22, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
134 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
