Question about Faria Chesapeake Series Voltmeter Gauge
Alternator test shows 14 volt meter stays at 10 and sometime jumps to 12
    Scholar:
  • 76 Answers
Assuming that you checked alternator voltage at the alternator itself, this would indicate that you have a bad guage or bad connections elsewhere. Start by pulling the dash panel out and measuring the voltage behind the guage. If the voltage is 14 or so then you have a bad guage. If the voltage is low, check around in other locations behind the panel to see if you can find better voltage there. If not, you need to start tracing the charge circuit to find out where you are loosing voltage. You may have a bad engine ground.
Posted on Aug 13, 2009
My Volvo s60 battery died jumped got it started let it run 10 mind tried again now nothing
Sounds like 2 possibilities, A) your alternator is not charging the battery or B) your battery is pooched.
To check your alternator, 1) without the engine running apply a volt meter to your battery, it should read somewhere around 12 volts. 2) boost the car, and with the engine running test your battery again, it should read approx. 14-15 volts.
If it reads 15 volts, your alternator is fine, and your battery is suspect, if it only reads 12 volts when running, then your alternator needs to be replaced.
Oct 17, 2015 | Volvo Cars & Trucks
2003 bmw x5 4.4 battery light stays on
Brother Mark, changing the battery with a new one being done won't make the light go out, as you noticed. Light is still on so you changed the alternator. Good, but the battery light is STILL on. This only means that the charging circuit from the alternator is not working in the voltage regulator or the wiring is not connected properly to the alternator/regulator. A new battery will show over 13 to 13.5 volts not connected. An old battery will still show 12 volts and still be weak or bad. After connected and engine running, the system will show at least 14 volts because alternator/regulator is working properly, using a voltmeter/load tester connected to the battery. If after replacing the battery and alternator it is still reading 12 to 13.5 volts, it is not working and the light will stay lit on the dash. You may have purchased a faulty alternator if the system tests out this way. Have your system checked with a volt meter or load tester bit be sure all the connections are proper and clean.
Mar 26, 2014 | BMW X5 Cars & Trucks
2010 flhx battery fully charged but starter drags bad then clicks. Jumped power from car, still does the same thing.
Hi Anonymous, perform the following tests:
1. Fill acid type batteries to proper levels.
2. Charge battery overnight at 1-2 amps you need 12 volts or better after charging.
3. Make sure all connections are clean and tight especially the negative cable at both ends.
4. Hook up volt meter to battery and start engine, if meter falls below 9.5 v replace battery.
5. With engine running at 3600 RPM battery should read 14.3-14.7 volts if not continue tests.
6. Unplug voltage regulator from alternator at crankcase by front of primary cover.
7. To test voltage regulator go to: https://www.youtube.com/watch?v=F8EjV0IjW9Q
8. With ohm meter, one lead grounded, touch alternator pin meter should read infinity, if not replace stator.
9. With ohm meter, both leads touching alternator pins meter should read 0.1 to 0.2 ohms on 1989 and later models. 0.2 to 0.4 ohms 1988 and earlier models, if not replace stator.
10. With volt meter set on AC scale, both leads touching alternator pins meter should read
16 to 20 volts AC for every 1000 RPM'S 1989 and later and 19 to 26 volts AC for every 1000 RPMS. If not replace rotor. Good luck
Jan 01, 2014 | 2010 Harley Davidson FLHX Street Glide
Intermittent alternator
Hi Denny, perform the following tests:
Sep 09, 2013 | Harley Davidson FLHTCUI Electra Glide...
Replaced battery. still would not start. Cleaned treminal of all corrision. cranked fine. however 1 day later would not start. jump started . drove a couple of miles but when I turned on lights, engine...
Sounds like a bad alternator. Drained your battery and when you turned on the lights it took all the power left in your battery. When you drain a battery down that far, they are real hard to jump, and coupled with the alternator, the car is not producing enough current to start and stay running.
I would take the alternator off and take it to oyur local auto parts store to be tested. If bad, replace it and charge the battery fully before starting. Then check voltage at battery with motor running. Should be 13.2 -14 Volts DC. If not, you may have a bad battery cable or blown fusible link. (especially that if the alternator tests good).....Mike
Jun 15, 2011 | 1996 Ford Explorer
I have alternator charging battery problems on my 1991 Chrysler Lebaron LX 3.0 Liter V6 Convertible. Any ideas?
hello there:
you're problem may be in the alternator or the battery to find out you will need a volt meter and have the vehicle running to test the alternator set you volt meter to dc voltage and touch the positive side with the red lead and the negative side with the black lead you should show 14 to 14.5 volts if not replace the alternator then with car off using the volt meter and test the battery the same way you should get 12 to 13 volts then wit the volt meter still hooked up to the battery with the help from someone try to start the car and see if the voltage drops below 10 volts if so the battery might be shot....hope this is helpful best regards D.Jones p.s please leave a review thanks
May 30, 2010 | 1991 Chrysler LeBaron
How can i tell if my starter is going bad? I had
It may not be the starter. The battery could have a weak or dead cell in it and not holding a charge.
The alternator could be bad and charging the battery.
If you have a volt meter, or can get one, with the car running, put the leads from the meter to the battery terminals, red positive, black ground.
Put the meter switch to 12 volts. If the meter reads 14 to 15 volts, the alternator is ok, below that it isn't charging. If it does read 14 to 15 volts, replace the battery.
By the way, the starter is ok, or it wouldn't have started with a jump.
It's more a battery/alternator issue. Clean the battery terminals first and see if that makes a difference.
May 11, 2010 | 1999 GMC Jimmy
Will a bad Alternator stall the engine
It can, if it's not keeping the battery charged up.
Have it tested, or take a volt meter, put switch to 12 volts, put the leads on the battery terminals, red to red, black to black, if the the meter doesn't show at least between 14 and 15 volts, the alternator is bad.
Nov 10, 2009 | 1992 Nissan Stanza
My 2003 FX35 won't start without a jump start. I would drive 40 miles home, turn off the motor to open the garage door, and the car won't start anymore without a jump start. Tested using a multimeter...
I think your battery is weak, where as it doesn't have the cranking amps when you first go to start it. What i would recommend is doing a load test on the battery to tell for sure if it is good or not. If you have an advance auto or auto zone near by, they offer that service for free, and if need be they will install your new battery for you.
Dec 16, 2008 | 2003 Infiniti FX35
Faria Chesapeake Series Voltmeter Gauge Logo
353 people viewed this question
Top Faria Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Faria Boating Expert? Answer questions, earn points and help others
