Question about Pioneer DEH-P5200 CD Player
How do you play your ipod with DEH-P49001B system.
I don't see any plug to connect my ipod to.
  • 20 Answers
Two options.
1. To play AND control your iPod from this system, you need to purchase a separate cable. Model is CD-I200 and it plugs into the back of the unit and the other end plugs into the dock connector of your iPod. (Assuming your iPod has a dock connector)
2. To play your iPod only through the system use the AUX1 mini stereo connector. Unfourtunately the AUX1 input is located on the rear of the unit. You need a separate cable with a mini plug on both ends. (Will look like a headphone plug on both ends). You will probably have to pull out the system to be able to plug in the cable unless you are lucky and you have tons of room under your dash to be able to reach the rear of the unit. Make sure you get a cable that is long enough to reach from under your dash to where you want to keep your iPod in reach.
Posted on Jul 23, 2009
    Problem Solver:
  • 11 Answers
I've got you man. There's a double-sided cable that looks like the end of a headphone jack, walmart or radio shack will have one for you. The plug is on the back of your radio, I had to take mine out to get to it. Should be the top plug of the two little black ones.
Posted on Jul 17, 2010
How to set it to play with and Ipod
After researching your model DEH-P470MP, it appears that to use an iPod, you need an adapter that plugs into the rear port of the unit intended for a multi-cd changer connection.
If you have one installed and it's not working, I would check the connection on the unit. Make sure the cable is firmly seated in the port and then check the cable and also check for any fuse in the line to make sure it's not blown out.
Also some of the earlier models of ipod adapters aren't compatible with the newer generations of ipods. There are aftermarket adapter plugs that will allow your ipod to charge/play off these earlier decks/adapters.
May 29, 2010 | Pioneer DEH-P470MP Premier In-Dash...
I have a Pioneer DEH-P4150UB car stereo with usb-ipod connection. This was working this morning however when I connect the ipod now there is no volume coming from the system. The tuner works on the system...
you can try a soft reset on ipod by holding the menu and center button at the same time for 10-15 seconds and/or reset your radio by taking face off of it and pushing the reset button on the stereo too.
May 19, 2010 | Car Audio & Video
Help with ipod connection to cd player
You must use 1 of 3 methods to connect your iPod
1. FM modulator to wirelessly broadcast on a low FM band
2. iPod 3.5mm male/male direct connect cable.
3. iPod USB connection - with Pioneer iPod adapter module.
The direct connect 3.5mm port is on the back of the unit. One plugs into the radio - one plugs into the iPod headphone port.
Click HERE for your owners manual in PDF format.
CLICK HERE for the installation manual
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 13, 2009 | Pioneer DEH-400UB Car CD/ MP3 Player
I installed a pioneer Deh P49001B car stereo in a 1997 dodge stratus with wiring adapter from best buy. everything works great until you switch on the lights. all power to stereo is gone.
to solve the problem with it turning off when u turn your lights on is that on the back side of your radio is a spot that says max and something else keep your ground wires conected just how they are but get u a a 14 to 12 gage wire a cut u about 6 inches and use one end and connect to your other ground wires (with Connecters ) and the other end and with a closed end connecter with the little hole in the center i cant place wat its called but any ways put it where that max hole thing is where there is a screw there and that should fix that problem cause i had that happen before .. but make sure your antentia is pluged iin to ok .. good luck Paul,
May 13, 2009 | Pioneer DEH-P5200 CD Player
Cannot select ipod as a source on my deh-1500
The RCA jacks are preamp outputs (to use with a sub or external amp) not input to use with an iPod
There is no way to direct-connect an iPod to the DEH-1500.
You can use an iTrip or other FM-radio transmitter to play your iPod through an unused channel on the FM radio band
Apr 06, 2009 | Pioneer DEH-1500 CD Player
Connecting an ipod
Just press the bottom ipod in your player and start browse your ipod lists from your player
Jan 06, 2009 | Pioneer DEH-P3000IB Connect an iPod nano...
Deh 2800mpb + ipod, laptop
Negative; there is no way other than maybe an RF modulator to hook uup an iPod or other device to this head unit. For more information on this head unit follow this link: http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/Source/CD-Players/DEH-2800MP?tab=B
Jun 08, 2008 | Pioneer DEH-2800MPB CD Player
I tryed to use the red and white plug ins in the back to hook my ipod up but when i play my ipod i hear the ipod and either the radio or a cd is it possible for me to b able to hook my ipod up with out...
The RCA red and white plugs are OUTPUTS to connect to an amplifier. You are driving one audio source against another-which isn't good. There is no aux input to connect your iPod to. Copy your Ipod music to a CD-R instead and then play it in the pioneer.
Aug 31, 2007 | Pioneer DEH-1100 CD Player
Pioneer DEH-P5200 CD Player Logo
682 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
