Question about Kenmore Oasis HE 27082 Top Load Washer
My problem is the washer do not put in enough water to wash my clothes on any of the cycle except for sheets and towels. my clothes are not getting clean because it dosen't get enough water to clean the clothes. I do not like the washer at all. If we had taken it back when we got it they would have charge us $300.00 to reinstall. I felt so taken after learning the cost we would have had to pay to return the washer.
    Problem Solver:
  • 19 Answers
U not full the washer u see the capacity of washer
eg.7kg, 15kg u see the capacity then u use
Posted on Jul 23, 2009
    President:
  • 744 Answers
Hello, Sounds like you have a problem with your pressure switch. If you access the control panel and look for a part with a plastic tube going to it that is the pressure switch. Try pulling the plastic tube off and blowing down it. once reconnected see if that does the job. If you are still having a problem after you will have to change that switch. Good news is the part is very inexpensive :) Good Luck!! Please feel free to comment again if you have any questions or concerns. Mike
Fisher Paykell washer left black grease spots on some clothes
9 WASH PERFORMANCE INFORMATION
9.1 Creasing
Creasing can be caused by over loading the washer or the dryer. Permanent Press or Delicate
cycles have been designed to minimise creasing as they use a lower spin speed. Do not leave wet
clothes to sit in the washer or laundry basket.
9.2 Soiling
Soiling is the result of insufficient detergent for the load. White clothes are better washed
separately. Separate lightly and heavily soiled items, as clothes can pick up soil from dirty wash
water. Cold water below 68oF / 20 oC does not wash effectively. Select the wash temperature
according to soil type. For example, blood and mud are better washed in cold water, while sweat
and oil based soil wash better in warmer water. Loads made up of articles of varying sizes will
wash better (e.g. full loads of sheets may not wash that well). Hard water requires more detergent
than soft water.
9.3 Linting
Wash lint givers (eg. towels, flannelette sheets) separately from lint collectors (eg. synthetic
fabrics). Over loading the washer can increase the likelihood of linting. Insufficient detergent for
the load can increase linting as there will not be enough detergent to hold the lint in suspension.
Over drying synthetic fabrics in a dryer can cause a build-up of static electricity and result in the
fabrics attracting lint.
9.4 Detergent Residue
Over loading the washer can result in detergent residue being caught in the creases of the fabrics.
If this occurs, decrease the load size. Some detergents need to be pre-dissolved. Check the
instructions for the detergent. Cold ambient temperatures, cold washes or short agitation times
may not let the detergent dissolve properly. In these cases pre-dissolve the detergent.
Overdosing of detergent can also cause residue when foam breaks down and will show as white
specs on the clothing. Poor quality detergents can result in residue.
9.5 Black Marks on Clothes
A build up caused by the interaction of fabric softener and detergent (scrud) can flake off and mark
clothes. Do not use too much fabric softener, maximum 75cc. If this is a problem, it is
recommended that the machine is periodically filled with hot water, plus 1-2 cups of dishwasher
powder and left to soak.
9.6 Grey Marks on Clothes
Not enough detergent for the amount of soil on the clothes can result in grey marks on clothes. If
this is a problem it is recommended that the machine be periodically filled with hot water, plus
detergent and left to soak.
9.7 Dye Transfer
Wash and dry non-colorfast clothes separately. Non colorfast clothes left sitting in a washer or
laundry basket can transfer dye to other clothes.
9.8 Tangling
Washing with too much water (i.e. under loading) can cause the clothes to tangle around each
other. Do not load the machine by wrapping clothes around the agitator.
Sep 21, 2012 | Fisher and Paykel GWL11 Top Load Washer
I just purchased my Cabrio washer...have had it a week. When I use the normal cycle, the machine does not spin the clothes at the end of it so when they cycle is done the clothes are dripping wet. I then...
I have had my Cabrio washer a little over a year. No it isn't suppose to do that. There is a setting for spinning high medium and low spin. Maybe you can change the spin setting manually. See if that works The washer is computer operated so the spinning cycle must be out on your normal cycle. I did myself a favor and I keep all clothes on towels and sheets. I set the temp for the water on what I would like manually. The washer fills up with more water and seems to clean the clothes better and My washer does the same thing from time to time about not spinning. Just remember you can set all wash manually with water temp and spin cycle. Is your washer still under warrenty?
Jan 03, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
After final rinse and spin cycle clothes are still wet
I can't solve this but am having a similar problem. There is no water in the tub but the spin cycle does not get enough water out of the clothes and they're very wet. This causes the towels especially... to smell really bad. The tub is very loose. How can this be fixed.
Jul 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Lint collecting and sticking on some clothing
Did you sort properly? sort lint givers(towels) form lint takers(syenthetics)
did you over load the washer? the wash load must be balanced clothes should move freely in the water
did you select to correct water level?
did you suse enough detergent? use enough detergent to hol the lint in the water
Did you line dry your clothing? if so you can expect some lint on clothing?
check the following:
was paper or tissue left in the pockets
is your water colder than 70 decrees F washe water colder than 70 decrees may not completely dislolve detergent
did you use the proper cycle time for the load? reducing the wash time is another way to reduce lint
Jul 16, 2009 | Maytag Neptune FAV6800AW Top Load Washer
The washer does not spin during washing cycle or drain & spin cyc
I can a very simple part called the motor coupler...you can find the part at www.repairclinic.com. It costs 13.95. I am fixing my washing machine today, as this happened before and was the answer. Goodluck
Apr 11, 2009 | Kenmore 46462 Front Load Washer
Whirpool Cabio washer knots clothes/sheets into tight balls
whirlpool had a service bulletin on this. New agitator design. replace with new design.
Mar 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Close very wrinkled
I have the same problem with clothes being very wrinkled and clumped together after a full cycle. I believe it is not because of the spin cycle, but because the washer using very little water to wash the clothes, so they bunch up easily and are not free flowing. NOW, I try to use the cycle that uses the "Deep Clean" action or I activate it manually with all other cycles. It adds more water to the cycles and the clothes come out wrinkled, but not as much. Try it.
Feb 23, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops during wash cycle
you may a pluse cycle where the washer will stop for a couple of min, this cycle is for perm press to minimize wrinkels
Nov 12, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Bad smell
washers and dryers dont make smells themselves its a problem with something u might be putting in it. if u tend to add alot more detergent then usual to your towels then they never completely rinse the water out and will have a mildew smell
Feb 18, 2007 | Whirlpool GEW9250P Electric Dryer
Kenmore Oasis HE 27082 Top Load Washer Logo
81 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
