Question about Locks & Locksmithing
My sliding patio door is sticking
This is a standard patio door, and I'm sure there must be some way of adjusting it - the only adjusting screws I can find seem to be used to hold the actual doorframe together. Any ideas?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Usualy there are 2 ajustment screws at the bottom in the flashing
if you lift the door out of the track and look at the bottom you will see the rollers and likely the ajustment screws is there are no adusters make sure the rollers are free f not spray with penetrating oil and let sit untill free then try again
if sash or frame is tight try spraying it with pledge furnature polish the light grease coat will allow plastic parts to move freely once again
Posted on Jul 23, 2009
    Welcome Back:
    Visited the website for 2 consecutive days.
My track was worn badly. Repairing the bottom track on a patio glass sliding door. it had many gouges in it and the door would jam at each spot. initial thinking was that the whole door would have to be replaced. At costs from $200 to $800+ I had to think of other options. Could this track be sanded down to even the track again? Can just the track be replaced? I finally found at Home Depot a rail that goes over the old one at a cost of $12!!! It had to be ordered but it arrived at the store 2 days later & no shipping fees was charged. I had to remove the sliding door side only. This track is 8 ft long so measure & cut whatever width the door is. After the door was removed I slid the new track over the old track. I was able to slide the track under the permanent door side so removal of both doors was not necessary, slight pressure had to be applied to push the track down. Put the sliding door back on the track and cruised my fingers that all worked!!!! The door now rolled smoothly back & forth with no jamming, Cost if $12 and about an hour of time & I felt like I had a brand new door !!!!!!
Posted on Aug 07, 2014
    Sergeant:
  • 384 Answers
Track is dirty. Vacuum clean. Rub candle wax to track. Wheel adjustment are on end of doors...single screw to raise or lower door.
Crossly turntable/cd tape player
If there's a small hole in the front of the door anywhere, push a paperclip in there to release the door.
Mar 04, 2014 | Slide-Co Sliding Glass Patio Door Latch...
Pella sliding screen door keeps coming off track
MAke sure there is no debris in the tracks. MAke sure the rollers are not damaged. MAke sure that they are adjusted properly so that there is no upward motion on the screen. You may want to have someone lift the screen up as high as possible while the adjustment screws are set.
Aug 19, 2013 | Pella Screen Door Roller Adjustment Screw
Why are patio doors most convenient for renovations?
Patio doors are the most convenient product available for renovation on the market today. They also happen to be one of the most secure options available. Standard tempered glass and multi-point locking for the highest levels of security for a door opening. Patio doors are also affordable because of standard sizes such as five and six feet. There are numerous options for patio doors including grills, colors, custom sizes, locks, glazing and blinds.
Jul 15, 2013 | Heating & Cooling
Oven door removal
Most residential oven doors are removable by taking out two screws of each hinge. Located on the door on left n Right sides where the hinge slides into the door. These also are the way to adjust the door by loosening n then snug the screws, close the door. Adjust it, then carefully open without affecting your adjustment. Then tighten the screws. When removing the door MAKE SURE THE DOOR IS FULLY OPENED. THE HINGES ARE SPRING LOADED N WILL SNAP BACK.
Sep 24, 2012 | Whirlpool WFE361LVS Stainless Steel...
My sliding patio door will not unlock
Spray some WD-40 in the lock and see what happens, if that don't work find a big red brick and throw it at the door!
Mar 11, 2011 | American Standard 6034.STE5.002 Chrome...
How can adjust faint dark adjustment?
open the front door, remove mounting screws of toner hopper at top right corner, flip open hopper cover, slide out hopper , above the drum unit in center there is corona assembly, detach connection of corona cleaner, on the right side of corona assembly there is a black plastic lock, loosen the screw and slide lock upwards, slide out corona assembly, on the upper side of corona assembly there are clear plastic adjustment screws, if u want to make copies darker- turn all of four screws evenly counter clockwise and if u want to make copies lighter- turn all of four screws evenly clockwise.adjust half turn every time and check. revert whole process to put all together. make sure u connect hopper connector at the right bottom side of the unit after sliding in the unit.
Feb 10, 2011 | Canon imageRUNNER 6000 Copier
HEALIGHT NOT ALIGNED WITH THE Other one?
There are two torqs style alignment screws, one for up/down the other for left/right. These screws can be found next to the headlight. Before adjusting the screws check to see if both headlights have similar play when you move them by hand. I had a sliding lock tab out of place, so one headlight seemed loose and hard to adjust. If one headlight is loose, look for two plastic 'sticks' (1" wide) directly behind the light. These 'sticks' are slotted to fit over one fixed metal rivet and one plastic tab from the headlight. The trick is making sure the bottom of the stick fits in a pocket below the light. It's best to use a flashlight and a long flat-blade screwdriver to push the stick into the pocket as it locks over the tabs. Without all three points of contact the headlight will seem loose.
Apr 03, 2010 | 2002 Chevrolet Blazer
Need leveling screws (bolts) for my patio table legs
Hi I would try a local patio supply place. Something like BBQ galore
Dec 17, 2008 | Hardware & Accessories
Glass on sliding door
this is the link to the information http://www.swisco.com/Screen/how-to-repl...
Opening your patio sliding glass door should be an easy task. If your sliding door is giving you a work out every time you open it, most likely it is your rollers that are causing the problem. The rollers are located on the bottom of the sliding door and give the door the ability to slide. Often times they get dirty and wear out, making it difficult to open the door. If you have an older sliding glass door your rollers may have become rusty because sliding door units did not always use stainless steel rollers.
Hiring a professional to replace your rollers could cost you around $100 not including the cost of the replacement parts. Below are detailed steps containing all the information you will need to know to replace your patio sliding glass door rollers yourself.
* Before you start, understand that you need to take the sliding glass door out of its frame to work on the rollers. The sliding glass door is heavy. You may need the assistance of another to help you remove the door.
1) Your patio glass door will have two separate glass units. One unit is the door that you slide and the other unit is stationary. First, stand outside your house and look at your sliding glass door. If the stationary unit is between you and the sliding unit you will most likely have to remove the stationary unit so that you can get to the glass sliding unit.
Before you go through the trouble of removing the stationary unit, first try to go inside your house and see if you can remove the sliding unit. Usually you cannot because there is a lip along the bottom of the patio glass door frame (it keeps moisture out of the house) that prevents the sliding glass door from being removed from the inside.
If the rollers on the bottom of the door are difficult to get over the lip, you can adjust them to help you create more room (go down to step 2). If it is not the rollers but the sliding unit�s frame preventing you from pulling the sliding unit out of the door frame, you are going to need to remove the stationary unit first before you can remove the sliding unit.
To remove the stationary unit, you first need to take out your screen door (if you have one). Lift one end of the screen door frame and use a screwdriver to lift the roller on the bottom of the screen door frame off of the track. Do this to both ends of the screen door and your screen door will pull out of the door frame.
The stationary unit is held in place by a metal piece that runs along the bottom of the track from the corner of the stationary unit to the bottom of the side jamb (there is a chance this piece is missing but if you do have one remove it from the track). After you have removed the metal piece, look for screws holding the stationary unit frame in place. After removing all of the screws try pulling the stationary unit out of the door frame. If you are having trouble pulling out the stationary unit, try placing a screwdriver between the stationary unit�s bottom frame and the track it is resting on. Lift up on the screwdriver while you have a helper pull out the stationary unit from the door frame. Be careful not to use too much force with the screwdriver so that you do not damage the door track.
2) You may need to create more room when you attempt to remove the sliding unit from the door frame. To create more room you can adjust the rollers on the bottom of the sliding unit. By turning the adjusting screws on the rollers clockwise the wheels move up into the sliding unit�s frame giving you more room. The adjusting screws are located either at the bottom of the sliding unit�s frame or in the sides of the frame. There is a chance that there are plugs covering the screws.
After you adjust both rollers (one on each side of the sliding units frame) try to remove the sliding unit from the door frame. If the unit is still getting stuck you may need to get someone to help you. Have your helper lift one side of the unit and pull outwards while you try to pry the other side of the unit over the track.
3) To remove the rollers from most sliding units you need to remove the bottom of the sliding units frame. Most likely the screw that holds the roller in place is the same screw that holds the frame together. Remove the screw from both sides of the unit. Then try to remove the bottom piece of the frame off of the sliding unit; you may need to use a rubber mallet or a piece of wood and tap on the bottom of the frame until it comes off of the sliding unit.
Now that you have removed the bottom of the frame you can take a close look at your patio glass door rollers. Remove one of the rollers and match it up with one of the rollers on this page http://www.swisco.com/page/SI/CTGY/patio...
It is a good idea to replace both sliding door rollers at the same time to prevent extra wear-and-tear to one new roller, which will have to work twice as hard when paired with an older roller.
4) After your new rollers come in, replace your old rollers with the new ones. To make it easier to install the sliding unit back into the door frame, adjust the rollers to be all the way up into the frame. Once you have the sliding unit back in the door frame you can adjust the rollers for optimal performance. Keep adjusting the rollers until the door is sliding back and forth easily
Jun 22, 2008 | 1996 Ford Windstar
Locks & Locksmithing Logo
219 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
