Washing Machine not coming on
I have a Hotpoint WT960 and the screen has been flickering for about 2 months. I tried to switch it on this morning and nothing at all, not even a flicker! I have changed the fuse and have also chacked that there is power going into the machine which there is. Could it be the motherboard?
Cheers
    Scholar:
  • 61 Answers
You said the screen was flickering, it could be a problem with a faulty/loose cable/connection. between the board and display i would try this first. with the power off as electricity should not be messed with
Posted on Jul 23, 2009
Hotpoint washing machine wt960 not working because fo8 code come
Hi Hitendra,
F08 is a sticking heater relay. First check that connections on pressure switch are good, Check that heater connections are good.Check the board connections.Check that pump filter is clear.
Hope this helps!
Wayne
Nov 20, 2014 | Hotpoint Washing Machines
Hotpont washing machine wt960 fo8 code m/c stop
I believe F08 Error code is for a Heater fault
Issue: During a wash cycle the programme pauses part way through.
How do i reset my hotpiont ultima lcd wt960 washing machine?
I have a hotpoint wt960 i did 1 load of washing, turned it off. Put next load in then it would not turn back on. any ideas???
Nov 15, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machine will not turn on
Check the fuse braker (box out side) The lid switch may be stuck with soap and etc stopping the plunger from operating properly. Lid and door switches stuck, see if not pushed in and release out when lid or door opens. Hope this may help you.
Jun 02, 2009 | Washing Machines
Hotpoint wt960 comes up with test all the time
Press the Start/Cancel button until all the console Led's Illuminate
Press both Start/Cancel and On/Off buttons together until 'd off' appears
Normal screen should return and you can select a new programme. (GL = good luck)
Mar 14, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt960 lcd screen failure
Hi, I have experienced this problem on several hotpoint machines with led display's. There is really only one solution for it! If there are no wires hanging off then the answer is in the board, And you will need to replace it. It is a non servicable part and cost around £40.00+++.
Good luck.....
Dec 24, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt960
this m,eans the water is not entering the machine it iseither the inlet valve or water off at tap
Dec 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hi where is the filter for a hotpoint WT960 washing machine
Its most likely built into the tub and you don't need to access it.Under the agitator is usually the place on the tub they would put a filter
May 25, 2008 | Washing Machines
Washing Machines Logo
281 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
