Question about Frigidaire fes365e Electric Kitchen Range
Frigidaire lower element not working
We have a Frigidaire Gallery range - 11 years old. A breaker blew when set to self clean and the lower element would not heat.
We tested the lower element and it is not broken. The problem appears to be a "coil" on the circuit board that sends current to the lower element. Question: Can the "coil" piece on the circuit board be replaced or will it be necessary to replace the whole board?
Thanks for any help you can give.
  • MDeee Nov 24, 2007
    The way we know it is not the element itself is that we checked the voltage at the terminals. The question was whether a part of the circuit board could be replaced (hopefully at less cost) or will the entire board need to be replaced (Over $140)
  • 40 Answers
Does the element have continuity??Did you do an amp reading with the element connected?? Do you have voltage at the element terminals??If you have voltage at the element and you don't read amps when unit is on then it's the element.If it's the coil?The board should be replaced.Local appliance store may have it or can order it.
Posted on Nov 21, 2007
  • Michael Calligan
    Michael Calligan Nov 25, 2007
    You would have to replace the entire board.
Self cleaning mode had failure. Cleared by flipping breaker. Now runs bake/ convection mode with broiler at 600 + degrees and lower oven operates under temperature. I think temperature sensor error
Hello Pamela, thanks for your post!
From my understanding your Frigidaire range had an issue when it was in self-cleaning mode. It sounds like your thermostat or control panel may need to be replaced. I would suggest seeking help from a professional technician this will help you to avoid any unnecessary part purchases or improper disassembly of your range. Hopefully this information is helpful to you. -Matt
Jan 03, 2016 | Frigidaire FGES3045KF Gallery 30" Slide-In...
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Jan 03, 2016 | Frigidaire FGET2765KF
Frigidaire electric stove does not work at all
First check the breakers at your house's breaker box. A tripped breaker will be a little bit away from on. Push it all the way off, and then back on. If it trips again, call an electrician.
Dec 01, 2013 | Frigidaire Gallery FGEF3055M 30"...
I have a frigidaire gallery glass stove top that is about 5 years old. I can't locate the book that came with it... I want to use the self clean and don't know how to. Also, I don't have a door lock...
Good Morning Sandy, thank you for allowing me to assist you!
I understand you are seeking information regarding the self-clean feature for your above-listed range model number, GLEFM397DS. I have located the Owner's Guide on the manufacturer website and you will find step by step instructions on how to do so from pages 32 through 34. Hope this proves helpful! If you have further questions, please do not hesitate to reconnect.
Sep 25, 2013 | Frigidaire Gallery GLEFM397DS Electric...
The lower element burned in my oven. I replaced the element, but the oven will not work.
unplug range ..remove the back cover plate check all wires all connections ..their must be a burnt /broken /dissconnected wire ..check where the wires connect to the bake an broil element ..and the bake broil switch..if all looks good .then the bake broil switch burnt out when element blew out..plus is the breaker tripped in the box ..it prob. tripped when the element blew out..let me know..good luck
Aug 28, 2010 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire gallery stove, oven not working,
Morison,
The same thing happened to me about a week ago. I was preheating our electric oven, heard a very loud bang/pop. Checked and the oven had PF (power failure) I went downstairs and the breaker was tripped. Came back upstairs and to look at stove, the burners are working fine so I continued to preheat oven after a half an hour the oven was only slightly warm. Did you ever find out what was wrong?
May 04, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
nguyen@ite.net
Jun 09, 2009 | Frigidaire 30 in. Electric Gallery Series...
Frigidaire fes365e Electric Kitchen Range Logo
258 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
