Question about LG LSC26905TT Side by Side Refrigerator
M# 596.72219200 Kenmore with bottom drawer refrig keeps freezing
M# 596.72219200 Kenmore with a bottom drawer freezer. Refrig keeps freezing especially the top shelf and two bottom veg drawers. Started after I had frozen a lot of food for Grad party. Put 5 gallons of frozen chicken in the refrig to defrost. Added 3 gallon jugs in freezer. All that is gone and done with. Completely emptied and cleaned regrig and freezer thinking something got blocked and frozen in the system. Was okay for a while now it is back to freezing in the refrig again.
  • LG Master
  • 4,654 Answers
That is a broken thermostat control part number 67003000 when they stop they can break while on or off. Sea Breeze
PART NUMBER AND MODEL SEARCH FEATURE
Posted on Jul 23, 2009
My kenmore elite refrig keeps leaking water from what appears to be condensation. It gets so bad that the ice maker door freezes shut and water actually drips on the floor. The freezer is set to 0 while...
The high level of condensation is due to constant opening of the fridge when the frost develops. It is required to defrost off the condensation and if this has an auto mode timer for defrost , then it is possible that it is not working.
The water must drain out to the drain tank but since it is formed out of the freezer the water flows out of the collection tray.
Sep 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Water accumulating in bottom of refrig under crisper drawers but not in drain pan under unit.cannot locate drain line
Here is a tip that I wrote about how to fix your freezer so that the drain hole does not keep freezing up.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 23, 2010 | Kenmore Refrigerators
Items in refrig are freezing when they're not supposed to.
thermostat has failed i'd say..its not turning off at the requested temp.
Jul 24, 2010 | GE Profile PGSS5PJXSS Stainless Steel...
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Items in the back of the refrigerator freeze.
is this something that has just started happening? Most kenmore top freezers have a vent that allows cold air from the freezer into the refrig through a vent located on the back wall in the center of the refrig section. if packages are pushed up under this vent they can freeze.
If you have widespread freezing in the refrig setion then a temperature control could be the fault. thanks for using fixya. Peyton..
Feb 17, 2009 | Kenmore 72992 / 72994 / 72999 Top Freezer...
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Amana bottom freezer model #BX21TW purchased in 1996
this particualr refrig is notorious for this. check your controls ( your freezer control as well set to 4 max) any higher and the refrig is running longer, generating more cold then needed, behind the left hand crisper is a few slots( the fresh air return) by default the coldest spot in refrig, i usuallly would reccomend to my cust not to keep high water or thin walled vegies in there such as carrots cukes tom and lettuce, perfect beer and fresh /frozen defrosting meat to be though, if you ever looked at the newest bottom freezers they've pushed up the drawers and added a deli pantry, running the width of frig
Feb 27, 2008 | Refrigerators
Kitchenaid superba refer side by side
its normal for the temperature to stay around 28 degrees farenheight int the bottom drawer. (fresh cut meat keeps better at his temp). you can adj the temp slide near the bottom of the refrig next to the botom drawer to help adj temp. veggies will almost always freeze in the bottom drawer. also adj the temp controls to a little bit warmer to help as well.
Keep in mind the mid point settings on your refrig is just a starting point for you to adj to where it works best for you and your usage..
Dec 17, 2007 | KitchenAid Superba Architect KSCS25INSS...
Kenmore top freezer unit-refrig not cooling past 50degrees
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer freezer allowing MORE air to refrigertor side.
Sep 03, 2007 | Kenmore 64802 Top Freezer Refrigerator
LG LSC26905TT Side by Side Refrigerator Logo
289 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
