Question about Cameras
Hi, I have loaded 160 photo's on to the hard drive. The machine will run through all of the photo then a few more photo then reverts back to the restarting view again. I want the pictures on the Photo Frame to run 24/7 but can not understand what will make it do this. I have a Kaiserbaas 15". I have tried going back to Default to see if this will make a different but with no luck Can someone help please? Regards Musharella
  • 1 more comment
  • bpuglisi Jul 23, 2009
    Hi Benjamin,
    Hopefully I have just loaded across to the Photo Frame hard drive the 'firmware upgrade' that you have suggested. I am now re running the 160 photo's and will let you know what happens? and if it has sorted the problem. Thankyou - fingers crossed and I will let you know tomorrow.
    Regards Musharella
    Hi Benjamin,
    Sorry that was short lived - did not fix my problem sorry. I have doubled checked that the firmware updates loaded across and yes it did both programs. This time it only ran through half of the photo's for one reason or another.
    Regards Musharella.
  • bpuglisi Jul 25, 2009
    Hi Benjamin,
    I have check everything inside and out and can not work out why it is doing what it is doing.
    Phoned a help line as well for Kiaserbaas and they were useless to deal with.
    Have now taken it to a computer technician and he is going to have a look at it.
    Thanking you Musharella
  • 3,037 Answers
First try downloading a firmware update for your unit. You can do this at the following website link
http://kaiserbaas.helpserve.com/index.php?_m=downloads&_a=view&parentcategoryid=9&pcid=0&nav=0
If that doesn't work, let me know as the upgrade should allow it to continue, otherwise you can call 1300 302 306 if you want faster help on this as there is no reason that the unit should not continue through since it does start over at one point at the beginning and the only thing I can think of is an error in the software since you reset it and have it running on one big loop. Let me know how this turns out.
Benjamin
Posted on Jul 23, 2009
  • Benjamin Patri
    Benjamin Patri Jul 23, 2009
    You have checked all of the settings on the picture frame, right? I think you might have a faulty frame if you just got this unit, if you did, take it back and exchange it as it should work fine right out of the box. Otherwise, these things are so simple that there really shouldn't be any problem other than bad firmware or it wouldn't work at all, so as long as all settings are fine which you should go through again just incase something is messed up(again I don't know why anything would be), then I would determine that it is a bad unit. Let me know what you find.
  • Benjamin Patri
    Benjamin Patri Jul 25, 2009
    your welcome, I'm sorry that your still having so much trouble with this. Let me know what you find out is wrong with it
My system says no hdd detected. how do u fix this
a few possibilities:
hard drive plug came disconnected somehow
hard drive plug/wires are bad
hard drive is shot.
you may want to try to contact the manufacturer before attempting to open it to find the problem, if your hard drive is bad you will probably need to get the operating system/format programming to load onto a new hard drive. best bet is to find a contact for them and see if they sell replacement parts, my guess is the hard drive is bad. it happens, it sucks, and it can be expensive, the upside is if you are careful and take your time it is usually pretty easy to take the bad one out and put a nwe one in... good luck
Sep 01, 2012 | SWANN 4-channel/camera Dvr Surveillance...
Download photos
click start all programs accessories open windows explorer navigate to your photos the files right
click on the photos right click copy navigate back to the destination drive right click select paste or hold the mouse cursor the photos drag them to destination folder then drop them in
or if you are downloading photos from the internet
once it starts downloading windows will ask whether you want to run or save it
a browse option will open you can save it into a folder in my documents or another device floppy or a usb device
if you need more help with this post a reply
hope this helps
Aug 24, 2012 | Seagate Expansion 1 TB USB 2.0 Portable...
Instructions how to transfer my photos from picasa to scandisk cruzer 4GB
hope this helps
Jul 28, 2012 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
FEW 12 will wash and drain but wont spin
Hi
Thanks for using FixYa. Please check if some small clothes have been stuck in the water pump. If so, please take them out and clean it. The Water Pump is mounted directly to the motor. If still the issue persists, then it seems that the drive motor has gone bad if it fails to start after the water is filled up to the required level and if the motor is running but the agitator is not moving then it means that the drive motor belt is excessively worn. Please check and replace whichever is required. Also please check and reset the circuit breaker and check the fuse. Please remove the debris from the drain hoses and the drain. If it is clogged, clean it. Now close the door and press start/stop button and it will start to spin after the door is locked. Please revert back for further assistance.
Thanks
Rylee
Dec 23, 2011 | General Electric Washing Machines
Toshiba 320GB MK3265GSX SATA hard drive don't recognize by the bios... it's broken... help me recover my files
If BIOS doesn't detect it either the data/power cables are bad or not making a good connection, or the drive has failed.
Nov 20, 2011 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
My eMachines T3882 with Windows XP just reboots over and over
Sounds like a sick hard drive. When it starts to reboot, press F8 and choose Windows Diagnostic Test. It will show a hard drive failure if one exists. If it finds a hard drive error, the hard drive is junk and needs replacing. Once replaced, you can run your restore/recovery disk to install Windows back to the condition it was in when you bought it.
Dec 16, 2009 | E-Machines eMachines Desktop PC
New 160 gig hard drive, can't load XP on Fujitsu S6210
Insert the new hard drive in your laptop, boot up and go into the BIOS.
Check if the hard disk setting is set to Auto (detect). Check the system configuration and see if it detects the hard disk.
If there is a hard disk diagnostic utility within the BIOS, run it to check the hard disk.
You can also test the hard disk by booting up with a boot floppy disk, run fdisk.exe to see if can display, create a partition, and format the hard drive etc.
If not of this works then it is highly possible that you have a faulty disk controller in your laptop.
Dec 18, 2008 | Fujitsu S6210 Notebook
Undelete/unformat a Mac formatted external hard drive.
The theory to unformat a Mac hard disk is, when you format a Mac HFS+/HFSX Volume or format a external hard disk, the data are not really wiped. Format process just marked your Mac hard disk as available to reuse, no matter it is quick format or complete format. So if you put if you fill in a mount of new data to your hard drive, then the formatted data are overwritten, your will permanently lose your formatted data.
Follow this guide to unformat your mac hard drive or formatted external hard drive on mac.
Jul 26, 2008 | Computers & Internet
Accidentally erased yahoo account and now cannot get back into account. If I revert my hard drive back to october 2007 would that fix my problem? My son erased all those files in October 2007 and today I...
Yahoo emails are saved on the internet by default. All you have to do is go to Yahoo.com, log into email and they will be there. If you forgot you password there is an email reminder option.
If you are talking about using Windows Restore points that will not bring back deleted files.
Hope this helps!
Jun 21, 2008 | E-Machines Computers & Internet
Lost all video files from harddrive
Hi, John. First things first - do not take more photos and do not save anything back to the camera memory card. Then connect it to your PC. Pick a digital camera recovery (recover photos, video, music files) to make a free scan and recover the deleted photos. Regards
Dec 09, 2007 | JVC Everio GZ-MG21 Camcorder
Cameras Logo
27 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
