Cooks Essentials Pressure Cooker Instructional Manual
We've added headings to facilitate navigation.
Basic operating instructions are the same regardless of capacity.
cook's essentials( HIGH PERFORMANCE KITCHENWARE 6 QT. PROGRAMMABLE ELECTRIC PRESSURE COOKER
MODEL CEPC660
OWNER'S MANUAL
IMPORTANT SAFEGUARDS
When using electrical appliances, basic safety precautions should always be followed including the following:
1. Read all instructions.
2. Do not touch hot surfaces. Use handles or knobs.
3. To protect against electrical shock do not immerse cord, plugs, or appliance in water or other liquid.
4. Close supervision is necessary when any appliance is used by or near children.
5. Unplug from outlet when not in use and before cleaning. Allow to cool before putting on or taking off parts.
6. Do not operate any appliance with a damaged cord or plug or after the appliance malfunctions or has been damaged in any manner. Contact Consumer Service for examination, repair or adjustment.
7. The use of accessory attachments not recommended by the appliance manufacturer may cause injuries.
8. Do not use outdoors.
9. Do not let cord hang over edge of table or counter, or touch hot surfaces.
10. Do not place on or near a hot gas or electric burner, or in a heated oven.
11. Extreme caution must be used when moving an appliance containing hot oil or other hot liquids.
12. To disconnect, press the START/STOP Button until the red STOP Light illuminates and the Pressure Cooker beeps. Then remove plug from wall outlet
13. Do not use appliance for other than intended use.
14. Do not fill the unit above the MAX Fill Line. When cooking foods that expand during cooking, such as rice or dried vegetables, do not fill the unit over 1/2 full. see the Cooking with your pressure cooker section in this manual."
15. Do not cook foods such as applesauce, cranberries, pear barley, oatmeal or other cereals, split peas, pasta, or rhubarb. These foods tend to foam, froth and sputter, and may block the Steam Release Valve.
16. CAUTION: To reduce the risk of electric shock, cook only in the Removable Cooking Pot.
SAVE THESE INSTRUCTIONS FOR HOUSEHOLD USE ONLY
http://www.vipconduit.com/terry/info/PressureCookerManual.html
