Question about Boating
2005 ele start 25hp merc, starts with rope not with ele start,it trys
    Champion:
  • 207 Answers
If it trys to turn over and is not strong enough then u need to check your battery to see if it has a dead cell if battery is ok then you need a new starter the spindle in the starter is going bad if it doesnt turn over at all or makes a clicking sound then u need a starter solenoid it is located on the side of the motor the best way to find it is to follow your main power leads from battery and then power lead to the starter the device that the leads bolt to is the solenoid it will have 2 studs up top and 2 acc leads on bottom let me know follow steps in order
Posted on Jul 27, 2009
25 hp merc. have replaced push button switch and solenoid.have power to solenoid and start it by jumping the solenoid. starts fine pulling rope.no response at switch.
With the info provide, sounds like you still have a bad solenoid..
1. Take your battery to a battery shop and have the cold cranking amps checked.
May 17, 2017 | Seloc Mercury Outboard Engine Repair...
25hp pull start cord not retacting spring has been replaced
When fitting any pull start spring, you must first pre wind the spring. Once the spring has been at least 1/2 way wound up or tensioned, wrap the pull rope around the spool. When you assemble it and pull the cord, the spring should wind up further to its fully wound position and now retract as normal. If you don't prewind the spring, there will be little or no tension to rewind the rope.
Sep 25, 2014 | Garden
1974 40H.P. mercury outboard been setting up for 10to12yrs
This is probably a Merc 400 and you can remove the upper cowling and rope start it if you do not have the rope starter already attached. As I recall, all of this class motor were manual start with optional electric start, so thy came equipped with pull starters.
If the motor will not turn over manually then it is likely seized or frozen up and requires professional help. I have worked on numerous Mercs from 5 to over 100 HP and every one would turn over by pull starting if they were mechanically sound.
Apr 10, 2014 | Clymer Mercury 3.5-40 HP Outboards...
Black arms in clutch dont allways come out and catch when rope pulled. Chainsaw rope pulls out without catching and turning over to start. What should i do?
Most Stihl starters that i have seen rely on the r clip securing the pulley on being a tight fit on the shaft, this creates a friction, as the pulley turns the clip trys to stay still and in turn pushes the pawls out, remove the clip and squash it close together to create a better fit on the shaft
Jul 09, 2011 | Stihl Chainsaw 045 056 Clutch Chain Saw...
What is the corrct fuel mix for 2005 25hp johnson
2 stroke is rated at 100 to 1... but I always run it a little more like 50 to 1. I would rather put plugs in it than burn up a motor for lack of oil......
Dec 25, 2009 | Boating
2005 cevy malibu will not start. It trys it jus
Sounds like the stater is spinning but it is not making contact with the flywheel. I guess it is time for another starter.
Dec 01, 2009 | 2005 Chevrolet Malibu
Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
