Question about Refrigerators
Put new mother board in refrigerator and it sounded like everything was working good but in the morning there was a loud noise in the freezer
    Champion:
  • 363 Answers
Sounds like the circulating fan is wearing out, this fan has a dc motor that wears down over time, when it starts the noise it generates is very annoying. What happens is the stator or spinning part of the motor wears down. This fan motor is around $80.00 if you purchase it and replace the motor yoursefl. But the minimum cost to repair/replace this fan assembly labor and parts is around $300.00
Posted on Jul 30, 2009
Freezer fan makes noise
Noisy fan = new fan motor.
May 13, 2017 | Admiral Refrigerators
Loud ticking noise when i close freezer and lights on icemaker flash like a stobe light. fridge and freezer wont hold temp. ice amker and water dispenser dont work?
if your lights burned out recently and the digital temp read-out is now dark also,burned out lights will cause a power surge and will destroy the main-board circuit trace(mother-board), it is located in the back side of the refrigerator, in a small plastic case,when you remove it you will see a burned spot on the circuit board and the loud clicking sound is a relay on the board trying to latch to light the bulbs and operate the unit
Feb 21, 2010 | Frigidaire FRS3R5EMB Side by Side...
My mothers beko fridge freezer making bubbling sound
Sounds like the evaporator fan is doing its job. Nothing to worry about. Good hearing is a blessing all fridges make different sounds some click loud while others gurgle loud. Some pop and snap. Till I got my hearing aids I didn't know mine ran so loud and clicked.
Dec 15, 2009 | Refrigerators
Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Nov 12, 2009 | Frigidaire FRS26R4A Side by Side...
Ge profile bottom mount and temperature control
sounds like the mother board maybe bad. we replace alot of those , or 2nd i would say a display board .
Sep 13, 2009 | GE Profile PSW26P Stainless Steel Side by...
Kitchen Aid refrigerator is making a very loud noise!
when you transported this unit did you lay it down or stand it up? If it was layed down then you should of waited at least 24 hours before plugging it up again to give the oil in the compressor time to settle back down. Actually either way it was transported it still needed the 24 hour rest time. So if you automatically plugged it in after transportation you could have messed up the compressor. Let it set unplugged for 2 days then plug it in and see what happens. If loud noise persists then you know the compressor is shot. Goog Luck.
Sep 02, 2009 | KitchenAid Refrigerators
The the refrigerator just stop working
a new fridge is probibly needed. The sounds you heard was possibly the reeds in the compressor that were going bad. Good Luck
Dave
Jul 24, 2009 | Amana ATB1832AR Top Freezer Refrigerator
Freezer making a loud noise.
Sounds as if the evaporator fan has shaft play or the blades are out of balance or striking something. When you open the door the pressure is equal but with the door closed the fan needs to push the air through the evaporator and return again and circle through fan again. I think soon would be a good time to unplug the refrigerator and remove the back panel covering the evaporator and fan motor to inspect the fan, shaft play and the evaporator for frost buildup or any obstruction of air flow. Thanks, sea Breeze
Jun 17, 2009 | Samsung RS2630WW Side by Side Refrigerator
Mother board
The motherboard is located under a rectangular cover on the back of the refrigerator. I'd check to make sure your defrost heater was good first. It's behind the back wall of the freezer section. (Part # WR51X10055)
Sep 16, 2008 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Refrigerators Logo
148 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
