Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
Water leaks from left (freezer) side
I believe it's a stopped up drain tube from all my research, but don't know where the drain is to try and flush it. GE Profile 2001 side-by-side model.
  • GE Master
  • 4,655 Answers
The drain ends in a pan next to the compressor and should hold about 3 cups of water. The drain begins in the back of freezer behind panel and below the evaporator coils. I have more information if you like, let me know. Sea Breeze
Posted on Jul 23, 2009
    Problem Solver:
  • 19 Answers
YOU WILL HAVE TO TAKE THE FLOOR PANNEL UP IN THE FREEZER.YOU WILL SEE THE EVAPORATOR COIL GENTELY LIFT IT UP THERE IS A DRAIN HOLE IN THE CENTER REAR
IF IT IS FROZE UP WITH ICE THE WATER CAN NOT DRAIN OUT SOME UNITS USE A SMALL DRIP PAN HEATER TO KEEP THIS FROM FREEZEING UP LOOKS LIKE A WHITE SHOE STRING WITH WIRES ON EACH END YOU MAY NEED TO REPLACE IT.
Posted on Jul 27, 2009
Ice build-up at bottom of GE Monogram refrigerator. Ice melts and leaks onto floor. How do I resolve this problem?
The drain hole is blocked, so water is not drain and getting freezed, and then melting and it leaks.--------the drain is stopped up ,, remove the inside back panel inside the freezer and pour hot water into the troft under the coil in the back and flush the drain ,, once water runs though the drain hole then put the panel back in and it will be fine.
The drain tube is located below the pan below the fins at the rear of your freezer. The drain tube has a trap (s-shaped curve) to prevent air flow out of the freezer. The problem is that water gets in this tube and freezes. You can take the sheet metal cover off the back, get a turkey baster and flexible tube, and continuously flush hot water.this will clear the clog.--------- Thanks.
Sep 13, 2011 | Refrigerators
My monogram refrigerator leaks water from the upper left side/top of the freezer.It is a model ZIS- 42
you have a blocked/frozen evap drain tube leading to the pan, located directly above the freezer section. in all honesty donot believ this to be a repair homeowner should attemp i would contact an authorized ge servicer.As a maytg/ whirpool servicer myself , i know in our built in refigs we have new heated drain tube/evaporator pans that we installe possible that GE has as well
Mar 14, 2008 | Refrigerators
Water drips in bottom shelf of freezer, creating a piece of ice and then water leaks under refrigerator
Sep 13, 2011 | Frigidaire Refrigerators
Water leaks out the left front. Water seems to pool and freeze in the bottom of the freezer. The leak is not alot but it never stops. Have checked for level have disconected the water and ice maker. Still...
You have a plugged up defrost drain. There should be a drain hole way in back of the freezer, at the bottom. (it should be behind the panel at the back of the freezer compartment) Use a turkey baster with warm water to flush it out until water runs out the hole into the defrost drain pan under the refrigerator.
Dec 08, 2009 | Maytag MSD2756G Side by Side Refrigerator
Water leaking in the freezer
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer
or
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Nov 05, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker is not making ice and water leaks from bottom.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Ice Maker
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 21, 2009 | Hotpoint HSS25GFP Side by Side...
GE side by side leaks water from icemaker tube
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Leaking water sometimes from bottomleft hand side
DEFROST DRAIN IS STOPPED UP .LOOK FOR ICE IN BOTTOM OF FREEZER.USE TURKEY BASTER AND HOT WATER TO THAW AND FLUSH DRAIN TUBE
Jul 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water leaking/freezing in bottom of freezer
Jul 12, 2009 | KitchenAid KSRA25ILWH / KSRA25ILBT /...
LEAKING UNDER BOTTOM OF REFRIGERATOR UNDER FREEZER DOOR LEFT CORNER
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 08, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
225 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
