Question about Car Audio & Video
Silvercrest bluetooth car radio. Working fine but wont save stations when switched off. Any ideas.
  • 655 Answers
Hello userpete,
It's possible that the 12V constant wire is either not connected properly or there's no voltage present when the vehicle is turned off. You'll have to check your installation manual for the unit, I can't look it up without a make and model number. But usually, the 12V constant wire is "yellow". If you're using an aftermarket wiring harness, make sure it's connecting to the correct wire in the vehicle wire bundle, and that there's 12V present when the ignition is turned off.
If this checks out OK, the unit itself is probably defective.
Hope this helps.
Posted on Jul 24, 2009
My vw Passat 16 plate infotainment doesn't appear to be working, I have lost all radio stations bar a couple, it won't save them anymore, when I save one and stop the car lock it and get back in everything...
It has lost battery power. It has 2 power sources. The battery is constant, no fuse. This is for the radio memory. The ignition is fused, it is the one that turns the radio on. You have to pull the radio plug and check for battery power. If it is there, you have an internal radio problem.
May 04, 2016 | Cars & Trucks
Wont save stations
There are 2 battery feeds to the radio.
The Main one via the Ignition Switch . This is used to switch the radio ON
The other is a permanently connected battery feed that retains the radio memory features...ie..the code and the radio station settings.
It looks as though it is this permanent battery feed that is missing.
Check the fuses and the connectors/wiring at the rear of the radio
Feb 14, 2013 | Kenwood Car Audio & Video
I have a kenwood radio and the radio wont switch off demo mode no matter what i do. I have looked at all wires etc and it still wont save preset stations or settings.. Its driving me mad! When i bought...
if it isn't saving stations you need to make sure the yellow wire is going to a constant power source. without knowing what brand or make of radio you have, it is hard to say how to turn off the demo mode.
Mar 22, 2011 | Car Audio & Video
3 problems with my wharfedale ics182. 1. The stations are not stored when turning off the radio and then switching back on. 2. When turning the ignition. the radio does not turn on. my other radio does...
Swap the battery and accessory lead positions in the ISO header plug. This is easily done by pressing the pins out from the plug side using a fine bladed screwdriver.
_MANY_ cars have these 2 wired the "wrong" way in their radio socket. It's far easier to move the radio's wires than the cars.
Once you've done this your bluetooth will probably sort itself out too.
Dec 29, 2010 | Car Audio & Video
JVC stereo not working properly - 2001 Sonata
generally wiring from the car is as follows...
red = ignition controlled live
yellow = permanent live
if you want stations saved and manual switch off of uni connect radio's yelow and red wires to the cars yellow.
if you want stations saved and radiounit switch off controlled by ignition (i.e only when car is running) then yellow to yellow and red to red. anything else will cause issues...
Feb 21, 2010 | JVC KD-R200 Car CD/ MP3 Player
I have a 2001 VW Polo with a factory fitted radio, cassette cd player. It's started to switch to the cassette player (which I've never used) and when I switch it back to the radio there's no sound. I...
Hey there! I had the same problem just the other day and removed the radio from the car over night.
Turns out the radio may have got too cold or a little damp! Whereabouts is your car stored overnight? Could be the reason why!
Either that or one of the buttons could be stuck. Hope this helps
Dec 06, 2009 | Car Audio & Video
Radio wont find any stations
this is most likely an antenna problem.
Jun 29, 2009 | 1999 Chevrolet Monte Carlo
KENWOOD KDC - W312SAY BUTTON MEMORY 1 - 6 NOT WORKING
what is the problem but if you want to memoris your station you just search for the station and press and hold the burton number #you wish to program it on
Dec 10, 2008 | Car Audio & Video
Car Audio & Video Logo
941 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
