Question about Motorola XU2100 (1 Channel) 2-Way Radio
XU2100 takes full charge, but will not transmit or receive
I run a small security team at my church. One of our XU2100's takes a full charge, but will not receive or transmit in stand alone or using the earpiece mic. Before I can go to the controller for repair money, I need a better idea of what may be wrong and what it might cost. Any ideas?
  • Motorola Master
  • 1,654 Answers
It is possible the radio has been changed to another frequency or PL code. Check the numbers in the upper right corner as you turn the radio on. The first number will be the frequency, the second number the PL code. (If both numbers are the same you will not notice them changing other than the word freq disappears.) If these numbers differ from your working radios, then your radio simply needs programming. If you need help walking through programming, simply call our office at 800-872-2627, one of the ladies will be happy to walk you through programming the radio over the phone. (This saves a lengthy explanation here on FixYa.) The second thing to check would be to try another battery in the radio. Just take one from one of your known good radios and try it in this one. Anything past these two potential problems would need to be looked at by a technician. This style radio is typically repairable. You can expect to find a flat-rate of approx. $69.
Regards, eradiostore
Posted on Jul 23, 2009
  • eradiostore
    eradiostore Jul 31, 2009
    Thank you for the nice note. Glad we were able to help.
Is it possible that my general lee cb radio did not transmitt this morning because it was -30 below? I Was able to receive
As long as it was getting a good 12 volts power supply it shouldn't matter. Was the vehicle running and charging the battery OK?
Transmitting takes more power than receiving. And -30 F is pretty tough on batteries.
Feb 18, 2015 | Radio Communications
Did the pope ask the new orleans saint's not to play on sunday's
It is unclear whether the request was received from the the Pope himself, but it was received from Vatican City.
The Vatican's request, addressed to owner Tom Benson, reportedly asks the team to consider abstaining from playing games or conducting practices on Sundays for the 2015 season and beyond because of the team's Catholic-based name and affiliation.
The team, named "Saints" because it was awarded to New Orleans on the solemn Catholic celebration of All Saints Day, plays the majority of its games on Sundays, which has been a source of long-standing apprehension for many in the religious community. According to Catholic teaching, Sunday is a day meant for rest as stated in the church's Ten Commandments
Nov 12, 2014 | Computers & Internet
How do program or clone an RDU2020 with a XU2100 ?
Here is a link to the RDX series page at Motorola, in the lower right corner there is a link to the user guide for your RDU2020 radio. In the user guide there is a very good explanation of matching the XU2100 to the RDU2020. The RDU radio was the next model in line after the XU2100 and was designed to work with it. http://www.motorolasolutions.com/US-EN/Business+Product+and+Services/Two-way+Radios/On-site+Business+Radios/Discontinued/RDU2020_US-EN
Apr 02, 2014 | Motorola XU2100 (1 Channel) 2-Way Radio
Why does the walkie talkie shut off when trying to taslk
If the batteries are not fully charged - or if the batteries are old an no longer capable of accepting a full charge - they may not be able to provide enough power to operate the transmitter, an shut off. If your radio supports hi / lo power settings, try switching to lo. Receiving requires much less power than transmitting, so you may not realize that the batteries need to be recharged / replaced until you transmit.
Nov 26, 2012 | Radio Communications
Does not transmit or receive
Hi Michel.
Did you buy this new or second hand?
If used, then there's every chance previous owner has deleted the channels, naughty.
As a guide to help you get resolution, try the following: join yahoo group specific to your radio Make/Model, the team there will require you the give as much info as possible regarding your radio, this will help them help you.
It's free to join and they have heaps of useful info and advice regarding your radio.
I hope this helps you get on air soon.
Cheers,
Peter
Nov 18, 2012 | GE 40 Ch. Full Power "help" 2-way Cb Radio...
I have a motorola rdv2020 and after a few minutes stops transmitting. You can see the recieving light come on with the other radio, but no voice is coming through. After shutting it off for a few minutes...
It is possibly a bad or poorly charged battery. Try a known good battery and see if the problem persists. When a battery is failing the first indication is usually loss of transmit. It takes more power to transmit than to receive.
If the battery appears to be the problem, check your charger to see that it is working properly and clean your battery contacts with a pencil eraser prior to giving it a full charge. Then try the original battery one more time. If it still fails, replace it.
If after testing the radio with a known good battery you still have a problem. It is likely your radio is in need of repair. Flat rate repair is available for this type of radio. (Currently running $85.) Or if your radio is less than one year old, contact the vendor where you purchased the radio for warranty procedures.
Best regards.
Mar 16, 2011 | Motorola Mobility RDV2020 RDX Series On...
X107 Mini helicopter does not seem to be taking a charge from USB port on computer. ran coptor for about 2 weeks following recharging instructions... rest, recharge of heli in "off"...
Hi, My X107 MINI HELICOPTER does not receive transmit anymore. It was working fine before. It only flys if I hold the remote control right next to the sensor. If I move it away it loses transmit. Both units have full power. How do I solve this problem.
Jan 27, 2011 | Cobra Electronics Cobra RC 3 Channel Mini...
My XU2100 XTN series 2 Way radio is not working. Not receiving or sending transmissions to the other two radios. It is fully charged. It does not make an audible "beep" when you turn it on. ...
Your radio is likely in need of repair. Flat rate repair for this model usually runs around $69. The fact it does not give you the initialization beep indicates it is more than a frequency problem. Then coupled with you do not have transmit or receive, this sounds like you have more of a problem than a bad speaker.
A few things to check before sending it for repair would be:
1) Swap the battery with a known good unit to see if your battery is bad/low and doesn't have enough power to function the radio fully.
2) Check your frequency and code to see if it matches your other units. This is in the upper right corner of the screen shortly after turning the radio on.
3) Check your mic opening in the grill of the radio to be certain it is not covered or free from debris.
If these any of these three items do not solve the problem, you should send your radio for repair.
Best regards.
Nov 12, 2010 | Motorola XTN UHF Two-Way Radio Series
XU2100 (1 Channel) 2-Way Radio: How do I change frequency on a motorola xu2100...
Hello, I just purchased 3 of the discontinued XU2100 radio's, Can someone help me to change the frequency on them? My email address is cubnboy@yahoo.com. Thank u for your time...
May 16, 2010 | Motorola XU2100 (1 Channel) 2-Way Radio
Won't receive or transmit
Here is a link to the user manual: http://www.motorola.com/mdirect/manuals/T56XX_57XX_User%20_Manual_E.pdf
May 31, 2008 | Motorola T5710 (22 Channels) 2-Way Radio
Motorola XU2100 (1 Channel) 2-Way Radio Logo
209 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Greg Cann
Greg Cann
SHARCNET-USA
SHARCNET-USA
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
